Originally Posted by jassi I had some queries from a friend who owns a swift and seemed excited with the idea of modding his one year old swift - hope someone can answer these queries as I only have theoretical (read googled) knowledge on tc'ing
1) If a tc is done to a bangy car by a tuner in another city (lets say by KS in bombay), and given that it takes 3-4 days to tc the swift, how much tuning is needed once the install is done. As in, will one trip to bombay suffice or will further tuning and alterations be needed
2) Can all models of swift (lxi, vxi w abs, zxi) be tc'd
3) How difficult is it to maintain and service the car once tc'd. In layman terms, can the car be regularly serviced by any maruti shop and does the tc need any special support or post install servicing precautions. Also how often (if at all) do I need to get the tc serviced or checked by the installer (read at what frequency a bangy-bombay drive)
4) What other mods are recommended to support a tc'd swift - apart from tires/alloys, do I need an FFE, suspension mods, etc.
TIA
-j |
1) If you get the tuning set up right then it will probably suffice but you will need a few runs on the Dyno to get the tuning right i.e. according to your driving style. Then run around fro a few days and see if you are satisfied. If yes then thats it. Everyone's driving style is different. The tuner is the basically going to do a basic set up and then you have to give feed back to him as to what areas you want tweaked. A lot of people have this misconception that if a tuner tunes the car then all issues have to be sorted out. What may be an issue to you, may not be an issue to him, this is where your contribution is required.
For eg. whether you want the turbo to spool in early or late, etc are issues you have to give feed back to your tuner to solve
So the time taken will be entirely on you after the basic set up.
2) Yes all models of the petrol Swift can be T/c ed with out without ABS but it would be better to have ABS on the car.
3) Anyone can service the T/C but owing to the inquisitiveness of greenhorn mechanics at garages, it would do well to get the car serviced at a place that is aware of t/c-ed cars.
4) Apart from the above mods, the Swift needs better brakes. This can be done by better pads or bigger discs (expensive). Also one would need to tweak the suspension as that is a grey area in the Swift already.
For a T/C-ed car, the exhaust set up will be totally different. The manifold design is also different from a N/A car. This is not every (so called) exhaust maker's cup of tea and should be left to an expert. Normally every tuner get his exhaust work done from a particular person and it is best that such a specific job be left to him.
One would need meters (Boost, Oil Temp, Oil Pressure) at least and a turbo timer installed in the car also.
Then it is upto the owner what cosmetic ad ons he would like to install. @ Gemballa- How about a Matt Black all the way.
Reason: adding content
