Old 28th June 2023, 23:24   #1636
ABHI_1512's Avatar
Thanked: 13,419 Times
Re: The 'Wiper Blade' Thread
Originally Posted by rocky17 View Post
Where can I buy these?
I bought from an offline shop here in Calcutta but it should be available online too. Try the usual suspects like Flipkart or Amazon or even Boodmo for that matter. The frameless ones look cool too.
ABHI_1512 is offline   (1) Thanks
Old 14th August 2023, 03:34   #1637
Thanked: 76 Times
Could you list the name of the shop please ? Also do the wipers have any specific model ?
I too have been looking for wipers. For some strange reason almost all the wipers I use tend to streak in some way or form. I have tried to clean the windshield with many different types of products including rubbing alcohol with no luck.
If you know of a solution that actually works please do let me know.
Ghost131100 is offline
Old 14th August 2023, 06:36   #1638
Thanked: 789 Times
After reading the recommendation here, I bought the Schaffler wipers from Motrpart Online. The shipping was delayed as it was out of stock while the site showed it to be available. But they are performing well without any noise or streaks on the glass.
Although the brand is Schaffler, they are imports from China.
shipnil is offline   (2) Thanks
Old 14th August 2023, 06:55   #1639
Thanked: 1,444 Times
Bought from Boodmoo.
Bosch frameless wiper blade 26", works perfectly for my Nano's huge windscreen.
Price 521/- including shipping.
Vinod_nair is offline   (1) Thanks
Old 16th August 2023, 22:08   #1640
ABHI_1512's Avatar
The shop is near HP petrol pump, Mominpur and it is named United Auto Center but I am sure you will get the wipers at any reputed auto parts dealer across Calcutta. You can mention the car model and they will provide the best fit accordingly. Hope that helps.
Old 16th August 2023, 23:11   #1641
Sahil's Avatar
Thanked: 7,999 Times
Originally Posted by Vinod_nair View Post
Attachment 2490092
Just ordered the same ones today for my Lexus. Yes the nano and Lexus share the same wiper
However it’s cheaper on Amazon. Here is the link: https://www.amazon.in/gp/aw/d/B06WP6...b_b_prod_image
I’ve found Amazon quick and cheap for wiper blades. Availability is sometimes and issue but most often you find most car accessories you are looking for from reputed brands.
Sahil is offline
Old 17th August 2023, 00:20   #1642
Doesn't your car need a pair? Where one stalk is shorter than the other?
I thought only Nano has a single stalk wiper.
Old 17th August 2023, 00:49   #1643
Sahil's Avatar
Yes ofc it needs a pair. Hence they sell single ones so you make your own pair. Other one was 18inch that I ordered.
Sahil is offline
Old 17th August 2023, 01:57   #1644
Thanked: 4,909 Times
As does my etios. I am happy with the OE toyota wiper. I find the hybrid mechanism offers better coverage than the frameless one
https://boodmo.com/catalog/part-blad...er_rh-6759409/
Toyota offers refill of just the rubber which is great value.
https://boodmo.com/catalog/part-blad...er_rh-6759409/ Etios part no
https://boodmo.com/catalog/part-rubb...er_rh-6759383/ Lexus part no
greenhorn is offline   (1) Thanks
Old 31st August 2023, 00:21   #1645
Thanked: 21,174 Times
Pathetic quality of Bosch Frameless blades
After having a fantastic experience with Valeo Frameless wipers on different cars including my Slavia, I swapped to Bosch Frameless since the price was similar and wanted to try out something new. But within a month of use, not even with rain, the main 26 inch blade has given up right at the center, creating this horrible residue of water every wipe. Switching back to Valeo for good.
audioholic is offline   (6) Thanks
Old 31st August 2023, 19:10   #1646
Thanked: 3,196 Times
[b]Pathetic quality of Bosch Frameless blades
Bosch quality has taken a serious hit after they switched to cheap Chinese stuff. The earlier Aerotwin range was superb, but they pulled the plug on German imports and decided to go for cheaper Chinese ones.
The Clear Advantage from Bosch hardly worked for a season in my Baleno. I can understand how the cheapest Eco series will work.
The Michelin I have now is working flawlessly in it's second year. Do give it a try as an alternate to Valeo.
unk9ja is offline   (3) Thanks
Old 1st September 2023, 01:46   #1647
Samfromindia's Avatar
Thanked: 2,857 Times
Yes same with me for Ecosport. I thought Amazon have given me duplicate product. The clear advantage I had earlier was definitely better.
https://www.team-bhp.com/forum/modif...ml#post5129821 (The 'Wiper Blade' Thread)
Samfromindia is offline
Old 18th September 2023, 15:05   #1648
Thanked: 75 Times
Go for Schaeffler wipers if possible or available. I have been using the same for the last few years and they are brilliant. The quality of the wiper is top notch and longevity is great too. After having used Bosch before, I can vouch that these are superior and better.
Can you please tell us if it can be installed on the J or U hook?
I am planning to buy these and give it a try, so before I place an order just wanted to confirm the compatibility.
Thanks.
TURBO28 is offline
Old 18th September 2023, 23:25   #1649
ABHI_1512's Avatar
Mine is a U type and hence it should be compatible with most of the cars,
Regards.
Old 19th September 2023, 16:36   #1650
Thanked: 75 Times
Regards.
Thank you for the information.
Can I know how are the blades holding up? Is it better than other brands like Bosch? It would be great to see how they are working since you have been using them for quite a period of time.
Thanks.
TURBO28 is offline
