Been an enthusiast for... forever, I ve always wanted to upgrade my car through various mods. I own a bmw335i and i recently crossed 50000 miles, which means its out of warranty and i can go nuts with it. As i was doing my research, i came across endless number of mods for my car. And there were endless number of tuners who provided different parts.
Because this is my first mod i am sticking to upgrading my ecu maps rather than any actual part, for now. It is cheaper and while i have read about them, i dont have any hands on knowledge about it. Gradually i will get the real stuff. I came across quite a few options for ecu upgrades. There are basically two type, PiggyBack(hardware) and Flash(software). While flash is what most people recommend(because its a software), PiggyBack is much more fun. You can change between different maps on the run and turn it to a map that saves fuel if you are driving in the city. But ofcrse there is a down side, you actually have to open the ecu box and mess with the connectors. Anyways I have narrowed it down to three of them. First of all the stock Bmw 335i
335i has the N54 3.0l twin turbo. It has enough power already but twin turbo means there is a lot of room for even more power.
Stock Power
306 hp @ 5800
300 lb-ft (400 nm)@1400 -5000 rpm
Performance
0-60 mph 4.9s
1/4 mile 13.6s @ 105 mph
Procede V5 by Vishnu tuning
-Piggyback (hardware installed in the ecu unit)
-60-80 whp (90hp on crank) gain on stock car
-60-80 lb-ft torque gain.
-On the fly map changes through cruise controller.
-user interface
-turbo boost psi at around 20psi
-removes speed limiter
-Price- $800
Performance
0-60mph 4.6s
1/4 mile ~ 12.4s @ 115mph
Directflash N54 performance Software by ESS
-Flash ( Installed through obd2 port. No opening of ecu unit)
-60-80 whp gain
-80 NM torque gain
-no on the fly map changes
-no user interface
-around 14.7 psi turbo boost
-Removes speed limiter
Price - $995
Cant find performance figures. But i assume it is more or less the same as vishnu.
JuiceBox4 or JB4 by burger tuning.
-Piggyback (hardware installed in the ecu unit - takes about 35 mins)
-70-80 whp (100hp on crank) gain on stock car
-user interface
-Max turbo boost psi at around 20psi
-does not remove speed limiter
-Price ~ $500
Performance
0-60mph 4.5s
1/4 mile ~ 12.4s @ 116mph
As you may have noticed JB4 and Procede are almost same except for the brand names. And Directflash by ESS is quite different. The reviews for all three are good and people have not had any major problems with them. I have a little concern about PiggyBacks because it actually requires installation in the ECU unit, where as DF is a software.
Please share your knowledge and experience with flash vs piggyback. Also help me decide among these three brands or any other for that matter. Although i have researched most of them from dinen to giac to cobb.
I am leaned towards jb4 just because of great reviews and price.
I am planning to install it next weekend.
Here is the installation link for jb4, its pretty straight forward.
