Old 8th September 2019, 11:28   #31
graaja's Avatar
Thanked: 25,613 Times
Re: BMW Advanced Car Eye 2.0! Radar-based in-car surveillance system to catch vandals
Originally Posted by el lobo 6061 View Post
Recently got Advance Car Eye 2.0 installed in my X1.
What is the maximum memory size MicroSD we can install in it?
Came with a 32 GB card which can only do a recording of 2.5 Hrs.
So want to upgrade to maximum supported to enable longer duration of recording.
I have the previous generation Car Eye and that has a max of 64GB, if I remember correctly. Not sure about the 2.0 version.
From nigr's post, looks like you can go upto 128GB.
The one disadvantage I found with the Car Eye is that it automatically sets partitions to store normal recordings, recordings for the camera after ignition is turned off and recordings based on the g-sensor. The partition assigned to the normal recording is the smallest.
graaja is online now
Old 8th September 2019, 14:30   #32
Thanked: 21 Times
20190404_180430DE.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 150 MiB
Duration : 1mn 0s
Overall bit rate : 21.0 Mbps
IsTruncated : Yes
Video #1
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : 2 Ref Frames
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=15
Codec ID : H264
Duration : 1mn 0s
Bit rate : 10.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.161
Stream size : 71.6 MiB (48%)
Video #2
Format : AVC
Codec ID : H264
Duration : 1mn 0s
Bit rate : 7 585 Kbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.122
Stream size : 54.2 MiB (36%)
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : 1
Duration : 59s 998ms
Bit rate mode : Constant
Bit rate : 705.6 Kbps
Channel(s) : 2 channels
Sampling rate : 22.05 KHz
Bit depth : 16 bits
Stream size : 5.05 MiB (3%)
Alignment : Aligned on interleaves
Interleave, duration : 25 ms (0.75 video frame)
I gotta add though, I think the dashcam doesn’t particularly have a liking towards cards other than whichever company’s measely 32GB card it comes bundled with. I’ve had the data get corrupted on the 64GB card that I had in it before, once.
Last edited by Gannu_1 : 8th September 2019 at 16:09. Reason: Back to back posts merged. Please edit your first post and add content if re-posting within 30 mins. Thanks.
nigr is offline
Old 8th September 2019, 17:38   #33
el lobo 6061's Avatar
Thanked: 2,400 Times
Originally Posted by nigr View Post
I have a Samsung 128GB in there, not sure if it supports any larger than that
Thanks for the quick response. Also asked same query to BMW India to confirm if I can go for higher than this. If not, will plugin 128 GB.
As per the manual for Advanced Car Eye 2.0 following is the ratio for 32 GB card:
Parking Mode (20%) 39 minutes
Driving Mode (78%) 156 minutes
Images (2%) 100 Images
If I install a 128 GB card or higher, I can get close to 10 Hours of driving video, which is more than sufficient.
I would recommend every BMW owner to install it
1. BMW approved product. No affect on warranty
2. Clean install. No wiring mess.
Given how people drive these days, dashcam is a must have.
el lobo 6061 is offline   (3) Thanks
Old 8th September 2019, 17:45   #34
Thanked: 21 Times
A dashcam is an absolute must. I was hit by a Baleno driver and he sped off. Thankfully I was able to grab the RC details and raise a complaint at the Police Station and show them the video evidence.
Now coming to this dashcam, the quality is piss poor. I have a ₹3.5K worth dashcam from Xiaomi’s 70mai division and it makes ACE2’s video look like it was shot on a potato, especially in the night. The sensor and the resolution on the Xiaomi is much better. I wish BMW worked on improving the software and hardware integration, it’s almost impossible to grab Number Plates if you have LED headlights.
Could you share a photo of the rear dashcam’s placement?
nigr is offline
Old 8th September 2019, 18:15   #35
Will click a pic tomorrow morning in daylight and share.
el lobo 6061 is offline   (1) Thanks
Old 9th September 2019, 14:23   #36
Front:
BMW Advanced Car Eye 2.0! Radar-based in-car surveillance system to catch vandals-ace-2.0-front.jpeg
Rear:
BMW Advanced Car Eye 2.0! Radar-based in-car surveillance system to catch vandals-ace-2.0-rear.jpeg
Old 9th September 2019, 15:28   #37
bottle's Avatar
Thanked: 293 Times
Does the rear cam obstruct the rear view mirror ? Not possible to install it to the side ?
bottle is online now
Old 9th September 2019, 16:34   #38
Thanked: 21 Times
Rear:
Ah, you don’t have the rear roller blinds, so it’s easy like that.
Depends, it kinda does if the rear window is narrow. I have it installed to the side because of the roller blind.
nigr is offline
Old 9th September 2019, 23:47   #39
Since its installed at the very top, obstruction is negligible.
Installing in the center gives better coverage & field of vision.
Old 6th October 2019, 10:11   #40
Thanked: 79 Times
I am planning to go ahead and get the Advanced car eye 2.0 for my 320d. The software bugs seem bad but the BMW integration seems worth it. It seems to be available for much less in the US (380 dollars). If I pick it up from there, will BMW still install it and the warranty status be unaffected
nirvanaguy19 is offline
Old 6th October 2019, 11:46   #41
Turbanator's Avatar
Thanked: 31,925 Times
They will do but in my opinion not worth the efforts given the low difference. Instead negotiate locally. If you do not need overnight parking surveillance, you can buy anything from market and connect to 12 V lighter output at the start of trip. I have got one wired (front and back both) and simply plug when I leave from home. Will post pictures in few days.
Turbanator is online now   (2) Thanks
Old 8th October 2019, 17:24   #42
d3mon's Avatar
Thanked: 4,823 Times
Hi Turbanator,
Why do you feel the need to unplug from the 12V socket? It is turned off automatically after a couple of minutes, and only gets powered again when the car is unlocked. Hence, any dashcam will work perfectly with it permanently plugged into the 12V socket. At least that's the case with my F30.
d3mon is offline   (1) Thanks
Old 8th October 2019, 17:50   #43
Turbanator's Avatar
Thanks for the tip, honestly, I am a little afraid of things going wrong on the newer 7. It's a far more complicated car than anything else that I have owned. Even though the hard wiring that came with the device was fully compatible and Dealership could have done it for me if I were to agree on foregoing warranty of the affected parts in case of any issues.
Will try leaving it and update if something crops up.
Old 12th December 2019, 05:02   #44
Thanked: 319 Times
Installed this last month on the X1. OEM finish, video quality is good too. The best part being there’s no need to tap any fuse or cut wires. The harness provided takes power from auto headlight/rain sensor module.
BMW Advanced Car Eye 2.0! Radar-based in-car surveillance system to catch vandals-74e25a1ca1d84e9a80f39bf2156ae9d5.jpeg
BMW Advanced Car Eye 2.0! Radar-based in-car surveillance system to catch vandals-3d69c25275344d6d9b7c19aa950f9bef.jpeg
adi58 is offline   (2) Thanks
Old 12th December 2019, 09:48   #45
Thanked: 27,219 Times
Infractions: 0/3 (13)
Is it possible to install this or similar in a BMW Mini Cooper too?
Any inputs would be greatly valued.
Thanks!
shankar.balan is offline
