Old 18th October 2016, 19:24   #901
james's Avatar
Thanked: 648 Times
Re: Buying & Using a Pressure Washer
Originally Posted by alstonlobo View Post
yes, this is working fine, although had changed the gun attachment a year back since it was not used for a long time, probably the apparatus inside got jammed.
Thank you, Alston!
Originally Posted by diyguy View Post
I am planning to get the head replaced in my karcher as it was not pumping at high speed. It has been unused for more than a year. Very unhappy with it actually.
The head of the k2.x series costs roughly around 4.5k. And almost in every case, after replacing the head, the oil leaks out and ruines the unit.
I changed 2 small plastic cogs in the pump that should cost no more than 20 bucks. Ended up paying 1.8k for them!!!
I'm thinking of picking up a unit from Makita or bosch.
james is offline
Old 19th October 2016, 08:18   #902
kutlee's Avatar
Thanked: 232 Times
I have been using basic Makita for about a year now. Use it monthly twice. Till now there is no problem. Water is hard water or soft depending on what's available. Its very noisy. I put some old rag on top of it to silence it a bit (I know it will stop heat dissipation etc).
kutlee is offline   Received Infraction
Old 19th October 2016, 15:18   #903
alstonlobo's Avatar
Thanked: 128 Times
Originally Posted by james View Post
Thank you, Alston!
I'd recommend the Makita, for me getting spares is piece of cake as the dealer and service centre is walking distance from my house so A.S.S is taken care of without any issues.
alstonlobo is offline
Old 21st October 2016, 18:59   #904
S_U_N's Avatar
Thanked: 417 Times
Which are the long lasting/ reliable pressure washers in the 5000-15000 price range?
I see many issues with Karcher 2.x series.
Quite astonished that the products do not last more than a few dozen uses.
S_U_N is offline
Old 12th November 2016, 20:51   #905
arun_sharon's Avatar
Thanked: 124 Times
I had a bosch aquatech 100 which sharted oil leakage in 3 years. I bought a karcher k3.550 2 years back. Thought it was a stable version but proven wrong last week it started leaking water and the repair cost was 3k. The usage is very less mostly biweekly. So my experience stay away from any model which has plastic heads /couplers. As per the karcher service personal k7 models are all aluminum/Cooper ones.
arun_sharon is offline   (1) Thanks
Old 12th November 2016, 23:36   #906
diyguy's Avatar
Thanked: 582 Times
Originally Posted by arun_sharon View Post
karcher k3.550 2 years back. ...tepair cost was 3k. K7 models are all aluminum/Cooper ones.
+1
Sadly I had to learn this same fact from experience myself too. Which city and where is this service center? I should get mine fixed as I haven't used it in almost 15 months
diyguy is online now
Old 13th November 2016, 00:36   #907
Thanked: 2,140 Times
Re: Review : ResQtech 8 litre pressure/Spray washer
Originally Posted by five46 View Post
That's that. Any hopes that it can wash down the muck will also water down. The bristles are very soft. Good to wash down the dust. Mud splashes around the skirt is difficult to remove with this.
My ResqTech unit has now gone out of warranty. Here is what I feel about it:
I have found the weakest link is the O-ring inside the lid/screw top. Mine went kaput in the first six months. I visited the factory where the unit is assembled/stored and got a replacement pump with a spare O ring. Within a few months, the O ring gave up again.
It would hardly be a Rs. 20 part, but it lets pressure out, rendering the pump useless. It's not even worth the effort of communicating with the manufacturer and geting a couple of O rings dispatched. I scratched my head for an easier solution.
Finally I tried the silocone sealant. I had bought a tube for sealing some cracks in our bathroom tiles, and I tried applying that in the recess where the O ring normally sits. I left it to dry for 24 hours and then tried the pump.
Coming back to the pump itself, when you pump it to a decent pressure, the force is strong enough to dislodge grime from between tiles. If the O ring leaks pressure, get rid of it, and fill that space with a good quality silicone sealant and you have something longer lasting than the original O ring. Once the pressure holds, you need to fill it completely with water, and then work the handle about 25 to 30 times to build up a good amount of pressure. It should help with the muck.
The other part is if you want to clean up good, take around half a bucket of water mixed with a good car shampoo. Get a good sponge to apply it to the car's body. Spray a fine mist from the pump, then thoroughly apply the shampoo, and then use the brush or nozzle with a good pressure to clean up the shampoo. Use a good micro fibre cloth to wipe it and you will see a new car!
honeybee is offline   (1) Thanks
Old 12th December 2016, 09:25   #908
The tube sealant also proved ineffective, with pieces of it coming out and finally I discarded it completely. Bought a new GP sealant in Gurgaon, a big tube, with a gun - and applied it last morning to the inside of the screw top. Let it cure for around 24 hours.
Today I fitted the screw top to the pump, worked the handle a few times, and the pressure held on for more than a minute as I sprayed a steady jet. No let up of pressure.
Hopefully this new GP silicone sealant stays put longer than the earlier one. With this type of performance, it would beat any battery powered pump hands down.
honeybee is offline
Old 14th December 2016, 19:12   #909
S_U_N's Avatar
Thanked: 417 Times
+1
Thanks for writing. I see that the K7 is upwards of Rs. 40000 which is prohibitory pricing for my personal use.
Isn't there anything in the 10-15K range which is durable?
S_U_N is offline
Old 14th December 2016, 21:20   #910
scopriobharath's Avatar
Thanked: 1,330 Times
Hitachi AW130 seems to be good - IT has lot of good reviews in Australia.
scopriobharath is offline
Old 15th December 2016, 14:21   #911
S_U_N's Avatar
Thanked: 417 Times
Thanks!
This seems to have just 6 months warranty. Isn't that too less for such products?
S_U_N is offline   (1) Thanks
Old 15th December 2016, 18:48   #912
Thanks!
In fact I too am looking out to buy one and none of them seem to offer more than six months warranty. Hitachi supposedly being Japanese offers better quality (hopefully) as they offer in Australia.
Old 19th December 2016, 11:52   #913
Thanked: 63 Times
Hi Honeybee,
I see that you are struggling with the Oring, try wrapping the Oring with teflon tape around the circumference starting from the ID to OD along the whole of the circumference. I have seen even cracked O rings worked like this. A tight fit initially bit does the job. I agree its a jugad, but then why not if it works.
Hope the above helps.
jayeshdamle is offline   (1) Thanks
Old 22nd December 2016, 23:24   #914
quakerme's Avatar
Thanked: 66 Times
Hi i was on a look out for a preassure washer narrowed down to Bosch aqt 33-11 along with a derergent nozzle, any reviews on this or will it be like eureka forbes vaccum cleaner u buy it and never use it. Price for both together is Rs 8199+412
quakerme is offline
Old 30th December 2016, 04:19   #915
Samfromindia's Avatar
Thanked: 2,822 Times
I had upto 10k budget and went ahead with Bosch AQT 35-12.
Bosch AQT 35-12 is available on Amazon lightening deal for Rs. 8399
I got mine for 6750 during a recent sale at flipkart
The 33-11 was going for 5400 recently at flipkart sale. I got 35-12. You can check my review in the link mentioned below:
http://www.team-bhp.com/forum/modifi...ni-review.html
Samfromindia is offline   (2) Thanks
