Old 20th February 2018, 17:17   #391
Samir Taheer's Avatar
Thanked: 278 Times
Re: Best Xenon HID conversion kit
The HID bulbs in a HID projector Yes! The DS2 is one of their best projectors - Comes as a 3" projector.
I have the Morimoto Mini H1 Bi- Xenon, which is a 2.5" projector and I love them! In parallel to my HID projectors I was going to install a pair of Hella 3000 I had lying around - after seeing the light output of the Mini H1's I canned the idea. I just didn't need them!
Samir Taheer is offline
Old 21st February 2018, 10:26   #392
Vid6639's Avatar
Thanked: 43,809 Times
Originally Posted by Samir Taheer View Post
A new video from TRS comparing the light and pattern of different kinds of bulbs (Led Vs HID vs Halogen) in a standard lens.
This video is even more useful:
The video clearly shows more glare with the HID though crazy amount of illumination. Also, to note that the cut off with HID is the worse over halogen and LED.
I have also noticed that once you change to LED bulbs the beam height changes. You need to align the headlights manually and ensure they don't focus upwards. This causes more glare and spread.
Vid6639 is offline   (2) Thanks
Old 21st February 2018, 10:35   #393
Thanked: 278 Times
Thanks. That's the video I actually wanted to post.
That's why I previously mentioned the DS2 projectors.
Old 1st October 2018, 10:13   #394
Behemoth's Avatar
Thanked: 5,909 Times
If you are savvy, I will buy/import Hylux (prefer the CAN enabled) and CN lamps. Many people have China/HK warehouses, so supply is pretty quick. Due to shipment costs the same supplier for both may work out cheaper. If you need projectors, Morimoto are available from AVN and their Direct Importers. Also, many people stock decent projectors.
Advantage with Morimoto is no cutting of the back side of the housing is involved. You remove the front cover (now mostly plastic), put in the projector, align and bolt it, and seal back the cover. The lamp (mostly DS1 or 2) has enough space to go in from the narrow opening left.
Hi SGIITK,
Sorry quoting a very old post of yours to take your help.
I currently have this HID setup on my Skoda Laura in the main beam and had installed it myself.
DMEX 12V AC 42W Fast Bright Fast Start Error Free Canbus HID Xenon Kit H1 H3 H7 H8 H9 H11 9005 9006 with Canbus HID Ballast
https://s.click.aliexpress.com/e/bVTfX2U0
The quality is quite good and it is a Canbus Asic ballast.
Now for my Jeep Compass I am considering whether I should go for the same Dmex setup with CNlight bulbs in 4300k or should go for a higher grade ballast from Hylux with Yeaky bulbs as below:
[url]DMEX 1 SET 4500K 5500K 6500K Canbus HID Xenon Kit H1 H3 H7 H11 9005 9006 9012 D2H Hylux 2A88 Canbus Ballast Yeaky HID Xenon Bulb
https://s.click.aliexpress.com/e/cYYiokFQ
How are Yeaky bulbs as compared to CNlight? The Yeaky bulbs are more expensive and have a minimum CCT of 4500k.
Request your advice! Thanks
Behemoth is offline
Old 25th November 2018, 00:35   #395
Thank you for the informational video. Cars under the 10 lakh category like the Dzire, Ertiga and the likes - when they say projector headlamps, my understanding is projectors housing halogen lamps and not HID bulbs. Am I correct? If so, are those halogen lamps in the "halogen projectors" OEM 55/60w? If not, please educate and enlighten. Thank you!
Last edited by Eddy : 25th November 2018 at 01:53. Reason: Quoting a video hampers readability
andescondor is offline
Old 8th February 2019, 18:36   #396
sidpunjabi's Avatar
Thanked: 128 Times
Hi all,
I got a projector + HID kit installed in my car about 6-7 months ago.
Around December, the passenger side HID bulb didn't come on. There were no sparks, no flickering, nothing of that sort. The light just didn't start.
My initial suspect was the ballast. But the shop I took it to tried a new bulb with the old ballast and it worked, so went ahead and installed it, but continued to keep an eye out. This happened 2 weeks ago. Yesterday, what I feared came true. The new bulb stopped working as well.
This time I'm planning to head to a headlight specialist (any suggestions?) and get the wiring checked out.
Any suggestions on where he should start? Would it be right of me to continue suspecting the ballast given the symptoms or is it something else that is shorting the bulb?
The driver side HID bulb has been working perfectly the entire time. I use my car mainly on the weekends, so the lights haven't been used much in these 2 weeks.
sidpunjabi is offline
Old 13th February 2019, 23:18   #397
drhoneycake's Avatar
Thanked: 1,793 Times
The new Ertiga has a low beam projector (with a halogen bulb) and a high beam reflector (also a halogen bulb).
The top trims of Dzire, Swift, Baleno and Ignis have an LED Bibeam Projector. They have LED chips inside them that emit the light. A shield inside the projector controls the low/high function.
The pre-facelift Baleno also has a bibeam projector but with an HID bulb inside (D5S 25W).
Hope it’s clear
Last edited by drhoneycake : 13th February 2019 at 23:20. Reason: Added some more info
drhoneycake is offline
Old 14th February 2019, 10:30   #398
sgiitk's Avatar
Thanked: 4,796 Times
With LEDs coming in the life for HIDs may be not that long. I Predict the LED will be the lamp of the future. The HID will be an intermediate stage. I am sure the cooling system will progressively become smaller.
Prediction may always be tricky - I remember a US General calling the atomic bomb an impossible damf**l trick which will never come about, etc. But I am sticking my neck out.
sgiitk is offline
Old 4th July 2019, 01:04   #399
thirdmainroad's Avatar
Thanked: 2,063 Times
I got myself for my WRV Osram 6000 K HIDs for Rs 11,000 and now need projector lenses. When I went to a local shop in Chennai, he quoted Rs 15,000 for the projector lenses and I ran away. Can someone please guide me on what projector lenses to get that will fit the WRV and also how much they'd cost? I do not mind buying online.
thirdmainroad is offline
Old 4th July 2019, 02:40   #400
Thanked: 80 Times
Try installing a 6amp 400v Rectifier Power Diode on the positive wire side that goes to the ballast.
It is either that or you need to use a better headlamp relay.
Mod Note : Please avoid quoting the entire post when responding
BeingHuman is offline   (1) Thanks
Old 4th July 2019, 08:12   #401
naveen.raju's Avatar
Thanked: 9,063 Times
Try Morimoto. They have different models available online. I would suggest you to contact their support to check which model will suit your car. They have a dealer in Bangalore.
naveen.raju is offline
Old 4th July 2019, 11:09   #402
sidpunjabi's Avatar
Thanked: 128 Times
This turned out to be a ballast issue. Unfortunately, I had to change the fuse as well. Thankfully it was a 2-minute fix since the company gives 4 extra fuses.
It's been a couple of months now, and happy to say that everything is performing perfectly.
Old 4th July 2019, 22:08   #403
sgiitk's Avatar
@sidpunjabi; I bought my hid conversion for the fog from Xenonpro (on the other forum) and I had a problem with one light not firing up after about 15 days. He advised me to swap ballasts and sure enough it worked. He said that lamp failures are almost invariably due to the ballasts, and bulbs last a very long time. A quick swap confirmed it. So I replaced the ballast and it is still going after about seven years. I have 3000K, 55W HIDs in my Civic.
sgiitk is offline   (1) Thanks
Old 7th July 2019, 02:11   #404
Revvliner22's Avatar
Thanked: 24 Times
Hello Bhpians,
I own a ‘14 Innova and I planning to go for sinolyn projectors along with their HID kit. The kit and projectors will be fitted in the foglamps itself. Has anyone used sinolyn projectors and HID kit. If yes, please give me your valuable inputs on the same.
Thanking in advance,
EK
Revvliner22 is offline
Old 7th July 2019, 07:42   #405
Thanked: 118 Times
Originally Posted by Revvliner22 View Post
Hello Bhpians,
EK
I am using IPHCAR fog projectors along with crystal eye HID kit and have no issues with it. I have heard that IPHCAR and SINOLYN projectors have a same design and quality. So I believe they will be a good set of projectors. However, I don't have any idea about the HID kit from SINOLYN.
MrBeast is offline   (1) Thanks
