Old 29th April 2010, 14:53   #46
Mr.Bangalore's Avatar
Thanked: 56 Times
@recshenoy, i would say a big NO for that mod.
check out your self, comments from the expert.
http://www.team-bhp.com/forum/modifi...bs-innova.html
http://www.team-bhp.com/forum/modifi...swift-vdi.html
http://www.team-bhp.com/forum/modifi...n-1-6-nxt.html
Mr.Bangalore is offline
Old 29th April 2010, 16:41   #47
rjstyles69's Avatar
Thanked: 845 Times
Originally Posted by recshenoy View Post
Guys,
Sorry to re-open the old post. Could not find and appropriate thread! Any pointer for after market ABS/disc brake in Bangalore?
One of my friends wants to upgrade his rear brakes to disc and if possible add ABS! I know its pretty expensive affair with risk of unreliability!
Upgrading to disc brakes at the rear is quite achievable but adding an ABS is just next to impossible .Simple reason that the ECU wouldn't support it. BTW what car is your friend talking about ?
I think Jesal had converted his zen's rear brakes to a disc setup after an engine swap. You might want to check with him.
rjstyles69 is offline
Old 30th April 2010, 08:36   #48
recshenoy's Avatar
Thanked: 256 Times
Sorry guys forgot to name the car. Its a Hyundai Accent!
Yes. Even i had advised same to him. Not to try these after market option!
Being a petrol head and electronic heart guy, moment he told about ABS i thought "will ABS be supported by existing ECU" Also the reliablity if done after market!
Many thanks for replies
recshenoy is offline
Old 30th April 2010, 20:40   #49
blackasta's Avatar
Thanked: 2,928 Times
Can a car with existing ABS and front discs-rear drum setting be converted to all disc?
The car here in question is my i10.
blackasta is offline
Old 19th December 2012, 09:16   #50
Thanked: 87 Times
Re: Drum brakes to Disc
Bumping up an old thread
What would be the implications of changing the rear drums with disc brakes using OEM parts?
The car under consieration is Verna 1.5 CRDi SX (non-ABS). Verna 1.5 CRDi SX also came with the abs version with rear discs.
So, can the rear drums be safely changed to discs at the authorized servcie center?
Any chances of wheel locking by converting to rear discs (no ABS)
styx71 is offline
Old 21st December 2012, 19:38   #51
Thanked: 87 Times
^^ Answering my own question.
It is possible, more info here(need to go through most of the discussion):
http://www.hyundai-forums.com/184-mc...onversion.html
In fact some of the earlier generation cars came with all 4 disc brakes without ABS:
http://honda-tech.com/showthread.php?t=579786
styx71 is offline
Old 17th March 2013, 23:46   #52
Thanked: 24 Times
Changing drum brakes to disc brakes?
Dear Sirs,
Most low to medium priced cars in India come fitted with front disc brakes and rear drum brakes combination. However some expensive imported cars have all wheels disc brakes.
Is it possible to change the rear brakes too into disc brakes ? What are the benefits, disadvantages and costs in India ? Are there certain specifications and legal aspects?
Warm regards.
SSanyal
sanyal779 is offline
Old 18th March 2013, 01:04   #53
Thanked: 767 Times
Re: Changing drum brakes to disc brakes?
Technically switching from drums to discs is definitely possible. The issue is quality of work and cost. Accept that barring a few specialists, most people will not be able to get anything close to factory finish. Considering it is the brakes we are talking about, do you really want to get it changed. A botched job and your life is potentially at risk.
Additionally be aware that unless the job is done by an A$$, and even then, they would probably void any warranty. Assuming the warranty period is not an issue, it may become an issue with insurance refusing to pay in the case of an accident.
All said and done not really worth the headache of getting it done.
pganapathy is offline   (1) Thanks
Old 18th March 2013, 08:47   #54
sagarpadaki's Avatar
Thanked: 6,795 Times
Originally Posted by sanyal779 View Post
Dear Sirs,
Warm regards.
SSanyal
Let me tell you, even with all four discs , 80% of the braking is done by the front brakes. So disc or drum at the rear does not matter unless the car is fitted with ABS+EBD. And all the cars which have the mentioned combo have all 4 discs. So retrofitting is no use. Keep the drums in top shape and you are good enough
sagarpadaki is offline   (2) Thanks
Old 18th March 2013, 12:19   #55
joybhowmik's Avatar
Thanked: 2,582 Times
Dear Sirs,
Warm regards.
SSanyal
Altering the brake system would require you to inform the RTO of the update, and require a fitness to be done. Please bear this in mind.
joybhowmik is offline   (1) Thanks
