Old 25th September 2012, 23:59   #271
krish3's Avatar
Thanked: 192 Times
Re: Rocket Hatch - Dark Grey GETZ CRDI. EDIT: 1 yr, 15k kms + report.
I'll be back this Saturday. Will get it checked and then get to know the details. Will post the findings here
krish3 is offline
Old 26th September 2012, 20:31   #272
kpzen's Avatar
Thanked: 1,882 Times
Very simple, change your A.S.C , it works best at times
Usually our Getz CRDi gets serviced at Advaith Hyundai, but they have got a little lax off late, and i decided to change it due to 2 reasons, one being the former and second being the location, the new one is close to my place. LAKSHMI HYUNDAI.
Brand new facility on the B.I.A.L road, bang opposite Columbia Asia Hospital , Next to Cauvery Medical Centre.
Got it serviced for 35,000 kms periodic service + Clutch plate Change + Pressure plate replacement + Releaser Bearing replacement . Bill touched Rs 21,000/-, but got some discounts and had to shell out Rs.19,004/-
Overall, a very good job done and delivered On time.
Hi Pavan,
Nice to hear about a happy service experience with HYUNDAI.
Any reason why clutch had to be replaced at 35k kms ?
kpzen is offline   (1) Thanks
Old 26th September 2012, 23:25   #273
Thanked: 2,557 Times
Hi Pavan,
The first 28,000 kms was driven by a lady 75% and her short husband for 20%. The rest 5% was screwed up by us
So now the CRDi is as good as NEW after its 35,000 kms service. Do let me know if you need help once you are in Bangalore
PAVAN KADAM is offline   (1) Thanks
Old 1st October 2012, 15:59   #274
krish3's Avatar
Thanked: 192 Times
An update-: I got the car checked, in my presence, at Popular Hyundai. There was no problem with the Accelerator Position sensor. A simple lubrication did the trick.
Apart from that, 2 issues have cropped up
1) The windscreen spray doesnt work
2) There is a shuddering in the brake pedal and steering when braking from speeds above 120kmph.
Any idea what needs to be checked for the 2nd point?
krish3 is offline
Old 1st October 2012, 17:26   #275
Thanked: 176 Times
krish3 - This mostly happens due to wrapped brake discs. Solution is to repalce them. Other option is to get them faced at a lathe shop if the wrapping is not much. Minimal facing (say <1mm) is okay, however should be done by experienced person to maintain same disc thickness for both discs. Please also replace brake pads under either option or else problem will come back soon. Also please bed in new/ faced discs properly for else you will again face the issues soon (http://zeckhausen.com/bedding_in_brakes.htm).
You could also start with cleaning brake pads/ disks and rear drums and see if it helps, chances are less though.
Hope this helps.
amit1234singla is offline   (1) Thanks
Old 25th April 2014, 11:52   #276
Jimmy_u's Avatar
Thanked: 115 Times
Hi
Hi ,
I have been on a lookout for a used Getz CRDI and through a friend got a reference to a car ,specs as below.
Year-2008
KMS - 64000
Major Work - N/A
Single Owner
No Accidents
Alloys + ICE
the asking rate is approx 3.5
Can you please share from your experience what items should I be looking at , will be seeing the car on Saturday.
Can you please advice on any check-list which would list things that would be replaced in the 60k service , this would help me understand how much will be the immediate damage if I go in for this purchase.
Thanks for the help in advance.
Jimit.
Jimmy_u is offline
