Old 28th July 2011, 09:50   #91
v&v
v&v's Avatar
Thanked: 1,234 Times
re: Skoda Octavia vRS - 12/2004 - Diamond Grey - Update @ 46500 kms
Now its going to be a year and no major issue with my vrs. Average is 9+ for 11000 kms considering 90% of it was city drive.
Last Sunday was DIY day. Workforce : Me, my son and daughter .
Agreement : Dinner at McDonald.
1. Cleaned MAF sensor : Ajmat thread was very helpful.
2. Air filter : Cleaned
2. Cleaned Sun roof : Cleaned drain and lubricated the channel.
3. Replaced fuel filter : Call update the local mechanic to do the job. Rs 100/-
4. Seats Waxed
MAF Sensor cleaning : Opened the air filter case and MAF sensor can be removed. Clean it with Rubbing Alcohol. Re-fit.
Skoda Octavia vRS - 12/2004 - Diamond Grey - Update @ 54000 kms-08062011603.jpg
Skoda Octavia vRS - 12/2004 - Diamond Grey - Update @ 54000 kms-08062011605.jpg
Skoda Octavia vRS - 12/2004 - Diamond Grey - Update @ 54000 kms-28072011905.jpg
Sun roof : Rail was lubricated with engine oil. drains were cleaned by pouring water. Luckily no blockage.
Seats were waxed with ArmorAll.
Skoda Octavia vRS - 12/2004 - Diamond Grey - Update @ 54000 kms-28072011906.jpg
Fuel filter : Only 1J0 is compatible not 1H0.
Skoda Octavia vRS - 12/2004 - Diamond Grey - Update @ 54000 kms-09062011610.jpg
v&v is offline   (2) Thanks
Old 20th August 2011, 14:40   #92
v&v
v&v's Avatar
Went today for throttle body cleaning : Wheelforce Center at Rajouri garden.
Symptoms : EPC Light randomly or some times rpm used to fluctuate between 700 & 1200.
Time taken : 2 hrs.
Jobs done : Complete cleaning of throttle body manually and in a throttle body cleaning machine. Adaptation via their ESItronic scanner and general checkup of car.
Charges : Rs 1200/-
Car is now more responsive and smooth.
One more thing i came to know from them is when the rpm fluctuate there will also a probability of hardening of brake paddle too and will become non-responsive. This will occur mostly when the car is in idle or in bumper to bumper traffic.
v&v is offline   (1) Thanks
Old 30th August 2011, 19:31   #93
v&v
v&v's Avatar
Today service indicator started flashing. Checked the users manual and its mentioned on page 70 about how to reset.
Here is how it need to be done
1. with switch off position ignition press the reset knob of trip meter.
2. Switch on
3. you will find service written
4. Turn right the clock adjust knob once.
5. switch off ignition
you are done.
Old 19th January 2012, 16:48   #94
v&v
v&v's Avatar
Update @ 44000 kms
No major problem since August 11. The dicky struts has failed last month. Some times it falls randomly when opened. I had enquired at Metro spares (Malviya nagar) was out of stock and told me try after 1st week of Jan. Enquired today , in stock and got it really cheap for just Rs 900/- (pair).
Rajnath Auto was quoting Rs 1250 per strut. This is manufactured by pune based company. Will post photo soon.
Installation is pretty easy. Remove the U clip from the top end of strut using a screwdriver and little pull will disengage the strut the nut. You can fix the new one in the same way.
I got it fixed from the mechanic available near the shop. Time taken 10 min. Paid him Rs 100/-.
Other jobs due are - Oil change & front brake pads change. May last another 1000 kms but wont take chance.
v&v is offline
Old 19th January 2012, 16:57   #95
mobike008's Avatar
Thanked: 17,095 Times
4000kms in 10 months? Thats pretty low running. Seems like this is not your primary car!!!
mobike008 is online now
Old 19th January 2012, 17:30   #96
rxpaul's Avatar
Thanked: 141 Times
Originally Posted by v&v View Post
Current update, Since the pointer was towards throttle body, i used system G.
Have driven around 500 kms. Every thing is back to normal.
What is system G ? Also is injecter cleaning a DIY job.
rxpaul is offline
Old 19th January 2012, 17:40   #97
v&v
v&v's Avatar
YUP , primarily a stress buster . I use my Safari and my office vehicles for commercial needs.
IFTEX System G is a fuel additive to keep injectors and manifold clean. Use it once every 1000 kms.
Here is the link : IFTEX OIL & CHEMICALS LTD.
v&v is offline
Old 19th January 2012, 17:56   #98
Durango Dude's Avatar
Thanked: 5,210 Times
@v&v: Nice to read this thread. One thing is clear is you don't just own a Skoda you need 'deserve' it. I think at the end of it this ownership you can start an independent garage for 'troubleshooting' Skoda vRS. I appreciate all the effort going into the upkeep and still things keep cropping up now and then despite the low running. Your Skoda makes one helluva weekend paramour, lol. I appreciate all the love and car you have lavished on her.
Durango Dude is offline
Old 20th January 2012, 06:51   #99
v&v
v&v's Avatar
Thank DD. Well said! Managing this beast is a pain but worth every penny. One drive and it make you forget all issues.
Every car has its issues but for RS being a Skoda being amplified much more than others. All it needs is timely checkups to keep it in top slot.
v&v is offline
Old 23rd January 2012, 09:19   #100
v&v
v&v's Avatar
Photographs of Dicky Struts.
Old one with C clip which holds/locks the Struts.
Skoda Octavia vRS - 12/2004 - Diamond Grey - Update @ 54000 kms-230120121824.jpg
New One - Made in india
Skoda Octavia vRS - 12/2004 - Diamond Grey - Update @ 54000 kms-230120121823.jpg
Also got the front brake pads changed on Sunday. The old pad were almost finished.
Brand : Pagid
Cost : Rs 3000/- inclusive of fitting
Done at FNG : Near Vikaspuri - A Skoda Specialist, Keeps spares too.
Time : One hour
Skoda Octavia vRS - 12/2004 - Diamond Grey - Update @ 54000 kms-220120121818.jpg
Old 30th January 2012, 13:14   #101
srinath1965's Avatar
Thanked: 11 Times
Originally Posted by Ardy View Post
Congratulation, v&v.
The car looks really neat. vRS is indeed a fantastic ride and I am sure you are going to love every moment of owning the beast.
The vRS guru has already suggested quite a few things that you need to look out for.
2 cents from my end based on my experience with Skodas and service centers:
There is really no way of checking the condition of the timing belt. In fact, this is exactly what the SA at the service center had tld me when he was suggesting the timing belt change for my Octavia at 75K and I asked him to check the condition. His response was "Sir, it is recommended to be changed at 75K and there is really no way of telling how much more would it last. But, if you want we can change it at the next service". My Octavia has now clocked about 78K and I plan to address timing belt replacement at 85K. Bottomline, if you think you want to change, go ahead. Also factor in the fact that the car is close to 6 years old and the timing belt may have become brittle due to not being in use much.
I have been using System G once in every 2-3 gas refills since last 15-16 months and I have really not faced any issued. Started using it after my engine mis-fired in last June and it was attributed to bad fuel.
In addition, also please check the secondary radiator fan. They are weak links as well. You may not face any issues right now if the secondary fan is not working and my not even realise that its not working. But come summer, if the fan is not working, then the car would tend to heat up.
Cheers,
Wow Ardy,
I blwe my Timing Belt. Car just came back with a bill of INR 1,60 lacs includes a new battery as the car was in garage for 60 days (No spares in India) and mileage has dropped to 4KMPL.
Srinath
srinath1965 is offline
Old 30th January 2012, 15:05   #102
v&v
v&v's Avatar
Originally Posted by srinath1965 View Post
Wow Ardy,
Srinath
1.6 L , what all were the damages ? After a rebuild why 4 kmpl ? Where did you get it repaired ?
v&v is offline
Old 30th January 2012, 15:28   #103
ashish22's Avatar
Thanked: 102 Times
@V&V So you went to Nitanshu's work shop to get the brake pads job done! He has amazing knowledge of Skoda cars and the RS in particular.
@Srinath They might not have set the tappets rightly or is there one? Also let the engine bed in properly as it might produce heat due to new metal friction. Have you experienced any loss of pickup?? Also i would suggest the oil change in next 1000-1500 kms.
ashish22 is offline   (1) Thanks
Old 30th January 2012, 15:35   #104
v&v
v&v's Avatar
YUP for these quick changes he is good. Rates are bit high as Metro Spares at Malviya nagar had quoted 1800/- for pagid. has good knowledge of RS.
How about your RS, is it still there ?
v&v is offline
Old 30th January 2012, 17:46   #105
rxpaul's Avatar
Thanked: 141 Times
Wow Ardy,
Srinath
Oops....so how much (km) had your RS done when the belt blew ?
rxpaul is offline
