Old 17th June 2010, 13:53   #196
josejoseph's Avatar
Thanked: 408 Times
Auxiliary lamps
Hello All,
I'm planning to fix auxiliary lamps in my M800. Car is a 2001 model 5 speed. The car has 80/100w Osram H4 halogens which I feel is not good. Hence this decision. I'm thinking about Hella Comet 450 lamps.
What are the modifications I need to make for fixing these lamps? What about the wiring & relay parts? My car already has the head light booster, double horns, Autocop security system, stereo, etc.
Does fixing the extra lights affect the battery and other electrical units?
Thanks in advance.
- Jose.
josejoseph is offline
Old 17th June 2010, 19:47   #197
krazydriver84's Avatar
Thanked: 44 Times
hey jose
Just remember to put some heavy duty relays to distribute the power, or else the battery is gonna drain out due to excessive load.
krazydriver84 is offline
Old 17th June 2010, 23:34   #198
blackfire_9's Avatar
Thanked: 192 Times
Originally Posted by krazydriver84 View Post
@ Blackfire: yeah dude, got the car back and she is running in right now. Have got your PM, will call you soon. Tied up with a bit of work.
Hey mate, sure thing. Whenever you are free just give me a call. Glad that your car's back, enjoy the 'born again' spirit
Originally Posted by sureshshanmugam View Post
Hi, Have seen few M800s with Spacers that look a bit tall. What are the pros and cons of it.. Wish to have them on my M800 if they can improve handling and how much inches can i add to make it look descent? - Dont want my car to look odd.
Experts pls help.
Hey suresh,
The only pro as I see of adding a spacer is some addition to the looks & the ability to put on a bigger rim & tyres.
On th other hand, the con is undesirable effect on hndling which probably is not noticeable in city but is definitely visible on highways.
I would say that although people get spacers installed, it's more of an easy way out because the most ideal way is to get a new suspension setup, which can set you back by an amount starting & upwards of 40K.
Drive safe.
blackfire_9 is offline
Old 18th June 2010, 10:41   #199
sureshshanmugam's Avatar
Hi Mates,
My M800 5S has clocked 71,500 Kms and is due for Service.
All these years I was in Chennai and the car maintained by Electra..and now I moved to Cbe and i couldn't find a good Car care centre, so planning to service at a garage near my home.. a small one but could see imported cars coming there for work.
1. I am currently running on Castrol Magnatec.... shall I go with the same or is there any other good VFM oil tha tI can opt to?
2. I change Engine oil every 10K and my daily ride is 35Km in mild traffic with a normal 50-70KMPH speed. I dont Rev the engine at all :-) Is the frequency of oil change okay or should I do it even frequently?
3. This time I am planning to Change Transmission Oil, Brake Fluid and Coolant. How frequently should I change these?
4. Please recommend me a good Brand and Grade of Transmission Oil, Brake Fluid and Coolant for my M800 5Speed
5. I would like to Flush the engine / Transmission before refilling new oil.. Please recommend a good Brand.
4. How Could I know if the Brake shoes are due to change?
5. I have never changed the Timings Belt since I bought the car in 2002. Shall I cahnge it now?
6. Planning to Change the Water pump Belt also as it ws changed 20K Kms back
7. I rember once changing the tie-rod end and Ball joints
8. Apart from the above will be doing Front wheel Balancing and Alignment- mine are Aura Alloys on 145/80 R12 BridgeStone Turanza
Experts considering the above scenario please let me know if I am missing something as part of my maintenance.
Its my long-time wish to fix a tacho, rear-wiper and washer, Strut Braces and remote Lid opener.... but not finding someone mechanic who has the passion to do it for me.....
If anybody has done these.. please share...
sureshshanmugam is offline
Old 19th June 2010, 05:48   #200
sunilchakola's Avatar
@Kingofmyworld, nice ride with you. Love the Alloy & Tyres - beutifully maintained...
sunilchakola is offline
Old 19th June 2010, 21:13   #201
kingofmyworld's Avatar
Thanked: 537 Times
@sunil : Thank you.
I remember someone asking about bosch wiper for M800 earlier in this thread. I got bosch wiper today for my M800, Both are 17" ones and they cost 400 a pair. And they work like a charm as everybody knows.
kingofmyworld is offline
Old 19th June 2010, 21:40   #202
josejoseph's Avatar
Thanked: 408 Times
Originally Posted by kingofmyworld View Post
@sunil : Thank you.
Kingofmyworld, I think the price is high because an year ago I bought Bosch wipers for my M800 for Rs. 210/-.
After an year of usage I feel they are no better than other brands. They don't wipe clear and also produce lot of squeaking sound. For this monsoon I'm going to try some other brand.
The same thing happened with my friends WagonR. Last year he too changed to Bosch wipers as I had highly recommended him. But now they don't wipe well making visibility poor .
- Jose.
Old 20th June 2010, 00:15   #203
Thanked: 537 Times
@jose : Last night I was out and it was raining heavily, My wipers were 2years old and they were bad. they use to make odd sounds, On top of that I have 20% visibility tints on my windshield so it was a tough time to avoid potholes and speedbrakers. So today I changed to bosch. Just came home and they were working all good.
The reason for choosing Bosch was that every wiper I tried worked not more than 1 and a half year, But bosch wipers on my swift worked for around 3 years and they worked great all the time.
Old 20th June 2010, 03:11   #204
Thanked: 132 Times
Hi Mates,
The answer to your questions are :
1. More than the oil its the grade of oil that matters. The maruti genuine oil is api sf rated which is obsolete. look here for current grades.
Motor Oil Grades and Service Ratings
the api sm grade is the current one and the latest grade always protects your engine better, although do be warned that there is an exception to this rule, for older pushrod engines like that of the premier padmini, the lower ZDDP levels in sm grade oil can result in cam wear, but for the 800 api sm is best.
So do read what the api rating of the oil you are buying is. the higher the better.
2: Well you can never change the engine oil too soon. the more often you change it the more your engine will last, neverthe less 10,000 kms or one year (which ever is earlier) is the recomended oil change interval for the 800 and is sufficient you dont need to change oil any sooner but dont change it any later either.(here too the oil ratings matter. Back in the 90's when oil grades inferior to api sf were available, the company's recomendations were:- 5000 kms for api sc
10000 kms for api sf
3: transmission oil should be changed every 20,000 kms or every 2 years, which ever is earlier. for brake oil its 40,000kms or 4 years (whichever is earlier)but about coolant i am not sure but 40,000kms is a safe range.
4:About brands i would say its a competitive market so amoungst the major brands there is not much difference in quality and the difference really wont matter to you since you arent into motorsports, that slight difference that exist matters there. But the cheaper brands usually have a lower api rating and thats the reason why they are cheaper.I used delphi's ready to use (already mixed with water in the right proportion) coolant, 2 litres set me back by 180 bucks. For break fluid you can use kbx. i used hp's gear oil on the last change.
NOTE: Do monitor dipsticks every week for engine and transmission oil and the levels of coolant and break fluid reservoirs every week. If something does go wrong with your car and it starts to leak any of these fluids, in most cases people find out only when their engine seizes , transmission is ruined or the breaks fail even though the warning lights for engine oil, brakes and waer temp do exist. transmission has no warning light that i know of
Also do maintain the fluid levels close t maximum but no more than the max level. more the oil in the engine, cleaner oil is available to the engine for longer since it takes longer to dirty more oil. BMW used this trick on their diesel engines to increase the service interval from 5000 to 10000 kms , they just increased the sump size and therefore the amount of oil you put in.
5: i have opened a 4 stroke engine and transmission myself and let me tell you that in a petrol engine there is absolutely no need to use engine flush as long as you are changeing oil on time. the oils contain detergents and agents that keep the dirt in suspension in the fluid , these agents break down over time. So as long as you change the oil on time there wont be a hint of carbon on most parts inside the engine. Engine flush is useful only when you have been negligent previously even then just changing the oil at a lot shorter time intervals once or twice say at 3000-5000 will give better results than using engine flush.
Also dont forget to drive the car a little, right before the change so that the dirt that has settled down gets suspended in the oil and isnt left behind in the engine and transmission.
6: well , you can only tell if the brake pads are worn by taking off the wheel and checking how much of of the pad is still left for disk brakes and for drums you have to open them and see, but as long as you change the shoes in the drums along with the disks, you shouldnt have a problem since the ones in the drums usually wear out slower than the disks. Its best not to wait for the metal grinding with metal stage and judge by the sound and reduced braking. inspection should be done around 40,000 kms.
7: Timing belt you should change every 1 lakh kms or every 10 years.
8: visual inspection of the waterpump belt is sufficient, if there are cracks on it or the v grooves are excessively worn change it and tension is also something that shouldnt be ignored.
9: tie rods and ball joint repacement differs from person to person and depends on the road conditions. Though its not hard to tell when they need a change. If your steering develops even the slightest of play or the tak-tak sound on moving it left to right and back left ,get it checked.
10:wheel alignment and balancing should be done evry time you get it serviced or every alternate time if the road conditions in which you drive are exceptionally good and there are no vibrations or pulling toward any side.
Also rotate the tyre ever 5000 kms to prolong their life.
Well you didnt mention tuning of the car, valve gaps(tappet adjustment), timing , other electrical setting of the distributor(that is if your car has one, i really dont remember if the 5 speed 800 does) for carb cars also the air fuel mixture
Also get the injectors cleaned when you notice asignificant drop in milage and performance. i used to get it done at every 40,000 but refer to your manual for the exact interval since i am not sure about this.
Besides the tacho and strut braces, id suggest you stay away from other mods as i have never come accross any mechanic in india who can do these mods the correct way. it will most certainly look like a jugaad. places like autopsyche autopsyche or pandit and company do have the know how to carry out these mods the right way but they wouldnt do it mostly because there isnt much scope for profit compared to the effort these mods will take, so drop the idea.
mycarhasablower is offline   (1) Thanks
Old 20th June 2010, 05:32   #205
harishnayak's Avatar
Thanked: 125 Times
Even i personally feel that Bosch wipers are as good as any other wipers available , i think it's only the name that they're trying to sell IMO.
harishnayak is offline
Old 20th June 2010, 08:59   #206
Thanks for the excellent info mycarhasablower.
Will keep the thread updated when I take the car for service next week.
Old 21st June 2010, 11:22   #207
dr.faramroze's Avatar
Thanked: 13 Times
I got a 2003 5S last week, there is a whinning sound comming from the timing assembly. The water pump, alternator belt tension and alternator bearings are working fine. The sound mostly comes during idling. The odo reads 26k kms. Taking into consideration, the timing belt replacement, if faulty, does it imply the car has run more than 1 lac kms? The car otherwise is stock and most parts are having original date of manufacture 2003 on them. It also gives me 18+ on highway and 13+ in city. Will K&N conical alongwith MSD ignition module (not ignition coil) help in get more out of the car?
dr.faramroze is offline
Old 21st June 2010, 15:52   #208
K&N on M8800
Hi All
Need Advice on fitting a round tapered(cone filter) on my m800 carb need too know if it is advisible, if not what is the other option for performance improvement.
PowerPort is offline
Old 21st June 2010, 19:23   #209
Originally Posted by PowerPort View Post
Hi All
Hi Powerport,
K&N doesn't make any moticeable improvement in an M800 and it doesn't meet the cost benefit when compared to the OE Filter in costwise. Its better to stick with OE and go for periodical replacement.
Old 22nd June 2010, 13:46   #210
Hi Powerport,
suresh i'd beg to differ. i have the stock replacement k&n in my 5 speed and the response of the engine thereafter has a marked improvement. Fact is that i did this for the track days and the cars breathing characteristics are vastly improved
manek is offline
