Old 28th June 2023, 23:02   #991
Thanked: 2,960 Times
Infractions: 0/1 (10)
Re: Tyre pressure gauge and portable inflator pump / foot pump
Bought TUSA TYRE INFLATOR
Tyre pressure gauge and portable inflator pump / foot pump-20230628_221437.jpg
Finally bought a Tusa inflator after searching, reading its reviews, and also watching some Youtube videos.
Initial Review after using 2 days
I inflated 4 tires of Mercedes, 4 tires of Compass, and 2 tires of RR310
Positives
1. Noise is on the lower side in comparison to other inflators.
2. It took 50 seconds to inflate my 225/45 R17 tire from 22 psi to 35 psi.
3. Very nice build quality, feels very premium.
4. Length of the cable is more than sufficient.
5.Backlit screen helps in Night.
Neutral
1. It takes 7- 10 seconds to measure the accurate tire pressure.
2. The torch power is low.
3. Cable length is good but the air pressure pipe length is short.
4. On one tire, I set the required tire pressure to 32 psi. So Tusa started to inflate it from 28 psi. Then it stopped at 32 psi but after a second it showed a tire pressure of 35 psi. ( So it is accurate 90% of the time)
5. Price is Rs 2900 which is on the higher side.
I heard that customer support is nice for Tusa products.
Inside the box, they give a card on which it is written to register the product online for 6 months warranty ( 6+6), plus they will ship a free magnetic phone holder once you share a screenshot of the Amazon review.
vattyboy is offline   (2) Thanks
Old 29th June 2023, 10:38   #992
HammerHead's Avatar
Thanked: 644 Times
Bought Qubo Smart Tyre Inflator PRO. Never owned/used a portable tyre Inflator before.
Used it on my BMW X3 and there seems to be a difference of 1 psi between tyre pressure displayed by BMW TPMS and what's set on tyre inflator.
Product is compact and well built. Looks great and works well. Comes with a good quality pouch. Did not notice 'heating' issues. Noise level is acceptable.
The only missing thing is a velcro cable strap to organize the cable and backlit switches.
HammerHead is offline
Old 1st July 2023, 19:36   #993
di1in's Avatar
Thanked: 286 Times
I bought the Qubo Inflator Pro, and noticed the pressure difference too on my tpms. Is it because of the little air that is lost when removing the inflator from the tire’s valve?
I’m using sensairy internal tpms, and they claim 1psi accuracy, so not sure if that’s what’s happening here either.
di1in is offline
Old 12th July 2023, 00:18   #994
impala's Avatar
Thanked: 545 Times
This actually confirms the hunch by which I chose not to buy Tusa. It's just another rebranded imported product which is striving by incentivised reviews. If it's a good non-private brand, they are likely to sell on other platforms too; Tusa doesn't. Whenever I see a card that offers an incentive for review in a package, I know I made a wrong choice. In this case, the price you paid included their cost of giving away the phone holder!
impala is online now   (10) Thanks
Old 3rd September 2023, 13:24   #995
wadewilson's Avatar
Thanked: 815 Times
Can dear members help me with my purchase decision? I need a tyre inflator for my XUV700 - I also ordered the MS Extender which should be arriving by tomorrow so no issues with the length (hopefully). I have used the following tyre inflators preciously:
  1. Michelin 12266 - Good but takes a while to fully inflate from 20 psi, probably due to its compact nature. I have used it on the Creta for a few years now.
  2. Windek - Don't know the model number. I purchased it for the Kwid in 2017 or thereabouts. Not the best build quality and it used to shut off after 2-3 minutes of usage sometimes. Gave it away.
Combing the thread as well as Amazon India, I came across a few tyre inflators but need help deciding which. I also would be more comfortable with a digital readout:
  1. VIAIR 85P - Priced around 7200 on Swastikfabs. It's a bit expensive and has an analogue display but considering the company's glowing reviews, I am tempted to get one. However, on specifications listed it mentions 0-30 PSI for R18 at 2 minutes 50 seconds. However, 0 to 30 would be in a rare scenario so I am okay with that.
  2. Michelin 12314 - Priced at 6841 rupees on Amazon. Around 9 reviews on Amazon but unsure of whether it would be better than the VIAIR. Mentions 0-35 PSI (unknown tyre size) at 1.30 minutes.
Would appreciate the help. I am not averse to trying out tyre inflators from other brands as well. Thank you everyone
wadewilson is offline
Old 3rd September 2023, 13:59   #996
PaddleShifter's Avatar
Thanked: 2,725 Times
Windek - Not the best build quality and it used to shut off after 2-3 minutes of usage sometimes.
VIAIR 85P - 0-30 PSI for R18 at 2 minutes 50 seconds. However, 0 to 30 would be in a rare scenario so I am okay with that.
Michelin 12314 - Mentions 0-35 PSI (unknown tyre size) at 1.30 minutes.
Checked the specifications of the two models you have listed. I hope you have seen the peak power draw from these two models.
1. XUV700 has a 12 volt socket in the third row that is rated at 120 watts as per the post linked below. Is this information still relevant and correct?
https://www.team-bhp.com/forum/offic...ml#post5128827 (Mahindra XUV700 Review)
2. I could not find the peak draw of the Michelin model but the Viair model has a peak current draw of 15A and is rated at 180W (1.5x the rated output in XUV700). Are you willing to use a higher power instrument in your car?
https://www.viaircorp.com/portables/85p/
I have two Burgmann Typhoon 150W inflators (peak current 15A) at my home and two of my colleagues also bought the same after seeing and experiencing mine. But, when I upgraded from Punto (had a 12v socket rated at 180W) to S-Cross (12V/120W), I had to buy a new tyre inflator. I have shared my experience below. It took 7 minutes to inflate a completely flat, 16” 215 section tyre to 33PSI.
https://www.team-bhp.com/forum/modif...ml#post5253745 (Tyre pressure gauge and portable inflator pump / foot pump)
A faster tyre inflator will draw more current and that is what limits their application as most cars these days have started providing a 12V socket with a rating of only 120W (against 180W in the last decade).
Recommendation: Since tyre inflators are mainly meant for top ups and pressure maintenance with a once in a while rescue on the highways in case of minor puncture so that the car is drivable to the nearest tyre shop, I’d say that you get a 120W model to be on the safer side. Moreover, cars now have TPMS so early warning mostly prevents a complete flat while on the road.
120W inflators that are commonly used by S-Cross owners in my circle:
1. Woscher 802D
2. Tusa tyre inflator
150W inflators used by my family members
1. Bergmann Typhoon
Tyre pressure gauge and portable inflator pump / foot pump-img_6270.jpeg
PaddleShifter is offline   (2) Thanks
Old 3rd September 2023, 15:12   #997
RoadFiend's Avatar
Thanked: 211 Times
I still use the VIAIR and it's so robust that I'd trust it any day over digital ones and their electronics which mayn't last long.
- I've to connect the VIAIR to battery terminals directly because of the high current draw. But then it fills up (even from fully flat) in a minute or two.
- In it's supplied pouch, it's quite small (I may have posted pics earlier in the thread).
- I've acquired an inexpensive digital meter separately, to check reading.
All the best for your search. Please do share what you buy and your experience with it
RoadFiend is offline   (1) Thanks
Old 26th September 2023, 17:19   #998
impala's Avatar
Thanked: 545 Times
Originally Posted by impala View Post
I finally bought another model of AstroAI inflator.
I could put it to proper test this weekend. I checked the pressure in the spare tyre of XUV700. It is a 155/90 R28 with 60psi rated pressure. It's at 30. Filling to 61 took 6min 30s which gave me good confidence that filling the normal tyres to the rated 32, even though larger would work when needed.
Old 20th January 2024, 23:57   #999
Thanked: 97 Times
After trying various low budget tyre Inflator, i bought "ResQTech Heavy Duty Digital Tyre Inflator" from Amazon. Since most of the petrol station tyre inflators are not calibrated always i was worried about accuracy. After using couple of times, i can say this inflator readings are accurate and built very well too.
rnaduthota is offline   (2) Thanks
Old 4th April 2024, 17:49   #1000
sapien's Avatar
Thanked: 359 Times
Seeking inputs from fellow members, looking to buy a tyre inflator for our XUV700 to be used in emergency situations only. For regular day to day use - I plan to fill Nitrogen and only in case of outstation trips etc might need to top up using the inflator. Some shortlisted options in no particular order :
Bergman Typhoon Analog
150W
Rs 2100
This seems like the best deal out there, has very good reviews and strong recommendations by BHPians.
Bergmann Striker Analog
120W
Rs 1597
XUV700 has 12V port hence, came across this while browsing Amazon and seems good value for money for emergency use.
Bargmann Vaccum + Inflator
few negative reviews
Rs 2200
Woscher Vaccum + Inflator
DC 12 V
has decent reviews
Rs 2300
The last 2 may not be as efficient as above inflator only products, but I get a vaccum cleaner as well - since this will be used on rare occasions to inflate, is it okay make a trade off w.r.t inflator quality and go for these. I'm inclined towards the Woscher Vaccum + Inflator, anyone who has used such products please help out a fellow mate. I'm open to consider other tyre inflators as well in similar budget. Thanks in advance.
sapien is offline
Old 5th April 2024, 01:58   #1001
Thad E Ginathom's Avatar
Thanked: 27,755 Times
Forget anything that you cannot plug into your car. When you are out there in the night with a flat tyre, you just need to pump some air into it, hoping it will hold until you can get it dealt with. Or, forget inflating, change the wheel for the spare which, with stuff like over-tightened wheel nuts, is a whole different trip.
Efficiency/power does not matter. If it takes you four minutes instead of three to inflate? It will get there in the end. I did recently inflate a tyre from flat. Actually, it was quite quick (and in the end we got the puncture guy to come to us anyway).
I have a TUSA Digital Tyre Inflator. I think it is a bit more expensive than the ones you mentioned. I bought it in October 21: I think it was recommended on this thread back then.
I still get air in petrol bunks (lazy!) but I do use this from time to time. It's good to know that emergency kit actually still works. And I absolutely keep it in the car.
Thad E Ginathom is online now   (3) Thanks
Old 5th April 2024, 08:57   #1002
sapien's Avatar
Thanked: 359 Times
Thanks Thad for your detailed response, all the 4 are pluggable in car socket. Any comparison w.r.t TUSA vs Bergman, please share.
sapien is offline   (1) Thanks
Old 5th April 2024, 22:14   #1003
Ahh, OK... Then all is good!
It's one of those things that I spent years getting around to buying. Partly because of the huge choice! So I do not have experience of any other model to measure against. In London I used to keep a humble foot pump in the car.
Thad E Ginathom is online now   (1) Thanks
Old 10th April 2024, 14:15   #1004
sapien's Avatar
Thanked: 359 Times
Originally Posted by northstar* View Post
I was also looking for an inflator for my XUV 700 and my biggest concern was making the inflator reach the front wheels as XUV got the port only in its book.
I finalised the TUSA Digital Car Tyre Inflator, which exactly reaches the front left wheel with ease.
How has been your experience with TUSA, I'm considering A6 model.
Originally Posted by GeeTee TSI View Post
I recently got a Michelin 12266 tyre inflator, my first portable one
Can you share how is it performing now, I'm considering for XUV700.
Originally Posted by turbospooler View Post
The Bergmann is well made (except its grab handle, which is plastic and feels flimsy) and the metal body is supported nicely with the rubber foot. They both have sufficient length of wiring but the hose of Bergmann has more length, which is super convenient if the valve is in the top position.
Any issues observed during the usage till now, please share.
Originally Posted by Kkumar View Post
I have been using a Michelin 12266 Tyre inflator for the last six months and have found it to be pretty handy.
Please share your experience - how's the performance been?
Originally Posted by wildsdi5530 View Post
People using the Michelin 12266 tyre inflator, I've been using one for the past 3 years mainly to fill up after fixing a puncture. I've had no issues with it yet.
However from day one the buttons to adjust the set pressure and to change PSI to Bar to .. don't work properly. In fact I had ordered on Amazon so after using the first time, I returned it for another piece. This also has the same issue.
Whats your review on Michelin one, is it holding up well ?
Is there a customer support number which you received, would like to try connecting with them before purchase. The website number is not reachable.
What did you finalize on, please share experience.
Whats the age of these now and how has been the performance?
Any thoughts on 85 vs 87 vs 88. 88P is the most powerful as per SwastikFabs.
Do you have a customer care number for TUSA, if yes - please share. Considering their A6 model due to 30 mins operation time.
Based on suggestions received here and some more digging, here's the latest on the tyre inflator search. Click on image for clearer text.
Tyre pressure gauge and portable inflator pump / foot pump-screenshot-20240410-1.22.59-pm.png
Now, considering features and reviews,
  • I feel TUSA A6 is best out of the lot, but I casually tried reaching out for warranty and the number(18003137375) not reachable, if anyone has purchased a TUSA product and has received a customer care number, please share - can try connecting to them.
  • Next, I looked at Michelin since its a well reputed brand, there's one review on Amazon which says this is the best product with all good quality stuff etc but warranty reviews are quite bad on Amazon so not sure. Also, max continuous operating time of 10 mins is not great.
  • Based on suggestion by BHPian Sommos, started looking at VIAIR 87P, and this turned out to be very reliable and powerful, just that it doesn't have auto stop etc features, also an analogue pressure guage. Not sure if I can fill bicycle tyres etc with this. But this comes as strongly recommended and sells in matured markets like US. When I called up SwastikFab they recommeded going for 88P as its more powerful and fills air quickly. The only negative point about VIAIR is high price. But, the person on call was super confident saying this is a lifetime product and he hasn't done a single replacement till date. Probably this will last much longer and hence cover up the price of 2 such inflators which I may end up buying in the same time period. I am strongly considering 87P/88P - how long does it take for 87P to fill a tyre from 20 psi to 33 psi ?
  • The Bergmann is still in the list as lot if BHPians have reviewed it and its the best value for money.
There's so much information and variety available for a simple device like Tyre Inflator, I'm going into Analysis-Paralysis mode
Old 10th April 2024, 14:23   #1005
turbospooler's Avatar
Thanked: 1,010 Times
None. My father loves this pump so much that he has made it a recurring Sunday activity to top up all the 2 wheelers and 4 wheelers tyres using this pump.
The price I paid for the inflator was INR 1880/- and I found the best deal on boodmo. So you may have to check a little before buying at INR 2700/-.
My model has an analogue gauge.
turbospooler is offline   (2) Thanks
