Re: Review: Bosch AQT 35-12 Electric Pressure Washer Quote:
Originally Posted by Lambydude Can you let me.know how to connect this valve to the hose? Are you using 0.5 inch hose? |
I measured the internal diameter of my hose pipe before ordering - it was almost 12mm, so that was the size I ordered. It fits the hose perfectly.
The item I received from AliExpress had a flow-direction marking on it. The non-return valve is to be attached only on one end of the hose, such that the water can enter the hose through the valve but not escape through it. Image below should help: ![Review: Bosch AQT 35-12 Electric Pressure Washer-img_20190403_163511.jpg](https://www.team-bhp.com/forum/attachments/modifications-accessories/1865347d1688326886t-review-bosch-aqt-35-12-electric-pressure-washer-img_20190403_163511.jpg)
I place the end with the valve inside the water bucket, and attach the other end of hose to the inlet of the pressure washer.
Even if there were no markings on the valve, it would have been trivial to figure out which end to connect the hose to - blowing the air through it would help figure out the flow direction valve allows. |
