Closed Thread
Old 16th May 2011, 17:30   #526
headers's Avatar
Thanked: 559 Times
Re: Letz Getz Started (Hyundai Getz CRDi)- UPDATE: 40000, new alloys, tires!!! (page
Originally Posted by ph03n!x View Post
This might be just me, but I believe that the more fuel you have in the fuel tank, more the pressure in the fuel lines, and the easier it is for the fuel pump - it has to pump fuel into the common rail, generating 1350 bars of pressure.
LOL, ok, where is the fuel pump located? and
headers is offline
Old 16th May 2011, 20:20   #527
Vdrive's Avatar
Thanked: 20 Times
@ ph03!x : Wasn't aware of that tech side. Yes, the gravity plays there and more the quantity more the pressure. But with modern fuel pumps, it shouldn't be a problem either. Now, a little confusion..
Vdrive is offline
Old 16th May 2011, 20:47   #528
headers's Avatar
Thanked: 559 Times
WHAT, OMG, you serious Vdrive? Does it mean the vehicle makes more power with a full tank?
@Jayanth: Lets Drag - Me with 5 litres only and you with a tankful to understand who is faster in the same car !
headers is offline
Old 16th May 2011, 21:03   #529
Vdrive's Avatar
Thanked: 20 Times
Is it not so ? But I have heard my friend also saying the same with his Scorpio. He says it is a tough job to get it right again after running lean or empty . So I think the fuel pumps after low pressure have to be pumped up again. But if it has to do anything with gravity...
Vdrive is offline
Old 16th May 2011, 22:49   #530
ph03n!x's Avatar
Thanked: 6,079 Times
Forgive me Mr. Thalais... But this is what I learnt from our Pondy trip. The conversation, IIRC, was between you and Suyamariyadhai Kadhalar. Or the D-BHPian?!! Dont blame me for what I learnt from your "after you-know-what" talks
But, irrespective of logic and reasoning, I would still ensure I have at least a quarter tank of fuel
ph03n!x is offline
Old 16th May 2011, 23:23   #531
ph03n!x's Avatar
@Headers - Another point I remembered from "that night's discussion by the sea shore". Water condensing in the Diesel tank as the fuel goes down from full...
ph03n!x is offline
Old 17th May 2011, 06:37   #532
headers's Avatar
Thanked: 559 Times
I think you've mixed up issues. But this full tank and gravity stuff is not correct IMO.
Water condensing into the diesel tank as fuel goes down etc is a different subject matter and it is better to keep more than 1/4 tank of fuel. But it has NOTHING to do with pressure and gravity in the cars of todays age!
headers is offline
Old 17th May 2011, 21:54   #533
ph03n!x's Avatar
After a good drive to Coimbatore, the rocket needed a good wash. Our flats in Coimbatore has a dedicated bay for car-wash, complete with a hose for high pressure water wash. After I nice wash of the black beauty's exterior, I took out the door mats - rather opened the doors to do that...
And Holy Crap! The front co-driver side foot well's rubber mat is filled with water - the car's OEM mat, the rubber mat - all under an inch of water!
Good that I washed the car in high pressure water. Good that I found this issues now. For the uninitiated, this is a known problem - if the drain for the windshield gets blocked, water tends to seep in to the passenger side foot well. I guess the fresh air intake vent does it - could be wrong.
Will take it to my A.S.S after I get back...
Looks like this is a topic for President
ph03n!x is offline
Old 20th May 2011, 11:56   #534
kpzen's Avatar
Thanked: 1,878 Times
My car with petes.
Letz Getz Started (Hyundai Getz CRDi)- UPDATE: 40000, new alloys, tires!!! (page 30)-090520111859.jpg
kpzen is offline   (1) Thanks
Old 20th May 2011, 12:05   #535
krish3's Avatar
Thanked: 191 Times
Pete's... here I come
Didnt know adding a tuning box would make a difference in RPM Vs Speed equation.
Prajesh-: Can you please click the 100 kmph pic without Pete's in your car?
krish3 is offline
Old 20th May 2011, 13:07   #536
headers's Avatar
Thanked: 559 Times
@Prajesh aka KPZEN: Does only 100 @ 2000 rpm. Where does the engine redline and whats the max you've reached?
headers is offline
Old 20th May 2011, 16:51   #537
planet_rocker's Avatar
Thanked: 426 Times
if you look closely - water seeps in from the extreme left corner from behind the dash board on the passenger side.
small DIY - take out the wipers - open the hood - unscrew the plastic cowl and check the LHS corner behind the cowl for traces of leaves / dirt - get the muck cleaned.
We had the same issue in our Getz Prime.
planet_rocker is offline   (1) Thanks
Old 20th May 2011, 21:47   #538
ph03n!x's Avatar
Thanks mate! This is exactly what I wanted to know, yet was not looking hard enough - will do this in the weekend. And yeah, the leak is bang from where you said!
My car with petes.
Attachment 548157
That's exactly what I was talking with Prajesh - never thought Pete's would alter what the car achieves at a certain RPM. Gave up raking my head!
Thalais - we sometimes choose to fly low - more like cruise
ph03n!x is offline
Old 20th May 2011, 22:03   #539
Thanked: 426 Times
the cowl comes out in two parts and has grooves where they sit on each other. you may need a pressure wash to force the muck through the rain channel. take care of the jacket that covers the wiper motor / fresh air intake vent. its quite easy and shouldn't take more than 30mins.
Old 20th May 2011, 22:13   #540
kpzen's Avatar
Will do that.
Redlines at 4500 RPM.
210kph (slope helped)
200kph (Mum- Pune expressway)
If its blocked, you will see water inside the plastic cowl.
kpzen is offline
Closed Thread
