Old 27th December 2023, 07:36   #16
Mystic's Avatar
Thanked: 2,075 Times
Re: Maruti Jimny Accessories & Modifications
I have seen a lot of posts on the back seat comfort of Jimny. In my personal case, I don’t use back seat most of the time but still have resolved this issue just in case with the seat cushion from Amazon. I bought 4 large size cushions for 80+ kg passengers as it is officially only 4 seater and not 5 seater. It is worth the money spent especially for people going on long drives. I even bought a small PVC stool to climb just in case as the ground clearance is high. I don’t want to install any permanent step as it is off road vehicle. In case of non occupancy of back seats , I have put in seat belt clips to avoid the car warning me to put seat belts on back seat for non existing passengers. Just check the Jimny water bottle given by NEXA with name Jimny on it. The open wire for the back window is also closed by the accessories shop guy for free.
https://www.amazon.in/dp/B07LDDX8B1?...p_mob_ap_share
Mystic is offline   (7) Thanks
Old 2nd January 2024, 15:36   #17
Jimny Tailgate Table
Any idea where I can purchase a tailgate table for the Jimny?
Checked Bimbra but they have it only for Thar.
Also, is it a good idea to do a DIY project and get a tailgate table made and installed. Attaching images for reference
jishuraajnath is offline   (2) Thanks
Old 12th January 2024, 13:15   #18
Very tastfully accessoried! Could you pls share more details (installation video) of the IPF Light Bar. Was it a straight bolt-on fit or do you have to cut / weld anywhere? Also how stable are the lights after installation? Do they bounce / flex / rattle while driving on bad roads? Thank you!
Invader is offline
Old 1st February 2024, 20:38   #19
Thanked: 77,611 Times
In Japan, Pioneer releases Hiace exclusive inner baffle and Jimny car speaker mounting kit.
Pioneer announced on February 1 that it will release the UD-K5314, a standard package of high-quality inner baffles for Toyota's Hiace, and the UD-K127, a car speaker mounting kit for Suzuki's Jimny. The price is 7700 yen for the UD-K5314 and 6050 yen for the UD-K127.
Hiace High-Quality Inner Baffle Standard Package "UD-K5314"
The UD-K5314, which is exclusive to Hiace, is a high-quality inner baffle that can be upgraded to a custom-fit speaker with a 16 cm diameter that can be upgraded to a custom-fit speaker capable of wideband playback by attaching it to the side of the luggage compartment. In addition to shielding the sound from circling with a sound insulation cushion, the high-rigidity MDF (Medium Density Fiberboard) material is coated with vibration damping coating to suppress resonance and achieve the original high-quality sound reproduction of custom-fit speakers.
Jimny Car Speaker Mounting Kit "UD-K127"
The "UD-K127" for Jimny is a mounting kit that saves space and has high strength because it is attached to the side of the rear seat. Custom-fit speakers can be reliably installed to achieve clear sound reproduction.
Link:
Old 9th February 2024, 03:37   #20
Has any one changed horns on their Jimny yet? Did you get a coupler to coupler fitting or had to cut or slice the wires?
BrezzaGuy is offline
Old 11th February 2024, 12:53   #21
Thanked: 637 Times
Has anyone used the 120 volt socket in the boot of the Jimny?
What can you run with it? How much wattage can you pull from it?
Any leads would be helpful.
dileep is offline
Old 1st September 2024, 12:36   #22
dj_666's Avatar
Thanked: 93 Times
Dyno Wheel HP figures as per OP:
Stock: 64Hp
BMC intake + tune: 75Hp
Cost Rs. 50k for air intake + tune(maybe Rs. 30k)
(Non-malayalees, please use English captions )
Alternate performance intake option under Rs. 20K:
https://swastikfabs.in/index.php?rou...roduct_id=1102
dj_666 is offline
Old 23rd September 2024, 14:51   #23
Thanked: 35 Times
Hey folks. Not happy with the performance of the headlights on the Alpha. Are their any ligitinate solutions easily available in Bangalore (can't do DIY).
Someone also mentioned about changing the fog lamp with a different Maruti vehicle. Can't find that thread.
bhupesh is offline
