That's the mileage clocked by my Alto-LXi on May 24, 2009 exactly a year after I bought it.
Since January 2009 and after the 3'rd service, the car har run about 5,000 kms, so when I got a letter from my my usual M.A.S.S mentioning about a free check up camp on May 24, I was happy because she would get a free check up exactly a year after I bought her.
So, took the car to the M.A.S.S at 9.15 am and was 6'th in line as a few cars had reached there earlier. Met Mr. Satya Prasad the customer care manager and Mr. Thimme Gowda my usual mechanic. Car was given a through check-up that included all components under the following areas:
- Under chassis
- Engine compartment
- Electrical circuits
- Body inspection
The brake fluid and coolant were topped up for free and in the end they gave the car a good wash and a free emission test certificate. I made a mention to the mechanic not to top up oil (if there was a need) as I was running on Mobil 1 fully synthetic 5W 50.
I met Mr. Vijai Babu my service advisor who normally takes care of my car and he mentioned that the car looked fine and that my next service was due at 20,000 kms.
Clutch Failure/Replaced under warranty @ 14,345 kms
Now, let's rewind back a few weeks to May 4 and 14,345 kms. Driving home one evening, my clutch gave way and failed. After a few anxious moments, this was replaced the next day free of charge under warranty.
Thanks to Mr. Thimme Gowda who put his foot down and insisted that the clutch failed because of a defective component whilst an unscruplous service advisor had other ideas and blamed the failure of the clutch on bad driving/too many people driving the car.
The SA (not my usual one) was lucky as he told this to my dad and my driver who had taken the car there to get the clutch replaced on May 5 a day after it failed. I would have blown this guy's head off head he made this accusation to my face as the car is only driven by me
Overall Fuel Efficiency
The car's FE seems to have settled into a steady rhythm since the switch to Mobil 1 at the 10K service. I made the switch to Mobil 1 more so for the increased protection offered rather than for an increase in FE.
The best FE I have got thus far as as below
- 24.04 kmpl (at the 6,000+ kms mark) on the highway
- 19.43 kmpl (at the 3,600 kms mark) with a mix of 30% city and 70% highway driving
- 19.09 kmpl (at the 14,000 kms mark) in the city
The FE in city drives usually hovers between 18 and 19 kmpl. To sum up the overall FE for the past year-The car has covered a total distance of
15,202 kms
(as per my last fill) and consumed
829.22 litres of petrol, which gives me an overall figure of
18.33 kms to every litre of unleaded that went into the tank.
Switch to Mobil 1 fully synthetic engine oil
On having read all about synthetic oil and the benefits, I was contemplating between OWS and Mobil 1 fully synthetic oil. I finally made the switch to Mobil 1 5W 50 at the 10,000 kms mark. I have now covered over 5,000 kms on this oil.
The difference in performance of the engine was astounding in the intital days after I changed the oil, but since then I have gotten used to it. The engine has now run 15,400 kms and is noticeable smoother and more eager revving. I have noticed that it takes a shorter time to come up to optimum operating temperature on a cold start and under extreme conditions in city traffic, the engine runs smoother.
Before the 10K oil change I changed the oil twice at 1K and 5K kms respectively with mineral oil at the M.A.S.S and on switching to Mobil 1, the difference was clearly evident- a smoother, quieter, free revving
(especially with the AC on) engine.
In terms of mileage, I can't say that I have noticed a big change, but since the change to Mobil 1, there has been a very marginal increase in the overall FE of the car.
Overall, I am very satisfied with the performance of the oil despite the higher cost involved. I will be sticking to Mobil 1 for all future oil changes and recommend it to others.
Overall Maintence over the past year
I maintain my cars in perfect condition. A light wash every two days, a full wash and vaccuming of interiors every week and a full shampoo wash, under chassis wash, waxing and polishing every two weeks is a strict military regime that I follow. Since I have completed one year, I used a Gulf AC Neutralizer and cleaned the AC ducting and cooling fins last week.
After the check up last week, I opened the bonnet and noticed some rust starting near the battery compartment which had leaked a few months ago, so I sand papered the area and used a can of com paint to cover the damage putting an end to the problem.
Some of you may think I am crazy, but last week I got out my tool kit from home and spent close to one hour inside the car tightening all the nuts, bolts and screws. I dismantled the glove box and tightened all the mounting points of the AC and zip strapped up all loose wires and wiring harnesses underneath the entire dash area. The end result - a quiet cabin void of any squeaks and rattles.
I maintain my tyre pressures at 31 psi all round and have a wheel balancing, alignment and rotation done every 5,000 kms and have not had any troubles with the MRF ZVTS rubber thus far apart from occassional tyre squeal during spirited driving.
Final Verdict Year 1
I am fully satisfied with the car and its performance over the past year, apart from the one time when the clutch failed, I have not had any other problems. The car starts up and performs day after day and is very reliable.
I have taken her only on one long trip to Trivandrum and back last Sept. Abhi's travelouges inspire me to take her on a long trip
(akroy) but I have not found time due to pressing demands at work.
The services at the M.A.S.S
(Mandovi Motors Gorguntepalya) has been good, as I used to take my previous cars there and have built up a rapport with the SA and mechanics over time.
Yes, I do have a few gripes too like a slightly cramped cabin with 5 people onboard, a slight lag in terms of power delivery with the AC switched on
(the amazing cooling make me forget about it at times
) but I know I cannot complain at this small wonder as I know I can't get a better car at this price.
I am posting pictures of the following:
- FE stats at 15,202 kms
- FE bar graph
- Pic of the car after a year (will upload more soon)
I am open to your comments, suggestions and brickbats
Mods: Please update this thread name to "Maruti Suzuki Alto LXi--15,000 kms Ownership Review".
Thanks,
gpa
