Old 28th May 2007, 16:25   #31
nikunj_cal's Avatar
Originally Posted by Epic View Post
Hi Nikunj,
Ive never heard of the 'Failsafe 175 4A' from Xenos. Are you sure that it is a Xenos product? Atleast the model number mentioned by you is not on their website, ofcourse unless its a new product from Xenos. Either ways, what are the features offered by the system you have installed?
Epic
Hi yes it is a Xenos product , cause the Guy who did the install had Xenos written all over his shirt , I have a small snap of a part of the box, i will upload it once i reach home ...
nikunj_cal is offline
Old 29th May 2007, 16:38   #32
gbpscars's Avatar
!!! duh !!! is that a great sense of humour or sense of consumerism?
gbpscars is offline
Old 30th May 2007, 09:35   #33
nikunj_cal's Avatar
Hi Nikunj,
Epic
Here you go :-
Old 30th May 2007, 10:53   #34
BUSA's Avatar
Thanked: 23 Times
I installed Autocop XS on my Swift VDi yesterday. Quite a good system IMHO, the doors lock as soon as the ignition is turned and unlock on turning the key off. There was reverse horn in the car with the system which i got disabled.
BUSA is offline
Old 30th May 2007, 10:59   #35
tsk1979's Avatar
Thanked: 23,481 Times
Some points which you need to consider.
You can get the best the most wonderful security system, and still have false alarms by dime a dozen.
The culprit is not your security system but the door light system.
Most security systems(Xenos, Vision, Autocop etc.,) tap on to the automatic door light system.
When you open your door a simple switch gets activated, which tells that the door is open. Over an extended period of time these switches get loose, and you have false alarms creeping in.
A good way to check this out is this.
Set the cabin light to the middle position, i.e. it glows when doors are open. Then drive over a very rough road.
Does it flicker?
If it does this means that one of your switch is faulty or loose.
It could be one of the 4 doors, the hatch, or the bonnet. Happy hunting.
Before you throw out your security system, check these switches, you may spend 5000 more and be struck with the same problem has before. As they say, the chain is as strong as its weakest link.
Hope this helps
tsk1979 is offline
Old 30th May 2007, 12:03   #36
nikunj_cal's Avatar
Does it flicker?
Hope this helps
Hey that is great advise , I will try out the same for my Old Indica today itself !!
Old 5th June 2007, 12:56   #37
adman77's Avatar
Go for Autocop. It's tried and tested. Better still, go for a Micro VBB if you have the dough.
adman77 is offline
Old 5th June 2007, 14:59   #38
shailu's Avatar
Thanked: 21 Times
go for Autocop....xenos service sucks
shailu is offline
Old 5th June 2007, 23:26   #39
kkdelhi's Avatar
Thanked: 19 Times
Would anyone care to advise if installing autocop or xenos on the Swift will invalidate the car's electrical warranty? Because I keep hearing that if you install any anti-theft other than the MGA Nippon, Maruti will not be responsible nor repair under warranty if the electrical system of the car fails.
But then...does it really matter if it invalidates the warranty? I mean, how costly could the parts of the system be even if it goes out of order (a big IF)?
kkdelhi is offline
Old 7th June 2007, 15:08   #40
Recently replaced by Minda with Xenos, based on feedback from this forum. Minda had a much better range than xenos, but was unable to get a model with immobiliser & sensors. (they didnt have stock). Tried evaluating autocop too, but have been reading too many failure stories about autocop. besides the remote looks a bit ugly..
Anyone knows where I could find a good gsm based car security / tracking device in Bangalore / Chennai?
looking for something like the one on Amsaki HomSafe Limited . Have been speaking to a lady at their delhi office, they dont have dealers in the south, and are least intersted in couriering the device across..
CARtik is offline
Old 13th June 2007, 13:48   #41
Thanked: 127 Times
Does anyone know the contact number for Xenos in Bangalore? Do hey send an engineer over to fix the kit?
TNAWAYAJ is offline
Old 13th June 2007, 17:48   #42
They're based at coimbatore. but they have their engineers in most of the good dealers. Got mine fitted at Radio Warehouse Chennai. Look for a dealer at Bangalore, and he should have a Xenos guy..
Xenos -Contact/Feedback
CARtik is offline
Old 14th June 2007, 01:36   #43
rohan_fonseca's Avatar
Thanked: 9 Times
Had used Autocop for a long time on 2 cars. Sensors started giving problems after a few years. A.S.S was good. Using xenos now without the sensors mainly as a central locking option. Got it fitted at the dealer itself so dunno wether its MGA. No major probs as yet just the occassional time a motor has a bad day. Opted for the xenos this time round as the remote looked better
rohan_fonseca is offline
Old 3rd September 2007, 17:31   #44
mobike008's Avatar
Thanked: 16,996 Times
Busa, how much this costed you? A friend of mine from Mumbai is looking for a security alarm system for his Fiat Petra, do you recommend this brand and model? Also, what is its price and where you got it from?
mobike008 is offline
Old 3rd September 2007, 17:45   #45
BUSA's Avatar
Thanked: 23 Times
Hey Mobike it costed me Rs. 3500/-
Yes i recommend the brand and model, its very nice and hs no problems so far, Gods grace.
I got it from Andheri(E) Guru Nanak Petrol Pump.
BUSA is offline
