Old 26th August 2006, 14:08   #46
rareone's Avatar
Thanked: 11 Times
Anyone has fitted a Strut Braces for Santro yet.
If yes let me knw from where.
If no then why not...
rareone is offline
Old 28th August 2006, 00:04   #47
harsh87's Avatar
i have done added a conical K&N and a free flow exhaust with a 1.5" tubing from manifold to muffler
my car has done 165 thats the max i have achieved
harsh87 is offline
Old 30th September 2006, 12:44   #48
hi guys,
i'm sunny and i'm new to this forum.. i'm having a Santro LE 2001 model matallic gray.
i want to modify the exterior of it, say the bumpers, skirts,spoilers etc.
now i request you guys to post some pics of any modded santro so that i can make up my mind on what to do exactly.
n yeah arush, i've seen ur work a lot n i kinda liked it so it's a personal request to you to suggest something...
waitin for your response guys..
san316 is offline
Old 30th September 2006, 13:26   #49
rareone's Avatar
Thanked: 11 Times
i am also desperate to see a modded santro...
someone post some pics & idea's...
rareone is offline
Old 28th January 2007, 17:27   #50
aZa
aZa's Avatar
Thanked: 21 Times
Santro's Tacho issue resolved :D
Santro like many other new cars comes with Dual Ignition Coil Systems (DIS) Due to this the normal 4 Cylinder setting on a aftermarket tacho shows only half the RPM reading.
The solution
1. A tachometer with 2 Cylinder setting, Very easy to connect and takes the rpm from 1 coil only.
2. Autometer/sunpro RPM Adapter, Using this the 4 cylinder setting will show the correct RPM
Harsh and i, both have SUNPRO tacho fitted onto our Xing's and it rocks
For more info check out Sunpro®
cheers
aZa is offline
Old 28th January 2007, 17:38   #51
Thanked: 66 Times
Hey,
one of the t-bhpians, suren181 has modded his santro zip plus.
The mods include:
1. iridium spark-plugs and the corresponding wires.
2. stock replacement K&N air filter.
3. Hijoin HR 5 spoked machined finish 13" Alloys.
4. Bridgestone Turanza 165/65/R13.
Thats it.
And the rocks!
Happened to have a ride recently in the Jan Hyderabad bhp meet.
I thought this is the first time i have ever shifted to 4th gear at 100kmph. Wait another bhpian took it to 115kmph in the 3rd gear, and still the car can be pushed little further, we ran out of road.
kkr2k2 is offline
Old 28th January 2007, 18:10   #52
Thanked: 66 Times
Originally Posted by aZa View Post
..... A tachometer with 2 Cylindersetting, Very easy to connect and takes the rpm from 1 coil only.....
Hey!
Doesnt the tachometer take the engine speed directly from the fly-wheel?
Because the deisel engines doesnt have ignition coil. or may be the setup is different for the deisel engines.
And also, with the ECU in the place, is there any way to get the reading from the ECU?
kkr2k2 is offline
Old 28th January 2007, 19:07   #53
jkdas's Avatar
Thanked: 1,492 Times
aZa ! tacho pics!
kk; santro does 115kmph in 3rd gear .ANd these tachos are electronic. Experts can enlighten more about this.
edit: saw pix. How much does it cost?
jkdas is offline
Old 28th January 2007, 19:46   #54
aZa
aZa's Avatar
Thanked: 21 Times
JKKKKKKKK.... this is a must have yaar!! The MRP is about 170$ but i got it from Ebay.com for 55$ + 20$ shipping. It has a two stage shift light. Very impressive u know
KK : There are ways to get tacho reading, CKP sensor is one , ECU the other but its better not to fiddle around with these.
aZa is offline
Old 27th February 2007, 00:18   #55
JPL
Does anyone has any information on skirts for santro, has anyone installed it, please tell me the price and pics will be helpful.
Thanks,
JPL
JPL is offline
Old 28th February 2007, 17:09   #56
faithless_1984's Avatar
Thanked: 327 Times
hey JPL ,i have side skirts in my car (xing).
paid 2500 for the side skirts and 500 for the installation.
here`s a pic (for more pics check out my garage)
hope this helps.
cheers
faithless_1984 is offline
Old 7th March 2007, 22:36   #57
JPL
Thank you Faithless for the PIC and the cost. And I also checked out your car garage, really cool man. Aologies for replying so late, I had actually forgotten where I had posted this...silly..yeah it is..
Thanks again
JPL is offline
Old 8th March 2007, 23:07   #58
harsh87's Avatar
aZa ! tacho pics!
jkd, check out my garage for the tacho pics, aza got the tacho after i got the same one working on my car
harsh87 is offline
Old 31st March 2007, 09:20   #59
How much will a tachometer cost including installation(for Santro Xing)?
Will it effect/void the warranty? And where will they install it?......i see no place in the dash board......
shashankre is offline
Old 1st April 2007, 19:39   #60
razor4077's Avatar
Thanked: 299 Times
lots of modded santro's... nice to see!
i've done some upgrades to my xing as well, and i must say the car's a different animal altogether.
1. K&N universal conical filter + intake
2. OWS iridium plugs
3. 165/65 R13 tubeless Goodyear's on alloys
4. A kicka** ICE
Car handles very well, even at high speeds (unlike the stock Santro which feels like its about to take off when travelling at over 120). The upgraded rubber takes the credit for this.
Performance has improved considerably since fitting the filter & plugs. Pick-up is better, and i've managed to push it above 160... could have done more, but ran into traffic. That's not too bad, given the stock top speed is 145 as per Hyundai. FE has improved too, by about a kpl or so (and i drive the car pretty hard!).
and finally, the car sounds sweet, in & out
if anyone is looking to upgrade the santro, i would advise them to first upgrade the rubber before fitting the filter/plugs etc. else u'll have a powerful car with terrible handling.
my 2 cents...
razor4077 is offline   (1) Thanks
