Old 2nd July 2007, 17:48   #31
moralfibre's Avatar
Thanked: 14,081 Times
Guys I found a good product for cars. It is the Sparco SP014LLH007 . Cost is $100 for a can and it looks cool . Here is an image:
Sadly not available in India.
moralfibre is offline
Old 13th July 2007, 20:12   #32
condor's Avatar
Thanked: 16,229 Times
CeaseFire - BLR
Originally Posted by mail4ajo
I checked out the "ceasefire". Pretty compact ... No maintainence for 5 years.
The dealer quoted 1500Rs.(Is this the right price?).
Guys, any one intrested in the CeaseFire fire extinguisher ? Contacted the BLR office, they said Rs 1500/- per can, 650 gm, with B&W. Type - ABCD. 5 year warranty & no maintenance. He is quoting a 10% off for 5 or more pieces. If we have sufficient numbers, we could try for more.
@gigy, which is the 2 kg cylinder you mentioned ?
condor is offline
Old 13th July 2007, 20:20   #33
nitrous's Avatar
Thanked: 329 Times
Methods Automotive is the distributor for India.
These guys usually import stuff against order.So, im pretty sure it can be ordered here.
nitrous is offline
Old 13th July 2007, 21:17   #34
rr_zen's Avatar
Thanked: 401 Times
Am sure it can be ordered from them but going by what our members have experienced with their service, am not too sure if it will be delivered or if at all we get some feedback from them.
rr_zen is offline
Old 13th July 2007, 23:50   #35
Thanked: 9 Times
Install it on the passenger side where you see the net in the pic
Mayavi is offline
Old 29th June 2008, 10:41   #36
kARTIK IYER's Avatar
Fire Extinguisher In your car
Is it important or a must to keep a Handy Fire Extinguisher in your car . I have seen it in few Tourist cabs and i always felt it can use or help during emergency .
Any idea about make and costing and some experiences which can help all .
Regards .. Kat
kARTIK IYER is offline
Old 29th June 2008, 11:17   #37
Srini76's Avatar
Thanked: 124 Times
Hey Karthik,
I recall a model of Fire Extinguisher called "Cease Fire" while I was in India , It was basically a very handy unit intended for the house. I am sure you can have a stand/holder fabricated. Here in Bahrain the Fire Extinguisher is placed below the front right seat (Left hand driven cars). Please do check with the experts on what type is suitable for the car (i.e.) there are various types such as wet, dry, riser and so on.
good luck pal
Srini76 is offline
Old 29th June 2008, 11:37   #38
married2speed's Avatar
Thanked: 9 Times
An original cease-fire should cost you around 1000-1200 bucks here in Delhi. The fake one's or the not so good one's come in for around 600 Rs.
Just make sure that it's in your easy reach. Normally the dealers attach it on the A-pillar. However, what i've done is put it in the glove box. Works for me better.
These normally have a warranty of about 10 years. Just pray that you never get a chance to use it
Cheers!
M2S
married2speed is offline
Old 29th June 2008, 13:11   #39
gd1418's Avatar
Thanked: 729 Times
I didn't know about this warranty bit. You mean to say that in case the extinguisher is unable to work within the 10 year period when the car catches fire, then they will replace the device or er ahem.. the car..
Cynicism apart, somewhere I heard that you need to recharge the fire extinguishing chemical every two years or so to work in emergencies..
Cheers!
M2S
gd1418 is offline
Old 29th June 2008, 13:46   #40
Srini76's Avatar
Thanked: 124 Times
Hi kathik,
Just checked a few cars here and they all have "Dry powder: ABC, BC (above 50 to 70%)" type of extinguishers. and lets hope you never have to use it though.
Best Regards,
Srini76 is offline
Old 29th June 2008, 14:45   #41
Thanked: 9 Times
but in case the fire extinguisher doesn't work, I guess it'll be a lot more people who'll bear the wrath than the fire-extinguisher dealer.
I guess that's what they tell us at the fire-safety class but this dealer i picked it up from, said that it would hold good for 10 years. I checked this on the ceasefire website as well and this is what is said:
Guaranteed for 5 years. You can test an extinguisher only once when you ctually put out a fire. That's why Ceasefire is designed to be as reliable on the last day of its shelf life as the first. It needs no refilling, and no maintenance. Yet is backed by a nationwide service network.
Gd- We both stand corrected
Hope this helps
Cheers!
M2S
Old 25th October 2008, 07:25   #42
greenhorn's Avatar
Thanked: 4,658 Times
Fire Retardant ?
Was browsing through the local big bazaar and saw some red cans marked Fire Retardant in the auto section. Will they work in an emergency , or do i need proper fire extinguishers
greenhorn is offline
Old 25th October 2008, 17:14   #43
Thanked: 306,656 Times
I have seen some wood suppliers use this for special applications. It basically gives an X material a higher level of resistance to catching fire.
Entirely different from fire extinguishers.
GTO is offline
Old 26th October 2008, 14:36   #44
greenhorn's Avatar
no, it looked like some kind of fire retardant foam, somthing you spray on a fire, not the preventive type
Old 26th October 2008, 17:39   #45
Rehaan's Avatar
Thanked: 35,136 Times
Greenhorn,
I'm guessing here - maybe for legal reasons (which country was it manufactured in?) they could not call it a "fire extinguisher" and hence it had to be called a fire retardant since there was no guarantee it would entirely extinguish the fire, but guaranteed to retard it?
Alternatively, was it for a special type of fire (lithium (?)) that might be hard to extinguish but easier to slow down spreading?
cya
R
Rehaan is offline
