Re: Tail Gate Mounting For Spare Wheel Quote:
Originally Posted by narayan Guys
couldnt find any resources on the above subject - hence putting in my query here.
does anyone have any experience with fixing a spare wheel mount on the rear tail gate of the SCORPIO just like the SAFARI ?
will a wheel mount from SAFARI or SUMO / BOLERO be a straight fit ? any concerns on the strength of the SCORPIO DOOR HINGE to take on the weight of the spare wheel ?
is it ok to remove the tail gate door pads and have this welded over ?
please share your thoughts ..
thanks ! |
You can use the Bolero's spare wheel cover and the mounting hinges/clamps. It's a straight fit to the scorpio and I have seen one with the same mod. However the door hinges would require reinforcing. Best thing to do is to check with the A$$ itself and they should be able to do this for you. |
