To Mod: Might consider shifting this thread to "Technical Stuff"
Originally Posted by Mr.Boss Spring stiffness is not only material dependent. Few other parameters like coil dia, wire dia, pitch, etc affects the stiffness. Specific to this case, when the initial compression of spring is changed (pitch gets affected) it will alter the stiffness characteristics. |
Spring Rate depends on Coil Dia, Wire Dia and "No. of Coils" and not on pitch, all of which remains constant in this case. We are reducing the maximum spring travel to get increased ride height.
What is ride height?
Not in technical sense, but in layman's language, the ground clearance when car is in static position. At the springs side, there is some compression (static compression) due to the weight of the car.
dL = F / K
So, basically, this compression decides what the ride height could be, provided other lengths remain constant. What I am doing is changing this static compressed length by actually reducing free length, without changing number of coils in the spring. i.e reducing pitch.
But how max spring compression is reduced?
So now pitch is reduced. That means the coils are closer to each other (by dX, combined). Earlier the coils could be compressed by X distance after which the coils are hugging each other. But now, since the distance between coils is reduced by dX, the net compression is reduced to X-dX.
I hope I am able to replicate the picture I have in my mind.
Originally Posted by Mr.Boss I couldn't imagine how to control / alter the spring initial compression at strut assembly level. |
Well, I am not able to imagine at the strut level assembly.
In our dampers, we can increase/decrease the fluid pressure in pistons to compress/expand spring.
Okay, now I see some relation to your figures. By shifting the spring seat we are able to change the ride height without changing the spring travel, and damping characteristics.
In our Formula Student car we can't think of changing the spring seat, for that we would have to change damper mounts (long process). What we do is vary our "Pushrod length" and pre load to achieve required performance.
We use Double Wishbone Independent suspension, unlike normal passenger cars which use McPhearson Strut.
Originally Posted by Mr.Boss Sorry buddy, I couldn't understand which job are you referring to. |
I was referring to you occupation, Automotive RnD Professional. Edited a line to "correct me if I am wrong" when I found that
