Old 31st May 2021, 11:56   #331
neil.jericho's Avatar
Thanked: 21,050 Times
Re: Comprehensive guide to LED Headlight upgrades
Originally Posted by dieselburner View Post
Can anyone guide on how good are Nighteye LED's.
I want to change the head light halogens in my TUV300 to LED's. Have seen some reviews on Youtube about Nighteye LED but still have doubts.
If anyone has changed headlights in TUV to LED's pls share your insights.
Thanks.
I have the Nighteye LEDs on my Triumph Street Triple motorcycle. I am currently running it on one side only, the other sided is a halogen bulb. For the LED side, the low beam output is pretty good but there is no proper cutoff. The high beam is just a taller low beam and is not focussed at all.
For the bike that I have, the Nighteye LEDs are the best bet for the shape of the reflector and output. Several other Triumph owners are running with Nighteye LEDs in both headlights and they are very happy.
I would suggest that you try and find TUV 300 owners from the Facebook group or Whatsapp group who have Nighteye LEDs installed. For all you know, Nighteyes may not be a good bet for the reflectors of the TUV but some other brand might be.
neil.jericho is offline
Old 10th June 2021, 22:45   #332
supertinu's Avatar
Thanked: 1,368 Times
Nighteyes are not good enough for headlights. They are low output led lights suitable generally only for fog lights.
For headlights you need high output led lights (with fan). The Osram Led headlight bulbs are pretty good, but they are Cool White.
https://www.amazon.in/dp/B08L8W7GBZ/...164FW28N34DN50
Have you tried the Osram ones? how does the beam pattern form. Pricing wise it seems good since high quality brand vs. the chinese options. Philips i find overpriced.
supertinu is offline
Old 5th July 2021, 13:14   #333
Any options for led headlights in H4 base with a colour temperature of 4300k, AliExpress is closed now, bangood doesn't have many options.. stockists in india seem to be hosting only 6000k colour temperature ones..
Sudhamshu is offline
Old 22nd August 2021, 22:02   #334
Thanked: 13 Times
All,
Can you please suggest a good LED lighting (white) configuration to replace the stock projector lamps in a new SKODA Rapid? Should we get separate bulbs for high beam and low beam?
blrboy is offline
Old 26th August 2021, 16:47   #335
IshaanIan's Avatar
Thanked: 7,709 Times
Infractions: 0/1 (7)
Folks please advise me on what headlamp upgrades I can make to my 2004 WagonR. Mom finds the stock lighting inadequate and I felt like since aftermarket lighting technology has advanced nearly two decades, there ought to be a simple yet effective solution out there. Unfortunately I have no experience in understanding which lights behave well in reflector setups, whether I ideally ought to get projectors, which projectors are suited to LEDs etc. Advise from more experienced members will be much appreciated.
Thanks in advance.
IshaanIan is offline
Old 26th August 2021, 17:18   #336
ashis89's Avatar
Thanked: 12,148 Times
Thanks in advance.
The simple and most effective upgrade would be adding 100/90W bulbs along with a pair of relays. That lights up the road ahead and sufficient for highway drives.
Before that, since you mentioned 2004 WagonR, can you check the state of the current bulbs? If they're old/fogged, then a new pair of 60/55 stock bulbs might be enough regular city use.
ashis89 is offline   (1) Thanks
Old 26th August 2021, 17:29   #337
amvj's Avatar
Thanked: 2,439 Times
Can I change my stock fog lamp bulbs on Baleno to LED? I find the headlight is not adequate when it rains. I read somewhere that LED bulbs should not be used for reflectors that are designed for halogen bulbs.
Any recommendations for wattage and will this fit / suitable?
Let me know if you have any other suggestions.
https://www.amazon.in/dp/B07Q7NR55H/...EZEI09BI&psc=1
amvj is offline
Old 26th August 2021, 18:02   #338
Kosfactor's Avatar
Thanked: 11,204 Times
Your headlamp is perhaps inadequate, an upgrade with suitable projector retrofit , designed specifically for either LED \ HID should be able to fix the problem.
LED replacement bulbs are rather useless inside a halogen reflector housing, people do it anyways.
Kosfactor is offline
Old 26th August 2021, 18:08   #339
amvj's Avatar
My car's headlights are HID and not halogen. Do you suggest any bulb upgrade for this setup ?
It is the fog lamp bulb which I wants to change or shall I go for LED bar something like this.
https://www.amazon.in/PRIKNIK-Drivin...9981304&sr=8-9
amvj is offline
Old 26th August 2021, 20:44   #340
IshaanIan's Avatar
Did run on these for a while but I'm looking for a more comprehensive lighting upgrade.
I am basically looking for the best if not close to the best possible solution out there.
Old 26th August 2021, 20:53   #341
archat68's Avatar
Thanked: 642 Times
Then the best way would be to install a hid with projector fog lamp. Choose 4300k colour temp. Should cost you around 6.5 K max. You can look for seller Blaze India. This will be the best upgrade. Leds are mostly bling factor, may work well in city road on normal condition but useless in rain, fog.
archat68 is offline   (1) Thanks
Old 26th August 2021, 21:39   #342
Thanked: 21,450 Times
LED's in reflector setup will be even poor in terms of light output. Please avoid that route as it will do more harm than good both in terms of light output and glare for the oncoming road users.
For best results get 100/90W with a relay in the headlights and replace the OEM fog lamps with HID projectors (₹6000-₹7500). I can't think of any other way to improve the lighting setup.
Old 27th August 2021, 00:18   #343
Kosfactor's Avatar
HID already in the headlamp means best to leave that bit alone.
You could add a projector set up where the fog lamp is currently but you would lose the fog lamp in the process. Hope you have tried moving the headlamp leveler to 3/4 during the rain to move the beam closer to the front of the vehicle. That is a work around.
Avoid light bars, they are flood lighting , will cause unwanted attention on the road.
Kosfactor is offline   (1) Thanks
Old 27th August 2021, 09:09   #344
Thanked: 323 Times
Cross posting my query from another topic here. Incase of any errors please correct
https://www.team-bhp.com/forum/modif...ml#post5131725 (Auto Lighting thread : Post all queries about automobile lighting here)
Looking forward to update the headlights. The total budget I am looking at is around 10000/- (preferably branded ones).
Safari storme has low beam in projectors and high beam in reflectors. I would prefer a near whitish output. I did go through all the pages in this topic and came to a conclusion to keep the range in 4000K to 5000K.
Also would like to upgrade the fog lamps which are H3.
So what would be the options that I can have. Would prefer plug and play options since I am based out of a location with limited help.
jacobsam is offline
Old 2nd September 2021, 19:06   #345
greyhound82's Avatar
Thanked: 1,693 Times
I’m my Harrier XZA+ the stock light is HID projector , but find it insufficient for night driving on roads without street lights. Kindly let me know what are my options to increase the throw.
greyhound82 is offline
