Originally Posted by iTNerd
(Post 5598889)
does Viofo A139 pro comes with a micro SD card? |
Originally Posted by flashgo
(Post 5629102)
Thank you for this thread. I am considering buying the Viofo A129 Pro Duo. Can you please let us know if you have done the installation on your own? If not, how much did you spend to get it installed. |
Originally Posted by Mathan1130
(Post 5600220)
Hello there, You need to buy it separately. It supports up to 512 GB. Thank you. |
Originally Posted by indiankesh
(Post 5594037)
Looks good but does it have a Capacitor (recommended ) vs a battery (not recommended) ? |
(Post 5592075)
*SNIP* Night time footage loop recording https://www.youtube.com/watch?v=HtI-...hannel=MathanG *SNIP* |
Originally Posted by Sufficient_shop
(Post 5629242)
Any reason why you didn't hardwire it to the battery? Parking mode and other features are quite useful. When paying 27k, it makes sense to make use of every possible feature, I feel. |
Originally Posted by tilt
(Post 5629254)
THe video looks a little sped up. Did you upload it to play at a higher speed or is this how the cam records? The reason I ask is, I have the A129 Plus Duo and it records at standard speed. Cheers |
(Post 5629306)
Yes , It's in loop mode so its playing at higher speeds.I can share the normal video if you need one. Thanks. |
(Post 5592075)
Conclusion The A139 Pro is a new dash cam from VIOFO.I found it to be easy to set up, configure, and install and the videos to be crisp and clear.*Saving important videos is simple and viewing videos is easy with the VIOFO app.Overall, I am genuinely impressed with the product. |
Originally Posted by Samurai
(Post 5652052)
Originally, I had no plans of spending more than 15K on the dashcam. However, after reading your review, my budget has gone up. :coldsweat |
Originally Posted by hishetty
(Post 5653579)
I purchased the VIOFO A139 2CH Dual Channel Dash Cam - Front 2K 1440P + Rear 1080P with Hardwire Kit for installation in my Suzuki Jimny. Due to the rear tailgate, its not as straight forward install as it would be if it ware a Sedan. Since i intend to Hardwire, looking for a professional installer in Bengaluru who is knowledgeable with fuse tap adapters for clean install. Any leads would be deeply appreciated. |
