Originally Posted by hell_rider 1. can this simple fibre thing used to make doors and the boot as well ?? Can it be shaped exactly as the original doors ??? |
Well it should be possible but not sure if anybody's tried it. People make body kits in fibre but not sure about full body parts. I assume surface finishing might be an issue since it would not be as good or consistent as metal. Quote:
Originally Posted by hell_rider 2. any particular cons / disadvantges / problems with using this simple fibre for bonnets, doors and the boot ?? |
I don't think fibre has the rigidity or the strength to replace metal for body components. Plus again I'm not sure whether you'll be able to work out a consistent cavity for the door mechanism & window to go through into. Door pads will be another challange to get right. Quote:
Originally Posted by hell_rider I am asking this with respect to restoration work on older cars which are out of production now. So is this simple fibre thing a viable option ???? |
I think a better option would be to get the metal bits restored from a good body shop which is quite successful if the worker is skilled. But talk to some experts who are skilled in working on fibre, they might be able to help you out.
Here is a fibre bonnet I saw at the Speedrun, no idea why it was kept like this. My guess is that it was left unfinished for its lightness & overall weight reduction of the car.  |
