Old 25th April 2007, 15:30   #1
ramki067's Avatar
Thanked: 36 Times
Adding a Tachometer to Alto!
I'm interested in adding a tachometer to Alto. I'm in Bangalore and any help regarding where to get it and fixed will be helpful.
Ramki.
ramki067 is offline
Old 25th April 2007, 15:42   #2
Knight Rider's Avatar
Thanked: 28 Times
Aha.......... Is it the 1.1 version with 4 cyl or 800 cc with 3 cyl??? Most of the popular tachos would support 4, I also tried,
A friend of mine has some type-r tacho in his car, Just for show that is, Does not work!!!
Anyways, Car shringar in J.C road, (new one) had autoguage (I think) with shiftlight and 7 colours, His last price was 5.5
Knight Rider is offline
Old 25th April 2007, 15:44   #3
nitrous's Avatar
Thanked: 332 Times
The basic 3-inch Pricol tachometer is available for 800 bucks.
And get one that is specifically for 3 cylinder engines.
nitrous is offline
Old 25th April 2007, 16:15   #4
ramki067's Avatar
Thanked: 36 Times
Its a 3 cylinder one.
ramki067 is offline
Old 25th April 2007, 17:00   #5
manikjeet's Avatar
Thanked: 296 Times
I am planning to add a tacho to my 800cc alto
i have problem sorces it in chandigarh so getting from dehli but can someone tell if any local mechanic can install it or it is difficult
i was told by friend abhibh that a pricol will cost around 900 buck at the most
manikjeet is offline
Old 25th April 2007, 17:03   #6
Thanked: 28 Times
Get an Autogauge or Autometer 3.5" tacho with shift light and fix it in the middle or in the extreme right of the dash.
My alto has one installed in the extreme right (Will update my garage with a pic of it).
Some models of tachometers come as switchable between 6-4-3 cylinders. These are available here in Cochin. So, it should be available there in bangy too.
speedzak is offline
Old 25th April 2007, 17:22   #7
manikjeet's Avatar
Thanked: 296 Times
what will be a rough cost of the tacho and are they available up north i mean in dehli in chandigarh i could find
but that i came across is for 12k its a normal tacho with a shift light
Old 25th April 2007, 17:32   #8
Thanked: 28 Times
The model number I saw in car shringar - 233906sw - 3 cyl 5" (Autoguage) and as I mentioned earlier, His last price was 5.5
Old 25th April 2007, 18:57   #9
Thanked: 28 Times
The one installed in my car is roughly around 3k. Yes, it is a 3.5incher which suits well for an Alto.
5 inchers are available here for around 6k.
12k is very high unless it is some very good make.
speedzak is offline
Old 25th April 2007, 20:37   #10
sbasak's Avatar
Thanked: 15 Times
Alto VX comes with a tacho fitted.
So, if you can get hold of that dashboard it shouldn't be a big problem.
sbasak is offline
Old 25th April 2007, 20:46   #11
manikjeet's Avatar
Thanked: 296 Times
yae and figure out a way of adding a 4 piston tacho to a 3 piston engine
correct me if i am wrong
Old 25th April 2007, 20:53   #12
sbasak's Avatar
Thanked: 15 Times
What does it depend on no. of pistons???
PS;
Looks like it can be done in several ways. Not always depending no. of pistons. No idea how Alto tacho works though!
Source: What is a Tachometer?
A tachometer used in this application can be built in multiple ways. It may be a small generator attached to the engine drive shaft, where the RPM measurement is scaled to the electric current generated by the device. Alternately, it may simply measure the rate at which the ignition system sends sparks to the engine.
sbasak is offline
Old 25th April 2007, 21:34   #13
manikjeet's Avatar
Thanked: 296 Times
hey sbasak you already have a vx why do yo need a tacho then
Old 25th April 2007, 22:16   #14
sbasak's Avatar
Thanked: 15 Times
Well, I never said that I want it for me
sbasak is offline
Old 25th April 2007, 22:45   #15
Well if you ever fabricate one, tap your ignition unit...the number of sparks as a function of time would give you the engine speed, as long as you calibrate it for a particular rpm(that I am not sure how you would do, for you would need a standard gauge like those handheld tachs to measure engine speed). Then of course fabricate a dial and a casing and all that. Well, that would keep you busy for a while ;-).
Sparkie is offline
