Old 15th December 2015, 13:42   #1021
shreyak_ss's Avatar
Thanked: 135 Times
Re: The 'Wiper Blade' Thread
How are autofurnish wiper blades? I am looking to change my 1.5 year old Octavia's blades and came across Hella european and autofurnish on Amazon. Also, what's the correct indication that wiper blades need changing? Will changing them myself hamper any warranty? And what is the correct size for Octavia (new)?
Thanks in advance.
Shreyak.
shreyak_ss is offline
Old 15th December 2015, 14:11   #1022
stanjohn123's Avatar
Thanked: 1,854 Times
Thanks in advance.
Shreyak.
As per customer reviews, Autofurnish wipers are horrible, so please avoid that. Also Bosch is better than Hella.
stanjohn123 is offline   (1) Thanks
Old 22nd December 2015, 05:57   #1023
sridhu's Avatar
Thanked: 2,756 Times
You can add Auto Stark to that list too.
sridhu is offline
Old 22nd December 2015, 09:49   #1024
sagarpadaki's Avatar
Thanked: 6,794 Times
After trying auto furnish blades , i can say that the simple 300 odd bucks Bosch blades are anyday better! Sure the former looks cool with frameless design but the wiping goes for a toss within a month and will start leaving streaks . Switching back to simple Bosch blades again next time
sagarpadaki is offline
Old 22nd December 2015, 09:55   #1025
mayankk's Avatar
Thanked: 8,613 Times
Auto furnish is just a rebranding operation. Browse through their products, and others of a similar nature. Even the demo pictures are the same. I am sure theyre all just shipping in stuff from Guangzhou or such.
Its all a draw of the lot, Ive experienced. 1400 buck Bosch went off in about 4-5 months. Syndicates lasted for a year. But the current ultra unknown frameless have been going good for the past 5 months, and cost just 250 bucks a pop.
mayankk is offline
Old 29th December 2015, 00:18   #1026
Thanked: 11 Times
Ola señores,
It has been almost a year and a half since I changed the wipers on my 2014 Honda City, and am particularly interested in installing the Bosch Clear Advantage wipers as a replacement. I tried sourcing it from local shops where I reside but have had no luck with the exact configuration (24"/14" or 600mm/350mm driver/passenger side).
I came across this website industrybuying where they are selling Bosch CA wipers. Even the part number mentioned in the website for Honda City is same as that in Bosch's website. But I am unsure of the website's credibility and customer protection against fraud. Have you purchased wipers or anything else from here before?
Thankie for the advise,
KnJr
KnJr is offline
Old 29th December 2015, 09:25   #1027
skyliner34's Avatar
Thanked: 72 Times
Originally Posted by KnJr View Post
Ola señores,
KnJr
Not sure about the site you mentioned, but the product is also available on SD - http://www.snapdeal.com/product/bosc...dorCode=Sbfe05
Though the pic has different image the product description says Bosch CA.
skyliner34 is offline   (2) Thanks
Old 29th December 2015, 09:49   #1028
diyguy's Avatar
Thanked: 588 Times
They are now getting VC funding from TVS and Murugappa group. Shouldn't be any fraud here
diyguy is offline   (2) Thanks
Old 29th December 2015, 09:49   #1029
hrman's Avatar
Thanked: 1,104 Times
I had a doubt. When changing the wiper blades, is it ok if we get the replacement which totals to the original wiper size?
For Eg: In the Skoda Rapid, the original was 24inch and 16inch. So theoretically, anything totalling to 40 inch should be ok? Eg:22,18 or 26,14?
hrman is online now
Old 29th December 2015, 09:58   #1030
mayankk's Avatar
The passenger side blade, if longer, will scrape the lining, or maybe even go past the edge of the windscreen. Look at the sweep.
mayankk is offline
Old 29th December 2015, 11:53   #1031
Thanked: 787 Times
The size of the blades is dependant on a) the length of each arm and b) the angle of sweep. Generally, the passenger side wiper has a larger angle of sweep and that is why it is generally smaller in size than the driver's side wiper blade.
rpunwani is offline
Old 31st December 2015, 10:58   #1032
Thanked: 182 Times
Does using wiper stand help in extending the life of the wiper blade? I have purchased wiper stand after I was told that it helps extending the life of the blade, and reduces the chances of scratches on the windshield glass.
Is that correct? Any disadvantages with using wiper stand?
sohu9 is offline
Old 9th January 2016, 17:22   #1033
aLY
aLY's Avatar
Thanked: 15 Times
Upgraded my GT's Wiper Blades to Hella Curvo, Frame less blades.
Cost:
Driver Side - Rs.575/- (24 inches)
Co-Passenger side - Rs.520/- (16 inches)
Initially I was trying to get Hella Dynaedge Wipers, but I've been informed that they are obsolete, by http://www.epitstop.in/,Bangalore.
aLY is offline   (1) Thanks
Old 25th January 2016, 17:29   #1034
peterjim13's Avatar
Thanked: 708 Times
Cost:
True aLY,
Hella has discontinued Dyna Edge. Where did you buy your dynaedge from ?
peterjim13 is offline
Old 25th January 2016, 17:36   #1035
aLY
aLY's Avatar
Thanked: 15 Times
Originally Posted by peterjim13 View Post
True aLY,
@peterjim13,
As I mentioned in my post, I have upgraded to Curvo, not to Dynaedge. I bought them from http://www.epitstop.in/
aLY is offline
