Finally the day, when I paid 10,249rs (Rs 9999 + Rs 250) and accepted the delivery of DieselTronic Lite at my home. The most expensive upgrade to the car till now. RaceDynamic did package the courier well and everything was in order. The Stickers and vinyl really looked good and have been applied first. and then there is the wiring harness and the diesel tronic lite box itself. the harness consists of a split end over one end, which has two connectors(Male and female Type). On the other end of the harness is the port to connect the Diesel Tronic Box and then a single wire for power which goes only in the positive terminal of the battery.
I remember in the last post i said that i will try my best to get a performance and acceleration figure on the stock map but, I was so restless and impatient that within half an hour of taking the delivery, i had put all the stickers in place and was installing the tuning box itself. Since it had only one wire for power and it went only in the positive terminal of the battery, my mechanical mind got a bit confused by it, and I had to call racedynamics technical support to clarify the problem. The person said that the wire was correct and only need attached to the positive termicalof the battery without any negative.
Other than that the installation is pretty simple, For my swift diesel, i removed the engine cover and the harness provided is called Type B harness. I removed the wire doing into the common rail and attached it to the female end of the harness, and attached the male end of the harness into the common rail from where the original port was removed. I attached the tuning box on the other end of the harness, and connected the wire to the positive terminal of the battery. Tied everything down but only four tie were provided in the package which were actually small than necessary. i used some other tie which i had and tied down all the other wires, put the engine cover back and i was good to go.
turned on the ignition and the red light on the box started to glow, meaning everything is set. the green light started blinking thrice, which by the instruction manual meant that the box was on P1 mode relative to the single or dual channel box. Of-course i couldn't change the driving mode in this lite box. started the engine and on the first start engine was a bit louder than usual, i expected these changes so i let the engine run for around 10 minutes on idle. after that, it was time to test. the installation took not more than 15 minutes as i did it for the first time. now i can do it within 5. i also took extra 10 minutes just to make sure everything was in order
Moved out of my apartment and started driving in a relaxed manner when i felt the first difference. Engine was running smoother than the stock. drove for around 1 - 2 km to a quite and traffic-free road and made the first pull. There was absolutely no difference at all in the power delivery in either second of third gear. It got me a bit worried for sure as even with a discount of 4000, this was pretty expensive for me and i had high hopes and all sort of emotions started going on in me that this might be a bad decision and then i remembered the amazon 7-day return police, so i guess i was sorted if it didn't work out haha. Took a u turn and accelerated, short shifted into second, and immediately short shifted into third at just 1400 rpm and depressed the accelerator, the car suddenly woke up at 1800 rpm(it had never done than before) and started pulling inconsistently and then dropped at around 2000 rpm or i guess flat-lined and then it woke up at 2200 rpm and pushed me in the seat all the way till 3500 rpm, and then there was the grin on my face, the grin on which i just cant put a price on. There was bump in torque but it wasnt as much as i hoped, i would say by what i felt it was around 7 to 10 percent and not 20 percent as advertised, but yet all the clauses of amazon return policy had vanished till now from my mind, and i made pulls one after the other. The power delivery was still inconsistent between 1700 to 2100 rpm and by inconsistent i mean that engine didn't fell very happy delivering power. But even in this rev range and even inconsistently, the power was more than stock and engine woke up at 2100 rpm. this happened for the next 4 pulls in third gear and then reduced a lot in the fifth and by the time i had driven another 5 km, the power became linear. Torque has increased considerably between 1700 to 2000 rpm and that has increased drivability. And then comes the infamous turbo kick of multijet engine at 2100 rpm which kicks you down in the seat, just more pronounced and raw than before. and its because of the bump in torque in low revs that the power delivery now seems linear than before.
This was just the first drive the first 7 km on diesel tronic. Maybe i was expecting a bit too much as a miracle that will bump the power to 200 bhp and 300 nm torque
but even realistically the bump in power, as of now, is not more than 7 to 10 percent. and even after 10 pulls, the car seems to deliver different amount of power in each pull. From my knowledge i believe that the Tuning box will somehow understand and adapt to my driving style, and will be a even better bump in power to at least what advertised to be 20 percent. and the power delivery is also expected to me more linear and consistent with each kilometer i cover with the box. I will also replace the air filter with a new one and see if i can source liqui moly additive to run with the tuning box. I apologize of not collecting and benchmark performance numbers of acceleration but i am just too impatient for it. even with what it is as of now, i am glad i got it for 9999rs only at a discount of 4000rs. the power bump is very much welcome and expected to increase and to my surprise the engine is a lot smoother and quieter.
I will provide the next update after at least driving 500 km in both city and highway conditions, its just a matter of time before i cover them now
