Sunday Musings ! March 20, 2011
It has been almost a month since I had suspended my ol' Sunday routine. Thanks to the excitement of bringing in the Admiral and settling down with him. But I knew I had to get back to the routine sooner or later. And that was today. Holi day. Started early before the barbarian hordes descended with their chemical colours !
And what is this Sunday routine all about ? Allow me to Ctrl C Ctrl V what I had written earlier in my piece about Guderian the Scorp. Please do grant me the poetic license (Licentia Poetica) for substituting the then warrior's name with the current and few other mish mashes:
"Ahhh...Sunday morning ! Believe me for me it's a great stress buster and the family loves it too - as I am out of their hair for almost 2 - 2.5 hours !
Let me best describe in seriatim the activities:
1. Go down to Wolfslair (errr...my name for Admiral's parking lot) with all my equipment - which includes tool kit/s, cleaning equipment (bucket/cleaning liquids etc), inflator etc. Getting ready to tackle the Sunday morning task itself is quite a R-Day parade. Start at 6.30 am.
2. First start of with the tyres. I check the air pressure with my pressure gauge and fill in air if required with the digital inflator. Maintain a pressure of 37 PSI. Loose about 0.5 PSI every second week. Once in 2 months lower the spare tyre and check pressure. Inspect all the tyres thoroughly for foreign objects like nails etc etc.
3. By this time the GDW (Gaadi Dhone Wala) reports in and starts the weekly interior cleaning. Rest of the week he does only the exterior. After the interior he goes on to the exterior.
4. My next action is to open up the engine bay and start the water cleaning of the entire engine bay. Living in Mumbai and running the beast for almost 100 KMs a day works wonders on the appearance of the bay by the end of the week. Dusty, mucky and tired looking are mild words ! I use plain water and super absorbent cloth to clean up the engine bay and the sorrounding areas. Force splash water through the grill area to keep the radiator and sorroundings free of muck and it helps the engine cooling.
5. Check the battery area and connections.
6. Inspect engine bay thoroughly for loose wires, tubes etc and fasten them. In the vehicle there are many wires with harness and a fire retardant factory fitted wrapping which over a period of time gets undone and brittle. Perform surgery on them - remove the dead and dying wrappings, tie back the remaning and neatly wrap it with Steel Grip tape. Also all connection ends which turn bare are 'Steel Gripped' !
7. I pick up one major task in a week (on a monthly/quarterly schedule) - Could be - check all nuts and bolts in engine bay and tighten, check all U/C nuts and tighten, check all interior nuts and bolts (seats etc), vacuum interiors, check internal wirings, remove NVH cover and check the CRDe entrails, cleaning up the seat covers etc etc.
8. Check all fluids - engine/brake/clutch oils/coolant/spray wash water levels.
9. Check under chasis condition for drips, leaks etc and overall look out for visible sign of abrasions, wear etc of moving parts.
(I hope I don't have to much here with a Toyota !)
10. Check out for specific issues if any that would have surfaced during the driving in the past week.
(I hope I don't have to much here with a Toyota !) - We are getting repetitive here aren't we ?
11. On the Sunday after the periodic servicing ( I usually take the vehicle to the ASC on a Saturday) I spend more time ! Rechecking all activities carried out and looking out for loose nuts etc and cleaning up the mess left behind by the grease monkeys...dirty seats, waste cotton and other by products of careless work, though I stand on the shoop floor !
(Haven't experienced this with the Admiral !)
12. Finally the exterior check. All minor scratches etc are covered by paint pen, if needed !
I am done in about 2.5 hours. And how time flies...when with the beast !
Believe me this weekly caper helps me to keep the beast in fine fettle, besides also knowing exactly what needs to be done at each periodic visit to the ASC without allowing them to do any pointless and often wrong diagnosis for noises, engine work (if any) etc.
Also maintain a fairly meticulous tracksheet on XL for the vehicle maintenance/service points/expenditure etc etc.
And of course there is plenty of music playing in the background !
Monday is such a pleasure to drive - in a fresh smelling vehicle !
And what did I do today ?
A. Firstly checked out the tyres & inflation levels. And therein lies a tale. On the date of delivery I had asked the A.S.S. chaps specifically the air pressure levels and it was assured to me that it was at 32 PSI. A week later just before the long drive south I checked it with the gauge and my hair stood on its ends when the front right tyre showed 48 PSI and the others 44 PSI. The max recommended cold tyre pressure by the manufacturer is 51 PSI. I can well imagine, on the high speed highway run, if I had a blow out - the results which would have followed !
Reduced it to 40 PSI all tyres then and today further reduced it to 37 PSI. May further drop it after I experience the comfort level. The recommended pressure is 30 PSI. Lowered the spare tyre and found it today to be at 44 PSI. Reduced it to 40 PSI.
Here is the nifty inflator I use:
B. Cleaned up the entire engine bay. I love a clean and sparkling engine bay at all times. Hate grease, oil stains and dust in the bay. Firstly it obscures any signs of trouble and secondly it looks terrible. After last Friday's dust grind, it took me some time to get it to my level of liking:
Now neat and squeaky clean:
C. Had some time and so pottered around and found few more devices and delights in the Admiral which I had read about in the manual but hadn't laid my hands on:
The 12V power at the rear. Helped me a great deal when using the inflator today on the spare wheel.
Cupholder for the rearmost seats.
Again for the rear most passengers. What shape is that ?
Even these for them
![Fleet Admiral Togo Heihachiro - Toyota Fortuner. Life Sails On...-dsc06756.jpg](https://www.team-bhp.com/forum/attachments/long-term-ownership-reviews/521001d1692339107t-fleet-admiral-togo-heihachiro-toyota-fortuner-life-sails-dsc06756.jpg)
Pity the poor sods on the rearmost seats. They must be real desparate to travel on those. Cattle class of the Admiral !
Nifty cup holders for the middle row - ultimate proof that the middle row is only for couple of blokes. And that third seat there is as mythical as the lost city of Atlantis:
Height adjustable seat belt for the driver:
And for the front passenger even though the seat is not adjustable for height.
![Fleet Admiral Togo Heihachiro - Toyota Fortuner. Life Sails On...-dsc06746.jpg](https://www.team-bhp.com/forum/attachments/long-term-ownership-reviews/520993d1692339088t-fleet-admiral-togo-heihachiro-toyota-fortuner-life-sails-dsc06746.jpg)
Does this mean overseas this seat too is height adjustable and here for cost saving it........nope, I ain't talking anything no more.
The middle row slides back !
The rear has bag hooks:
![Fleet Admiral Togo Heihachiro - Toyota Fortuner. Life Sails On...-dsc06741.jpg](https://www.team-bhp.com/forum/attachments/long-term-ownership-reviews/520996d1692339107t-fleet-admiral-togo-heihachiro-toyota-fortuner-life-sails-dsc06741.jpg)
Who says the Admiral cannot be sailed to fetch groceries would be the LoH's Q were she to spot it. Must think of alternate uses. Errrrr.....to hang underclothes to dry, on long distance non loo/non shower trips ? Good one Jeeves ! Bertie would be so mighty pleased !
The mid row AC control and vents:
Even the simple stickers are from:
Cup holder for the driver and front passenger:
I paid for it - so I guess I'll duly fall in love with the glove box and the wood inserts ! Ai yai yaieeeee !
D. A new toy I picked up recently. Boon for long distance travel.
E. Something that I wouldn't ever travel without ! My fave multi purpose tool - Leatherman Wave:
Next week possibly shall put up a piece on some of the tools and tackles I have collected from all across the world. Some which I carry in the vehicle all times, some carried only on long trips and some used specifically but never carried.
Why do I do this ?
Because I believe in getting to intimately know every little little bit of the machine I own and run around in, because I do not like unknown elements, because......
Because I am a little touched up there !
You mean crazy ?
Uh huh !
