Old 30th August 2023, 13:06   #61
F150's Avatar
Thanked: 926 Times
Re: Treel Tyre Pressure Monitoring System (TPMS) Review
With the recent updates the treel app is not showing on android auto apps list again. Could others confirm ?
F150 is offline
Old 22nd September 2023, 14:28   #62
rroy92's Avatar
Thanked: 228 Times
Originally Posted by Game_of_Roads View Post
The latest version of the app does not show up on Android Auto. I called their support. They sent me an updated apk that fixes the problem. They also state that they are waiting for Google to approve the fixed version.
Originally Posted by RaviCar View Post
Thanks for sharing. but the link shared there takes to an empty folder. can u share the apk itself.
This is the more up to date one shared by Treel Support
https://drive.google.com/drive/folde...WDLri6nyjqUWNj
ref post : https://www.team-bhp.com/forum/modif...ml#post5630015 (Treel (by JK Tyres) launches internal TPMS sensors with Bluetooth)
rroy92 is offline   (2) Thanks
Old 22nd September 2023, 15:12   #63
Thanked: 240 Times
Yes correct. As mentioned in the above post, the newer apk that fixes it (again) is here:
https://drive.google.com/drive/folde...Nj?usp=sharing
Requesting everyone using it to please write to JK Treel support to fix this for good in the Google Play Store official version. More the requests, I suspect they'll do it quicker.
I've also requested for the following feature to be added:
"Another feedback: Can you try to make the app work with the new Android Auto coolwalk interface in a smaller card on the side without occupying the whole screen ? This way navigation can be on the display in a bigger card and Treel TPMS display can also be there side by side in the smaller card ? This will be an awesome feature if you can look into it . I'm happy to provide more info if required and I'm sure all customers will benefit from it"
Game_of_Roads is offline   (3) Thanks
Old 25th September 2023, 13:16   #64
rroy92's Avatar
Thanked: 228 Times
I too can confirm that the play store one still doesn't but the new apk linked here works.
rroy92 is offline
Old 1st October 2023, 15:04   #65
mukeshgoel's Avatar
Thanked: 2,412 Times
Originally Posted by toiingg View Post
I opened the HUD (there are 4 small screws at the back), and pasted a small piece of double sided tape (5mm x 5mm) over the hole of the speaker.
Thanks. I did it and happy with the results.
mukeshgoel is offline
Old 1st October 2023, 15:22   #66
Red Liner's Avatar
Thanked: 19,174 Times
DM'ing you the link add I'm not sure if the policies here to share apks.
You are allowed to share the link in public as it helps hundreds of forum members and non members.
Red Liner is offline
Old 3rd October 2023, 15:27   #67
Thanked: 89 Times
Installed 5 sensors that I purchased from Kunal as recommended by @raptor_diwan.
Kunal provided the APK as above as well as his dealer code.
I got the sensors installed for 150 each along with 1000 for alignment and balancing.
So far it is perfectly accurate. AA works well.
Shrek8421 is offline
Old 8th November 2023, 09:43   #68
Hi Guys,
Anyone got a more recent APK for running the Treel TPMS on AA? The one shared here doesnt work for me.
TIA.
medalegend is offline
Old 8th November 2023, 10:47   #69
Red Liner's Avatar
Could you please post the APK here for the benefit of all members?
Old 6th December 2023, 12:59   #70
Thanked: 111 Times
I got the Treel TPMS sensors installed at MRF Fathima tyres, Avinashi Road, Coimbatore. As ususal, Mr. Pradeep was very helpful. Also the technicians here are very knowledgeable. Mr. Manoj, the chief technician, was very organised and professional in his approach. He explained each and every step to me, like how the sensors are fixed, how alignment is done and also about road force balancing. This is one of the few outlets in Coimbatore which has road force balancing. Got the complete work of fitting sensors, alignment, rotation and road force balancing done for Rs. 1200. Will definitely recommend this outlet. Hunter machines were used here. This will always be my go-to outlet.
And about the sensors, they are definitely worth the investment.
jna4cob is offline
Old 14th December 2023, 11:53   #71
Thanked: 111 Times
I have a query on configuring the max temperature, max and min tyre pressures warning limits. My recommended tyre pressure is 38 psi. What should be the max and min tyre pressure limits for warnings to be triggered? And also what should be the maximum temperature limit. Please help.
jna4cob is offline
Old 14th December 2023, 15:41   #72
Thanked: 89 Times
google drive link
Shrek8421 is offline   (1) Thanks
Old 15th December 2023, 18:12   #73
Thanked: 174 Times
I enquired the cost at a nearby shop, was told the following:
1. 750 per sensor with 2 year dealer warranty (bring back to same shop for replacement).
2. MRP (website has 35% discount) with 5 year company warranty. Dealer is not able to give the same.
Can someone confirm in case they have got the sensors at INR 750 or less, along with company warranty?
_____after posting______
Called another dealer, got quote of 3750 for 5 sensors, with GST bill and 5 year company warranty. Mods, feel free to delete this post if necessary.
SlowDough is offline
Old 15th December 2023, 18:31   #74
dass's Avatar
Thanked: 941 Times
I am unable to see this on AA on my June 2023 Harrier. Even after updating to the latest version based on the .apk provided in this group. Anyone else has managed to solve for this?
dass is offline
Old 28th January 2024, 18:33   #75
yogiii's Avatar
Thanked: 269 Times
Hey SlowDough,
Which one did you choose? Have you got it installed? I'm looking to get this done on my car in Delhi NCR and confused about pricing and installation.
yogiii is offline
