Re: Fleet Admiral Togo Heihachiro - Toyota Fortuner. Life Sails On... Quote:
Originally Posted by dot All these bunkering discussion brought back a very old memory. That too, it occurred when I was taking a siesta today. During childhood days we used refer a petrol pump as "petrol bunk". I knew lots of folks in Cal who used to say this. Never understood why. With the course of time the word went out of usage and out of memory. Feeling good to recover a lost bit. Thanks H.G. |
Hi dot, True that than word 'bunk' would have come from the word bunkering - because bunkering was originally used when ships took on coal as fuel to fire the furnaces/boilers and it continued when coal changed to oil to fire the furnaces/boilers.
Of course in my school days all I could think was of 'bunking' which had a far more adventurous feel to it ! Quote:
Originally Posted by Ricky_63 As a long standing habit I usually top up around the half tank mark. Vapourizing never came to my mind, but my reason is that running to a near empty tank will also damage the fuel pump as it would take in muck from the bottom of the tank. Not that it has ever happened to me, but I know of instances in people's cars where the fuel line was chocked on old-ish cars.
Cheers |
Hi Ricky, In the earlier days the half tank filling practise used to serve another useful purpose - as told to me by old army hands. It used to prevent rusting of the upper half of the metal/steel fuel tanks if perpetually filled. Because air/vapours could accumulate in the upper half leading to rust flakes being formed and dropping into the fuel.
Resulting in of course, if the dregs of fuel of a near empty tank were sucked in by the pump, choking of the fuel lines . if you remember the earlier vehicles - Ambys, Jeeps etc used to after ceratin point in their life have constant issue of fuel line chokes. So much so that fauji vehicles always used to have neatly stencilled on their fuel tanks date of last tank cleaning, due date of next cleaning etc ! They had to infact get the insides painted/ corrosion proofed through a method.
However with the advent of use of heavy duty plastic in most of the mordern day vehicles - the issue of rusting of fuel tanks may have been sorted out, but in India the issue of sediments in the fuel still remains. This was mentioned by you. Basically muck which comes in through fuel, dirty fuel bunk nozzles and stuff. That still could choke the lines. Quote:
Originally Posted by Off Roadie @ Guderian
Aha so good to hear the word bunkering, since my dad and I are sailors, that's the only word we use. Really good tips on the refueling front, we follow the same practice, except that we end up refueling late at night, instead of early morning. Very true about tanking up when the needle is at the halfway mark, had noticed that due to self observation a few years ago only to realize it was a known fact among enthusiasts. |
Aha there Rohan ! I thought that should evoke a response from you and it did.
Trust the foot's mending well and the Scorpio is all set to roll. |
