Originally Posted by jkdas Try the setting in the HU. Play it at 12-15-17 to 'hear bass' |
Tried everything. I am comparing it against my indica which has Pioneer HU, 2 coaxials on the rear tray, and 4 speakers on the front.
Originally Posted by Steeroid Congrats, Tanveer. Sad to hear of your blown fuses and stuff - this should've been picked up by the Dealer if they had tested the car before delivery. Did they just clean the car and deliver to you? This however is no excuse for QC at the factory! |
Thanks steer!
The did a TD, a pretty long one. I also drove around for 15-20kms with and without parking lights on, and after that the fuse blew!
My sump guard is slightly tilted, too. I went through the same rigmarole with my dealer.
At full lock, most power steering units make a bit of noise. At full lock, though - not approaching full lock.
I think you're going to have a lot of questions.
In mine the hissing starts near full lock, not at full lock. Guess first service tome it is!
Originally Posted by aaggoswami Congratulations.
Great narration. But in reality it would have been more irritating.
The small niggling issues clearly indicate that TATA needs some more QC quickly.
The FE of 10.5 kmpl before first service is certainly not that bad, IMO.
Isnt that 30 second idling supposed to be 1 or 2 minutes ( I can be wrong here ). |
The owners manual says 30 seconds. Even after idle for 30 seconds, I ensure that for about a minute more I do not exceed 1500rpm
Originally Posted by dicorex4x4 tsk1979, what colour is this? If it is Pearl White, I'm not able to figure out why it looks so different from my Pearl White.
The horn does sound muted when inside with windows rolled up. It does sound loud on the outside. But then, I have always been satisfied with the stock horn. |
Its called camera trick
I have a roots horn in the indica, so obvious comparisons!
Didn't quite get this.
Congratulations and a note on braking - under panic braking, try your best not to turn the steering wheel to either side even a little.
Thanks!
Try this. At a quite place stand outside when she's idling, switch on the AC and hear for the click. Now ask someone to tap the accelerator repeatedly, even exceeding 1200rpms or so. You will hear the compressor cycling off and on.
As for panic braking in any tata car you dare not touch the steering!
Originally Posted by GTO Congratulations TSK! White looks simply awesome on the Safari, and compliments dark tints + alloys even more (hint hint ). Go out and shod her with some really slick alloys & good rubber. |
Thanks GTO! After HDFC monkeys reduced my loan amount after the blue, all accessory fitting will have to wait. However I am trying to budget in an AMP and subwoofer if possible
Practice this with the utmost discipline. Even if its not mentioned in the owners manual, I still idle my turbodiesel Benz / Indigo religiously for 30 - 60 seconds.
Yup will take care of this always
Man, this really and truly sucks!! But then, you knew what you were getting into. Tata really needs to pull up their socks on the Safari's QC, more so when its their flagship car and the cheaper Indica / Indigo don't report as many issues. Good luck with getting them sorted out.
Restrict for the first coupla hundred kms, but then start stretching her legs. Gradually. Diesels feel very restrictive when new, but totally *open up* once the kms are logged on.
Hopefully this is the only problem! As for couple of hundred kms, she's already done 600, and by end of this week I will have her in for first service.
Time to ping Gurgaon!
Congrats again. Wish you and Mrs. TSK1979 many kms of safe touring. Time to get rid of the Indica then?
Thanks GTO!, but the indica stays. For in city jaunts the safari is real cumbersome. We are still not confident about our width judgement and the turning circle is humongous!
Originally Posted by dkamath Congrats, tsk1979, on your purchase!!!
Sad to hear about the initial niggles. Hopefully, the car will be just fine from now.
The hissing sound at steering full lock position seems abnormally normal with most Safari's. Preferred not mention about it during the first service too. The power steering otherwise "feel"s just fine.
Getting the same fuel consumption that you mentioned, in city driving conditions. |
Thanks dk, I got the FE in 50% highway driving at 90-110kmph. Hopefully the first service will take care of this
A question guys, I plan to purchase 7.5L of castrol GTX diesel(this oil is also mentioned in owners manual) and get it changed. Do Tata service centers do choo chaa on this? Most Tata service centers have Castrol GTD and no ways I am going to let them put in that thing in the car.
Also, the oil change is at 15000kms, and not 1000, but I am still going for it. So do I need to get oil filter changed?
