Wikipedia defines a head's up display as:
A head-up display or heads-up display, also known as a HUD, is any transparent display that presents data without requiring users to look away from their usual viewpoints.
These displays present data to the pilot (driver in case of a truck/car) in the field of view without the need for refocusing on the instrumentation. They have seen widespread use in military aviation and the latest civilian aircraft. Since the displays help the pilot not to get distracted, they are also being used in high end cars, for example on the BMWs. The BMWs use a projector system to display the information on the windshield directly. The technology has been clearly explained on the BMW
site.
I wanted to know how it is to use such a display and since I could not get a BMW just to try this, I started looking for options. I have heard of phone apps being used to show a reflection on the windshield. But there is a problem with this. Windshields are not designed for an image projection. Hence you see two reflections of the phone screen on the windshield and it, in fact, distracts the driver more. That is when I heard of
Hudway Glass on Kickstarter (here). I backed the project immediately for USD 39 and I got an unit as a reward.
This post describes my initial experience with the product. In summary, I should say that I a bit disappointed with the performance in day light.
What's in the box:
Inside the box, you will find
- A quick start guide and warranty information leaflet.
- Two kinds of mounts: one has a rectangular base that serves as a cradle base and the other is a fixed low profile mount. Both the mounts can be glued to the dash board with the help of tape already attached. The Glass attaches to the mounts on the circular end magnetically.
- A card (white one in the image above) that has codes to activate the Hudway Glass apps.
- A second card that has an NFC tag. The tag can be attached to the dash board and can be used to launch a mobile app if the phone supports NFC.
- The Hudway Glass itself. It comes in a pouch that doubles up as a cleaning cloth.
The package also includes a 'Pump your ride' sticker.
The Glass is basically a specially treated aspherical plastic lens that increases the image size by about 20% and it does not show two reflections. You place the phone on the cradle, lift up the lens and adjust the viewing angle; the HUD is ready to go.
The image above shows the reflective coating on the Glass.
The back panel of the Glass has a magnetic base that attaches to the cradle or fixed mount.
I tested the Glass with a Nexus 4 phone set to full brightness and adaptive display brightness disabled. The image below shows the Glass in the shade of my apartment parking.
As you can see, the reflected image is slightly dim. Immediately after taking this photograph, I took the car out for a drive to see the performance in full day light condition. Boy, was I disappointed. I probably have to attribute this to the phone's display a bit.
Here is a video of the drive. You cannot see the image, can you? I could see the image a wee bit but it was not as expected.
I am going to repeat the same with night driving and post a video in a subsequent post.
Mobile Apps
There are two mobile apps that accompany the Glass; Hudway Widgets and Hudway. The widgets app has screens for speedometer, trip information. Some screens can be unlocked with the Pro version - the activation key for which is in the package. Descriptions to some screens are given below.
Hudway Glass main screen. It is from here that you select the function required.
Speedometer Chevrolet style
Swiping in from the left brings up options. One such option is the HUD that flips the image so that the reflection on the Glass appears correct.
Clicking on Navigation option on the main screen brings up the Hudway navigation app.
Another screen that I found rather interesting is the Land Meter (under Other option on the main screen). This screen uses the accelerometer of the phone and displays the roll and pitch of the vehicle.
You are not restricted to Hudway apps only. There are a lot of HUD apps on the app stores. I have to look into them and see which one is better to use.
Until the next post,
