Old 17th March 2023, 21:56   #271
BoneCollector's Avatar
Thanked: 11,353 Times
Re: SensAiry : An app-based TPMS
Originally Posted by JoaTMoN View Post
How did you manage to connect yours?
For the app to work on Android Auto, you need to ask them for the apk file and not use the one available on Playstore. For Treel, the app on Playstore works with Android Auto.
BoneCollector is offline   (2) Thanks
Old 18th March 2023, 04:40   #272
Thanked: 268 Times
Some pretty confusing answers there. One says yes, one says no, and the brand says it might not. And this is the most recent answer I could find there.
SensAiry : An app-based TPMS-screenshot_20230318_043346_amazon.png
JoaTMoN is offline
Old 18th March 2023, 06:18   #273
The question itself is confusing. The app from Playstore has compatibility issues with Android Auto but apk file works. So any car that has Android Auto, Sensairy will work if you use the apk file supplied by the company. Same thing may not be true with the Android systems available in market. So the seller is correct in saying that it may or may not work with Android systems. But as far as the Android Auto is concerned, it works. Check the earlier posts of this thread, you'll get your answer.
BoneCollector is offline   (1) Thanks
Old 18th March 2023, 13:38   #274
ssadwelkar's Avatar
Thanked: 97 Times
In one of the queries on Amazon, they have said that their device doesn't connect to Android Car Players because the Bluetooth connectivity of these players are too weak to pick up the signals from tpms. How did you manage to connect yours?
The sensors are first connected to the Sensairy app on the Android or IOS device which in turn is connected by phone USB cable to the car system, as soon as Android Auto comes ON you should be able to see the Sensairy app icon.
As per their instructions you can also connect wirelessly if your car system supports wireless Android Auto.
ssadwelkar is offline   (1) Thanks
Old 18th March 2023, 14:53   #275
Thanked: 268 Times
So, it means I can only connect with Android Auto, and not directly with the Android Player. What about the notifications and alerts? Will they come on the Player, or only on the phone?
JoaTMoN is offline
Old 18th March 2023, 15:13   #276
ssadwelkar's Avatar
Thanked: 97 Times
Yes, you can only connect with Android Auto, that too after installing a private update apk file from Tymtix, which needs to be installed after downloading and installing the apk file from Google Play.
You will receive all notifications and alerts on the phone as as well as Android Auto if your phone is connected via cable or wirelessly to Android Auto.
Old 29th March 2023, 09:11   #277
Thanked: 268 Times
I finally got the 5-sensor device based on feedback from this thread, and I'm happy with it. Readings are accurate when checked with Qubo tire inflator, but shows a 0.5 psi variation when checked with Michelin tire pressure reader. Here are some pictures:
SensAiry : An app-based TPMS-20230322_150619.jpg
SensAiry : An app-based TPMS-20230322_150627.jpg
SensAiry : An app-based TPMS-20230322_150709.jpg
SensAiry : An app-based TPMS-20230324_135154.jpg
SensAiry : An app-based TPMS-20230324_135157.jpg
SensAiry : An app-based TPMS-img_20230324_151539.jpg
JoaTMoN is offline
Old 4th June 2023, 12:02   #278
rishi.roger's Avatar
Thanked: 597 Times
Ordered it from https://www.tymtix.com/#/store?product_id=7
Unfortunately I couldn't find any other sources to purchase it from (Delhi).
I was also a bit confused between external vs internal sensor for Nexon, went ahead with Internal.
The website showing ETA of almost 3 weeks to NCR :/.
rishi.roger is offline
Old 6th July 2023, 13:21   #279
sridhu's Avatar
Thanked: 2,756 Times
Update
I got 5 new external sensors from Sensairy for new tires that I purchased as I wanted to ensure that tire pressure is maintained & I have warning in case of a puncture.
The batteries in the existing internal sensors all gave up the ghost in about 3 to 3.5 years. They cannot be replaced any more, even by the company. So, you are looking at 2 sets for each tire replacement along with the associated mounting charges. Not worth it at all, if they dont make the batteries last 7 years or make them easily user replaceable.
The HUD backlight also died.
For the above reasons, I opted for external sensors from Sensairy.
Pairing with the app was pain free.
I labelled the sensor caps myself with a DYMO to identify them; I think they should be stamped on the sensor covers and that Sensairy should give a couple of blank ones as free spares.
The lock nut is too thick and reasonably useless.
Unfortunately, one tire failed on the way to Madras, within about 200 km. The sensairy system did not warn about the loss of pressure until it was too late, I think as the tire shows clear signs of running while flat. My driver knows to stop the car as soon as the alarm is heard. The puncture was due to a nail and hence should have been slow.
This is the precise scenario I bought the Sensairy to prevent and it failed spectacularly.
Net - net, Sensairy is not engineered well. I wont say "Stay away" but would definitely say "Lower your expectations"
sridhu is offline   (2) Thanks
Old 13th July 2023, 13:25   #280
src
src's Avatar
Thanked: 263 Times
Can someone confirm if this SensAiry will work on the Alloy Rims of Brezza ZDi?
Has anyone installed it.
src is offline
Old 13th July 2023, 13:55   #281
I've mentioned the details in this (SensAiry : An app-based TPMS) post. Kindly go through it to understand better.
Old 13th July 2023, 14:26   #282
src
src's Avatar
Thanked: 263 Times
Awesome Buddy. Was actually looking for your post as I remembered someone posted the same.
So my friend needs to buy Treel since I recommended him SensAiry after using it in my Honda City
src is offline
Old 13th July 2023, 14:43   #283
Well, newer valve stems of Treel also will not fit. If you read that post, you'll see that I've mentioned it. He can ask them to use older valve stems for fixing the sensors.
Old 28th August 2023, 11:29   #284
sidpunjabi's Avatar
Thanked: 128 Times
Question: Is there a way to switch the sensors off once the car's parked and then switch it on before I begin my drive? Maybe through the app or a pre-set timer?
I don't see the point of it constantly checking for tyre pressure and draining its own battery since my phone is going to be out of bluetooth range when I'm at home / office and the car will be stationary.
sidpunjabi is offline
Old 3rd September 2023, 07:28   #285
ssadwelkar's Avatar
Thanked: 97 Times
Agree with you on the sensors draining their own batteries while not connected to a BT device, I haven't seen the option of switching off the sensors when not in use in the user manual or the app, the manufacturer claim the sensors life to be of 4 to 5 years, the batteries are not replaceable, sensors need to be replaced.
