Old 25th November 2010, 17:51   #301
silversteed's Avatar
Thanked: 2,235 Times
Originally Posted by josejoseph View Post
silversteed, Ritz is 4 cylinder and M800 is 3 cylinder. I don't know if it suits.
My bad, I wanted to ask you about A-Star, but was reading a thread on Ritz in another tab
Anyway, thanks for the info. Let me see how I can get a suitable a tacho
silversteed is offline
Old 25th November 2010, 17:51   #302
josejoseph's Avatar
Thanked: 408 Times
Another hydraulic would need metalwork,i'd assume(holes etc.)
Why not try to source one from the zen/santro or the sort.I think the zen one is more robust.
The brackets/adaptors can be fabricated by a welder.
just a thought.
One of the BHP ians resolved this issue in his M800 by replacing the support with a different cars'. Unfortunately, he does not remember the make.
I'm going to try this with an Omni's support.
Fabricating the bracket/adapters will be the last option as no one is willing to do it.
Thanks,
Jose.
You can check eBay for suitable tachos. Remember to check that the tacho is suitable for 3 cylinder cars.
I'd consider my self lucky to get this tacho as I did not find any suitable to my liking or some were really expensive. The ones that were affordable had smaller dials or of unheard brand.
Thanks,
Jose.
Note from the Team-BHP Support Team : Please use "Multi Quote" option for quoting Multiple posts, instead of creating another back-to-back post.
Last edited by Technocrat : 1st December 2010 at 22:07. Reason: Please read the note in your post, thanks
josejoseph is offline
Old 27th November 2010, 12:13   #303
Thanked: 156 Times
Any one have installed heating facility parallel to AC?
This is the only problem with 800!
Is it possible to fit?
(Alok) is offline
Old 29th November 2010, 19:55   #304
krazydriver84's Avatar
Thanked: 44 Times
Hi Alok,
I have installed a heater unit in my car about 2 years back,
If you want a very good setup, be prepared to take the engine out, so that you get optimum results.
krazydriver84 is offline
Old 30th November 2010, 18:22   #305
Thanked: 43 Times
heater with a/c-working perfectly
ya i have got heater installed in my 2008 800 a/c.
COST=3500approx
parts=2800
labour=700
got it done from the dealer,takes around 2 hours,they remove the whole dashboard and fit this radiator near the blower,and a steel shutter to interchange between hot and cold air.
drjumbo is offline
Old 30th November 2010, 18:35   #306
johnruben's Avatar
Thanked: 85 Times
Hi Everyone,
yesterday one of my friend was suggesting me X-treme power from philips for my M800 as visibility during night and rainy days is too adequate.
I currently have 90/100 H4 Halogens, when i checked their site X-treme power is only 60/55, does it still provide more light than mine ?
philips website:
X-treme Power: Maximum performance
If any one has installed, please provide your feedback, thanks.
johnruben is offline
Old 30th November 2010, 21:10   #307
blackfire_9's Avatar
Thanked: 192 Times
^^ john, I have these on my car (alto). These are whiter compared to stock bulbs & hence appear brighter. Also their throw is more, but the one sore point is that they are not good enough in rains.
In fact, my experience was much better with the stock bulbs in rains.
blackfire_9 is offline   (1) Thanks
Old 1st December 2010, 19:40   #308
Thanked: 43 Times
hi john,
the only difference is that of color and hence wavelength,whiter lights feel brighter and more powerful because they spread more than stock ones,BUT they only spread more not PENETRATE MORE!! they are bad in fog and rain and especially when you have some other car with stock yellow lights coming from front you'll have your white lights crushed!!i have got philips crystal vision in mine,they definitely make the car look hotter,but u got to strain your eyes..best solution for looks with performance is HIDs.
drjumbo is offline   (1) Thanks
Old 1st December 2010, 21:23   #309
Thanked: 192 Times
Does anybody have any experience of HIDs in the stock headlight assembly in 800 or Alto?
Please suggest.
Drive safe.
Old 1st December 2010, 23:11   #310
Thanked: 100 Times
Please suggest.
Drive safe.
There is a place called Retro rides in Gurgaon (so called HID specialists)who quoted 12K for Philips HID set with projectors.They make a big hole in the reflector and bolt the projector assembly to the back of the headlight unit.
HID lamps w/o projector in a normal reflector headlamp assembly scatter the light even more, so much so, that while going through a street, you can make out the face of someone standing on the second floor, and at the same time have difficulty in seeing an object more than 20 metres away.
The cost of projectors, coupled with the drilling process, and non availability of Gyro has effectively stagnated the thought process.
JustCause is offline
Old 1st December 2010, 23:31   #311
johnruben's Avatar
Thanked: 85 Times
@drjumbo, @blackfire_9, @JustCause thanks for your reply.
I was about to purchase Philips Xtreme power, now that i know how it works in rainy nights, i better avoid it. Regarding HIDs, i dont want to spend so much for my M800.
I was wondering, how about upgrading to 100/130 Halogens itself ?
how much do they cost and are they available in H4 size for M800 ?
Will they be sufficient during Rainy Nights?
Also what will be the impact on battery?
Old 2nd December 2010, 12:52   #312
Thanked: 43 Times
its the projectors that are so expensive.moreover drilling holes and stuff would not be acceptable for all,JUST a HID kit is not that expensive,furthermore there are various power ranges in hid also like 8000k 10000k etc and there is certain permitted range by law,dont exactly know but i guess its 7000k or max 8000k,and xenos 10000k were for around 5000 bucks,that means the permitted range would be cheaper,,
drjumbo is offline
Old 2nd December 2010, 14:07   #313
Thanked: 43 Times
MY WHITE 800 on MATTE BLACK WHEELS..
hi guys!! here is my white 800 a/c 2008 with some subtle work,i was bored with nickle color so changed it to matte black
drjumbo is offline
Old 2nd December 2010, 20:34   #314
Thanked: 192 Times
Thanks for the response justcause, & it seems like a decent price for the HID kit + projector. One can try to reduce the price a bit though. Anyways, do you have any first hand experience or know of anybody who has gotten this job done from them? Do you have any plans of getting this done in your car?
Drive safe.
Old 3rd December 2010, 02:12   #315
johnruben's Avatar
Thanked: 85 Times
@drjumbo, i didnt know xenos sells HID kits, b/w your car looks awesome with new black look on tyres. the one before the last picture has a spoiler, how much did it cost you, it looks cute
Also tell me have you got HIDs or 100/130 halogens installed ?
