Originally Posted by Thad E Ginathom |
It’s just marketing, after years of my own testing, speaking to multiple chemists and the best detailers in the world like Larry (Ammo NYC), I can safely say it’s no better or worse than a good ceramic coating.
There’s a reason none of the top coating brands even bother with offering graphene coatings, from Carpro to Gyeon to Modesta, no one has brought it to market. Carpro for eg. spends a ton on research and I believe are even working on self healing clearcoat currently, which if successful can be a real game changer in the future.
Originally Posted by FieryRed Hey Brother finneyp
Do let me and others know if you got around to trying and if this is actually good for the paint and does not have any side effects ? |
Super Ceramic I had recently applied for a friend of mine as he had already bought the bottle (would always advise against cheap Chinese coatings). Followed all the steps including a full decon and paint correction and applied it, washed 1 week later and it had zero water beading.
It’s complete snake oil, you’re much better off with a turtle spray or literally any other product. Didn’t even last 7 days. Even a basic wax lasts 35-45 days.
Originally Posted by FieryRed 4000/- for 1 year warranty
5000/- for 3 years warranty
6000/- for 5 years warranty
They claim Ceramic Hardness : 9H
Product Used: Ceramic Hardness : 9H
Product Used: System X , made in USA & Certified by SGS
Scratch Resistant upto 1000 grams of pressure
Resistance aginst Bird beats, & tree gums
If any feedback on them pls do let me know |
As a SystemX certified installer I can help, first he’s not an authorised shop as SystemX doesn’t have any certified installer in Delhi, you can check on their India website for the list. You will not get any mfg warranty on any of their coatings if getting it done from an outside shop.
Also ask him which variant is being used, they have 4. Crystal SS, Pro, Diamond and Max which is their flagship and comes with a 10 year warranty in India (lifetime in the US). The film thickness of each coating is in increasing order, Crystal is the thinnest at 2-3 microns and Max is the thickest at 20-22 microns. Your factory clearcoat on most cars and bikes is ~50 microns for reference.
Even the entry level coating, Crystal SS comes with a minimum 2 year warranty, so is a non SystemX coating being used in the 1 year warranty option?
Also, prices are too low assuming he’s opening a fresh kit as the kit alone costs more than what he’s charging, Diamond is well over 2 times his 5 year prices for the bottle itself.
Regarding bird droppings and tree sap, it will resist within reason. If left long enough forget the coating it is so acidic it will eat through your entire factory paintwork and will require a repaint. Ideally remove within 6-7 hours.
Scratch resistance upto 1kg? You can scratch it with 50g of pressure with an object hard enough. Just gently dragging your finger on a high gloss coated surface can leave micro marring, paint is very, very soft.
Originally Posted by Vyadh Have talked to few detailers and now a bit confused about the same.
1. CarKraft (Jagtap dairy chowk). their quotes are in the range of 15K to 20K for ceramic (3years warranty including 4 services. in service they will cover swirl marks, hard water marks removal, polishing, touch up of original coating in case of minor accidents)
4. Moto Voiture (Wakad). Here they claim to manufacture their own coatings. this was new. Ceramic - 10H is 22K or 25K for 3 yrs / 5yrs. Graphene - 14H is 28K or 35K for 5ys / 7yrs respectively.
Quite diverse quotes from them, will be further inquiring with few more detailers later today/tomorrow. |
All I can say is please find better detailers, the guy selling 14H hardness might as well write 1000H. The pencil scale of hardness ends at 9H, everything over that is just false advertising.
Also, none of these are known brands. They are rebranded Chinese/no name coatings with no mfg warranty, which will also explain the constant need of reapplication they seem to be giving you as part of the deal. High quality coatings don’t need topping up or constant reapplication.
Neither do high quality coatings need machine polishing or scratch removal periodically, you won’t have swirls to begin with if you wash it safely, if you don’t then no coating can help. Look for Carpro, Gyeon or SystemX authorised installers in Pune.
