Originally Posted by krish3 Is the figo tank a 45 ltr one? Our Fiesta regularly shows 835 + on its DTE when we fill the tank.
I dont think low running affects the mileage much. It might have something to do with the traffic/driving habits maybe. Make sure you are using the torque of the engine to get ahead rather. Mostly for just rolling traffic, I just use the clutch to start moving. After that all pedals are left free unless absolutely required. |
The tank indeed is 45 ltrs. The Figo Engine is a BS IV one and AFAIK it has got a Diesel Particulate Filter and a lager Catalytic Converter than the BSIII Fiesta Engines. Probably these are the reasons for the lower DTE readings as well as the huge margin between FE for Short runs and Highway runs.
Would be interesting to see the DTE readings on full tank for the new BSIV Fiesta. Quote:
Originally Posted by RGK Gr8 Gemi. Nice to read your detailed post. Could you pl tell what are the things they have done during 10k service apart from the regular oil change. Have you done tyre rotation (min of 2 times). |
Apart from Oil and Oil Filter Change they have done tyre rotation also.
[quote=anilisanil;2085122]Thanks Gemi for the detailed report. Did your squeak problem vanish? Unfortunately mine refsurfaced!
Mine resurfaced once after a wash. Now when i get an underbody wash i make it a point to ask them to grease that cable that causes the squeak. Quote:
Originally Posted by ownerofazkaban Hi Gemi,
My Figo does 80kmph @ ~2000rpom,
100kmph @ ~2300rpm
and 120 @ ~3000+rpm.
All readings with A/c
Is this Normal ?
Time again am struggling to push over 120 on highway [keeping rpm below 3.5k) as the car hits ~3500rpm and I don't feel like pushing the rpm beyond since its only been around 7k on ODO. |
Mine does it exactly at those rpm readings. You would surely feel the engine out of breath above 120 since the torque starts falling drastically after 3K rpm. It is quite normal for the Ford TDCI engine. With 7K on the ODO you need not be worried of pushing her. Just ensure that you dont stick to redline rpms for long. Quote:
Originally Posted by Captain Slow Gemi,
You are lucky to have got the chrome bar. These guys still havnt managed to get me one yet
Any of you guys have issues with the breaks on your figos? The cars front breaks make a lot of sound while breaking. My car has done about 5,500KM. |
I was just lucky. And it was the goodness of the service engineer to give me the one from his car since could not visit them the next day.
The brakes make quite a lot of noise at slow speeds especially. I pour water through the holes on the front rim to remove the break pad dust. It temporarily solves the problem but the sound comes back after around 150km. Do let me know if anyone gets a permanent solution. |
