Old 15th July 2014, 14:04   #361
Red Liner's Avatar
Thanked: 19,156 Times
Re: Tyre pressure gauge and portable inflator pump / foot pump
Originally Posted by Traveller Nayak View Post
After lot of reading and exchanging emails with Emporis, I confess I am still unable to take a decision on which one to go for. Confusion has arisen because Emporis is 150 psi and Coido is 300 psi.
So hey there.
This is what I just got in the mail today: http://www.snapdeal.com/product/moto...flator/1337175
What I liked about this unit is:
1. It weighs a ton - it's all metal.
2. Its a double pump/cylinder unit. It's 150 PSI, but since its a double pump unit, the air will be pumped in faster.
3. It connects straight to the battery terminals using clip-on's which means its meant for heavy duty use. 12V socket cannot take the load. GOOD THING!
4. Got a few reviews which reinstate what I've mentioned above clearly.
Will try it this evening and see if it does its job. Comes in a neat little bag which keeps the whole thing packed tight.
Red Liner is offline
Old 17th July 2014, 00:46   #362
Thanked: 202 Times
Originally Posted by Red Liner View Post
So hey there.
Did you get a chance to try out the pump? I Googled on the brand and the company, it turns out they are based in Gurgaon. Near my office too. Depending on your feedback I will go to their office to get a first hand feel. I am also interested to know about the cable length.
Nayak // Sent from my iPad using Team-BHP
Traveller Nayak is offline
Old 26th July 2014, 17:47   #363
Max
Thanked: 99 Times
I am using Coido 6526 tyre inflator since last 2-3 months and its working fine. I bought it from ebay for around rs.800 for emergency use but have been using it since last few days for top up. The only problem i face is, it does not have on/off switch to have to manually take out power plug.
It takes about 1 minutes to pump 4-6psi in the tyre.
Tyre pressure gauge and portable inflator pump / foot pump-codio1.jpg
I also bought this manual Codio pressure gadget and its doing good job.
Tyre pressure gauge and portable inflator pump / foot pump-codio2.jpg
I hope this will help some one.
Max is offline
Old 26th July 2014, 18:49   #364
aditya.bhardwaj's Avatar
Thanked: 522 Times
Attachment 1266683
Attachment 1266684
Even I got the same coido inflator last week. Though I got it for Rs 550. It works really well. The main motive was to buy it for my leh trip so I would be using it on my motorcycle.
aditya.bhardwaj is offline
Old 26th July 2014, 20:16   #365
Red Liner's Avatar
This inflator is a win. Tried it out and works like a charm. Go get it!
Old 31st July 2014, 09:14   #366
sumeethaldankar's Avatar
Thanked: 3,660 Times
Guys i am looking for a double barreled foot pump to be kept for emergency use only. I am not inclined to buy a electric pump for several reasons.
1-Electric pumps are not known to be reliable.
2-I won't be using the pump daily for top ups but for emergencies only.
3-In a harsh weather situation like rains how is one suppose to use a electronic device without shorting out same is beyond me.
So any suggestions for a good foot pump from you guys.
Thanks.
sumeethaldankar is offline
Old 31st July 2014, 09:59   #367
sourav9385's Avatar
Thanked: 772 Times
Thanks.
Look no further. I've been using this for over two years now on my bike and car, and it has never let me down.
Comes with an analog gauge, which is fairly accurate.
Double barreled means top ups take just a few pumps.
I don't even go to filling stations anymore for air pressure checkup anymore. I maintain it myself, using this.
sourav9385 is offline   (2) Thanks
Old 31st July 2014, 11:36   #368
manim's Avatar
Thanked: 925 Times
Thanks.
I have been using foot-pump for many years for the same reasons you have mentioned.
Low-tech but reliable in an emergency.
Also an exercise for shedding a few kilos!
It works wonderfully.
After a few years the rubber seal gets worn out, which I replace.
Will try to post a photo of mine soon, It is an Indian make heavy-duty (single barrel) bought for around Rs.450.
manim is offline   (2) Thanks
Old 4th August 2014, 18:14   #369
manim's Avatar
Thanked: 925 Times
Foot-Pump
Here is my foot-pump.
Indian make, does a great job.
This particular piece is nearly six years old and is working fine still, bought it for Rs.450.
(had to change the rubber seal in the tip a couple of times).
I had a similar one before this for many years too.
The pressure-gauge is not reliable though.
I use a seperate gauge to measure the pressure.
I top-up after/before long drives, in the early mornings when the tyres are cold.
Is always in the boot of my car for any emergencies.
Tyre pressure gauge and portable inflator pump / foot pump-dsc_7691.jpg
Tyre pressure gauge and portable inflator pump / foot pump-dsc_7693.jpg
Tyre pressure gauge and portable inflator pump / foot pump-dsc_7692.jpg
manim is offline   (1) Thanks
Old 11th August 2014, 11:57   #370
Thanked: 214 Times
I like this double cylinder compressor. Thanks for posting this. How much does this actually weigh? And, does it come with different type of nozzle attachments for cycle tyres, foot ball, etc..?
Voyager-1 is offline   (1) Thanks
Old 11th August 2014, 11:59   #371
Red Liner's Avatar
It weighs quite a bit. All metal construction. I would say between 6 and 7.5 kilos. And yes, a few more nozzle attachments come with it.Out of the box, it connects straight to the tyres - so no worries there.
Red Liner is offline   (1) Thanks
Old 11th August 2014, 19:45   #372
joybhowmik's Avatar
Thanked: 2,581 Times
Wondering if there's any adaptor for the air compressors here - that can also fill up bicycle tyres? Can such an adaptor be purchased separately? And where?
joybhowmik is offline
Old 12th August 2014, 12:11   #373
Thanked: 346 Times
Most of these inflatrators come with 2 adapters. One for Bi-cycle and another for football/volleyball ... Not sure about buying it separately.
RaguHolla is offline
Old 12th August 2014, 12:15   #374
joybhowmik's Avatar
I too got the two adaptors like you mentioned... but unfortunately the hole for the bicycle adaptor is a little smaller than the outer dia of the bicycle tyre valve.
I tried expanding the adapter hole by inserting a screw - and turning it... but that did not help!
Old 12th August 2014, 13:17   #375
Thanked: 321 Times
I was using the generic Chinese pump but it was not at all reliable along with Michelin digital Tyre pressure gauge, was looking for buying pump from Michelin itself, they have very nice range of pumps(ebay UK have plenty of them) with auto cut but suddenly saw this cute, portable and useful pump which I can carry in my bike as well and picked up, it's on the way through USPS. Thanks to my friend Phani Kiran for shipping this to me.
http://www.motopumps.com
Ajaybiz is offline
