Old 21st January 2014, 23:29   #31
joybhowmik's Avatar
Thanked: 2,503 Times
Re: Review: 60W Cree LED Light Bar
Considering that the LED's can get mud/dirt on them thus impairing the heat sink, can they be somewhat effective if mounted on the roof above the windscreen, but yet have better chance to last longer?
joybhowmik is offline
Old 22nd January 2014, 00:36   #32
tsk1979's Avatar
Thanked: 23,157 Times
Yes, its always better to mount higher up. However, I had already "reserved" the top position for the rectangular square 60W pair, this was the only place left. Did not want to get anything on the roof.
tsk1979 is offline
Old 12th February 2014, 14:50   #33
~ H O N D A ~'s Avatar
Thanked: 9 Times
Continuing here from the other post. Click here
Its all about where you aim. If you do not go for diffused or flood beam, and go for spot beam only, you can aim in such a way that it does not go towards the oncoming traffic side.
I will give you an example
See the beam from this light bar
Attachment 1192794
Can you see how narrow it can be.
Now look at the throw. How dark it is beyond the borders.
Attachment 1192795
Now this is very powerful, 200W, but a 40W light bar in spot only without diffusers is not going to blind any oncoming traffic provided its not aimed at that.
So what you have installed on your safari is a 60W or a 200w bar that is shown in the pic above.
if it is Combo 200W then why such narrow throw.
or as you referred in the other post you still suggest a 120W (20inch Bar) spot setup instead of a combo,will have a good throw and will lit the road efficiently.
~ H O N D A ~ is offline
Old 12th February 2014, 15:03   #34
tsk1979's Avatar
On my safari for this review I have a single 60W bar.
200W was just as an example
Yes, spot for 120W is great. Long throw. For illuminating sides, best is to use low beam of your vehicle.
tsk1979 is offline
Old 1st April 2014, 14:45   #35
blackbeast's Avatar
Thanked: 161 Times
Followed this thread since its start. I've just dropped the idea of geting 3 xenon lamps from hella as everyone is opposing for the ugly look on the car. wanted to have them on octavia to drive on remote roads which i take.Can a light bar meet my requirement to a good extent ? Also what is the maximum size( no of leds) i can go for , considering its a sedan.
blackbeast is offline
Old 1st April 2014, 15:06   #36
tsk1979's Avatar
Why not import a projector kit and install Xenons. Is the cost very prohibitive?
If you go for good quality lights lets say 2*60W, cost comes to ~20,000 INR for stuff which can give you a 15 degree beam which is good for range as well as spread.
tsk1979 is offline
Old 26th April 2014, 20:15   #37
Thanked: 9 Times
Hey Tanveer,
How are you buddy, saw your video on LED Ovals, when did you get those.
Looks awsome, good throw lights up the road really good.
Post some day light pictures here.
Old 28th April 2014, 12:24   #38
tsk1979's Avatar
Hey Tanveer,
I have been using them for a few months. Sorry, you won't see a review here due to my commercial involvement.
tsk1979 is offline   (1) Thanks
Old 28th April 2014, 16:53   #39
jaguar.runs's Avatar
Thanked: 105 Times
Lately most of the off-roaders in UAE are using the LED light bars. I spoke to one guy and he said that the light bar is very useful in the sand dunes at night. According to him, the light spread is good and is muck better than the stock low beam light. He also mentioned that they are not supposed to be used on UAE roads.
jaguar.runs is offline
Old 1st May 2014, 14:23   #40
Thanked: 9 Times
120W CREE LED BAR on Hyundai Verna Fluidic
Bought the LED Bar last month during my trip to china.
These are 120W LED Bar Combo Setup
Review: 60W Cree LED Light Bar-vkey_001.jpg
Opened the top portion of the Front Bumper
Review: 60W Cree LED Light Bar-vkey_002.jpg
Welded a sheet to handle the load so that the fitting dont get ripped off just extra care
Review: 60W Cree LED Light Bar-vkey_003.jpg
Inserting the Custom Made fitting on which the LED will be fitted.
Review: 60W Cree LED Light Bar-vkey_004.jpg
Work almost done
Review: 60W Cree LED Light Bar-vkey_005.jpg
Finalizing the welding
Came home for lunch now .
will post the rest of the pics soon.
~ H O N D A ~ is offline   (3) Thanks
Old 2nd May 2014, 10:49   #41
Thanked: 9 Times
Re: 120W CREE LED BAR
Few Pics of the LED BAR installation
Review: 60W Cree LED Light Bar-vkey_006.jpg
Review: 60W Cree LED Light Bar-vkey_007.jpg
Front View
Will post night pics soon.
Old 2nd May 2014, 13:09   #42
Thanked: 9 Times
Re: 120W Cree LED Light Bar
Specification of the LED Installed
  • Power: 120W
  • Voltage: 10-45V DC
  • LED: 12PCS*10W(CREE LED)
  • Size::65.5*13*14CM
  • Beam: Spot beam, Flood beam
  • LED color temperature: 6000k
  • Working life: 30000 hours
  • Waterproof rate: IP67
  • Working temperature: -40~ 85℃
  • Material: 6063 aluminum profile, stainless steel bracket, PC Lens.
  • Out put lumems 13200lumens
  • COMBO BEAM 2-8-2 Flood-Spot-Flood"
~ H O N D A ~ is offline   (1) Thanks
Old 3rd May 2014, 00:33   #43
Thanked: 9 Times
Clicked this just now at Marine Drive
Review: 60W Cree LED Light Bar-1399057249466.jpg
~ H O N D A ~ is offline   (2) Thanks
Old 24th July 2014, 08:12   #44
himadrimondal's Avatar
Thanked: 913 Times
TSK, dedicating this make to you, your thread has given me the inspiration to design and make this. This is a 40w led bar, 10 watt each as suggested by you. The problem with 10w is not much of the parts are available, drivers to the led are not even heard by the local vendors. Took me over a month to fabricate and design. Parts required to make these are:
1. SMD LED 10 Watt each (local market)
2. Heat sinks (local market)
3. Collimator lens (ebay india). These are awesome. Without the lens one can still stare at the led for 5 secs but with these on the lights go crazy. I have removed my Hellas, they give silly pencil beam lights compared to these.
4. Drivers, bought many but used none. Most of them failed in both series and parallel connections. The ones bought from dx.com are yet to arrive, due over a month. Back to my engineering basics, used 7812 IC's on heat sink which is placed inside the bonnet.
5. MS sheet fabrication.
Thanks boss for this fantastic thread, write up and video.
Initial setup
Review: 60W Cree LED Light Bar-led4.jpg
7812 IC for the 4 led's
Review: 60W Cree LED Light Bar-led3.jpg
Review: 60W Cree LED Light Bar-led1.jpg
Review: 60W Cree LED Light Bar-led2.jpg
himadrimondal is offline   (7) Thanks
Old 24th November 2014, 12:36   #45
brraj's Avatar
Thanked: 1,301 Times
Attachment 1236499
Can you post few pic of the LED throw?
brraj is online now
