Old 7th May 2024, 20:42   #406
ryzen7@5800u's Avatar
Thanked: 130 Times
re: Tata Indica DLG Turbo. EDIT: 17 years & 125k km up
Nice to see another Indica going strong at 15! Our petrol V2 GLS hit 15 last year. The engine is sluggish and the clutch is a pain, but the Indica just keeps going. We renewed the registration for the next 5 years too. This is one car I will not let anyone take away!
ryzen7@5800u is offline   (2) Thanks
Old 6th July 2024, 17:03   #407
greenhorn's Avatar
Thanked: 4,857 Times
Infractions: 0/1 (5)
Originally Posted by greenhorn View Post
Your thread motivated me to get off my behind and complete my power mirror conversion project I've been sitting on. Thankfully it was a lot easier than yours because power mirrors are available for the indica platform from the indigo top variants. All i had to do was get the switch, mirrors and cook up a wiring harness. I got my local accessories shop to do the heavy lifting of installing the wiring.
Sharing a video of the proof of concept and final look in the car
https://Youtu.be/c-zMeLB1R3E?feature=shared
Attachment 2624541
Pinouts - Switch
Attachment 2624545
Mirror -
Green = Common
Red = Horizontal
Blue = Vertical
Recently upgraded to power mirrors!
greenhorn is online now   (5) Thanks
Old 5th August 2024, 19:19   #408
greenhorn's Avatar
Car crossed 125k and 17 years last month
Tata Indica DLG Turbo. EDIT: 17 years & 125k km up-pxl_20240717_092927275.night.jpg
And the gearbox refused to shift one fine day.Either 1 or 3rd gear would refuse to fall into place. Rest were fine. Coincidentally, this happened just when my etios was facing shifter issues.
Unfortunately in this case, my mechanic deemed my current gearbox too far gone. While they did not go into specifics, they said it was too worn and not rebuild able.
Thankfully they were able to source a used gearbox (7k - a new one is 48k!), and i had a spare clutch lying around ( how many people keep a spare clutch just in case )
Anyway the work is going on, and I'll update
Tata Indica DLG Turbo. EDIT: 17 years & 125k km up-pxl_20240805_141728517.jpg
Tata Indica DLG Turbo. EDIT: 17 years & 125k km up-pxl_20240805_141712112.jpg
greenhorn is online now   (12) Thanks
Old 23rd August 2024, 17:53   #409
greenhorn's Avatar
Tata Indica DLG Turbo. EDIT: 17 years & 125k km up-screenshot_20240823175157253_com.whatsapp.jpg
The car was delivered on Saturday with everything working fine. However on Sunday it stopped shifting with the engine on. I got a house call from my mech who tweaked the play in the clutch to enable shifting again. Things improved after that, but then on Monday the car started jerking violently in the middle of a u turn and stopped. A couple of passers by helped me push it to the road side. The car would not go into neutral. The clutch pedal had gone fully depressed. I couldn't start in gear because the car would attempt to move and stall. I could start in neutral but there was a strange noise coming. I left the car on the roadside and had workshop pick it up.
Tata Indica DLG Turbo. EDIT: 17 years & 125k km up-pxl_20240822_151528664.jpg
Tata Indica DLG Turbo. EDIT: 17 years & 125k km up-pxl_20240823_113119089.jpg
After a couple of days, this is the update. A failed release bearing. This is a brand new bearing from a clutch kit I bought from boodmo last year. The clutch has a manufacturing date of 2022. It's being replaced. I'm rather disappointed with a brand new bearing failing in one day, but that's how Tata spares are. Even the genuine ones. Now you know why I'll never buy another tata car again. This is not the first time a brand new genuine spare part experienced immediate failure.
It's being replaced. I will update
greenhorn is online now   (4) Thanks
Old 9th September 2024, 19:24   #410
greenhorn's Avatar
Got the car back from the bearing replacement. Was at home the next day tuning my ice when i hear a bang and notice rpm go up. Lost AC, power steering and brakes. Looked below the car and sure enough
Tata Indica DLG Turbo. EDIT: 17 years & 125k km up-pxl_20240907_140541226.jpg
Back to the workshop and they found this
Tata Indica DLG Turbo. EDIT: 17 years & 125k km up-img20240909wa0024.jpg
Apparently some aftermarket wiring had gotten tangled up and caused the belt to snap. It's being fixed. Will update
greenhorn is online now   (2) Thanks
Old 14th September 2024, 14:37   #411
greenhorn's Avatar
I had issues with stability under braking and had asked them to look at the suspension.
This turned up
Tata Indica DLG Turbo. EDIT: 17 years & 125k km up-img20240911wa0019.jpg
This is the area where my suspension Mounts are bolted
Looks like my maintainence expenses are going to cross 50k this year
greenhorn is online now   (3) Thanks
Old 1st October 2024, 14:43   #412
greenhorn's Avatar
Got the car and a very pricey bill.
Braking is still crap- wheels still locking up too easily but at least the tendency of the car to wander under hard braking is gone.
Reverse gear is still a bit hard to slot. Car is going back for linkage adjustment tomorrow.
Mechanic asked me to drive the car around for a week to bed the brakes. And see if braking improves
Tata Indica DLG Turbo. EDIT: 17 years & 125k km up-img20241001wa0029.jpg
greenhorn is online now   (7) Thanks
Old 2nd October 2024, 18:09   #413
Thanked: 312,518 Times
Time to sell the Indica, Greenhorn! 15 years is a lot for the car, I don't think even Tata intended for it to have such a long life.
Replace it with something newer, faster, more reliable....
GTO is offline   (7) Thanks
Old 4th October 2024, 23:11   #414
Thanked: 130 Times
Re: Tata Indica DLG Turbo. EDIT: 17 years & 125k km up
Respectfully, sir - I disagree!
Our Indica Petrol is 16 years old too - granted it has only 97k on the clock.
But it does city duties perfectly well, only needing a battery every 4 years...
The AC blower motor fuse blew recently, but that was an easy fix.
The car's still got plenty of life in it, I believe
ryzen7@5800u is offline   (1) Thanks
