I dont plan to write all the features of the car here. Attached is the brochure and this
link will give more information on the car
What I really like about the car -
- I am a value for money person and this car reflects that
- 5 year 100k km warranty
- 7 airbags and 5* safety
- Adaptive cruise control - Helps a lot in slow moving highway traffic where I spend a lot of time
- Built in amplifier for a reasonably good sound output
- 360 degree view camera & side view alone - super useful while reversing or on offroad
- 8 speed automatic - highway cruising at very low rpms
- Less diesel consumption - I got 12 kmpl over last 5000km. My usage is 60% highway and 20% semi urban and 20% urban.
- 4WD capability in stock form- comes standard with center and rear diff locks , low range, multiple driving modes etc. Took the car for an offroad trip and loved it. (details below). 220mm of GC
- Small front windshield and rear privacy glass (reduced heat). Commanding view of the road ahead.
- LED headlights - a big upgrade from Camry's poor headlights
- Paddle shifts. Fun to drive
- Great online support and availability of aftermarket options
- Speed limiter function - One can set a predefined speed and car wont cross that speed.
Dislikes:
- Turbo lag. feels very lethargic at less than 1800 rpm. Some say that this is intentional as this car is offroad capable. Anyways I have fitted a throttle controller ( its called iDrive) and that seems to solve the problem by making the car feel more responsive
- Slight vibrations post 2500rpm - Yet to ascertain if its a generic problem with the car or specific to my own car. Reported this in last service at 30k and they did an injector relearn procedure which solved the problem for next 1500km. Its back again.
- The ride. I cant complain here as I knew exactly what I am going to get before purchasing; but still wish if its better. Its very boat like and I can feel most of the road imperfections inside the cabin.
- The autonomous emergency brakes may kick in before I start reacting and sometimes causes people inside the car to question my driving abilities
. I understand the algorithm may be tuned to be on safer side, so its fine. It actually works by the way!
- The parking sensors sometimes go off in the middle of a 5 lane highway when no cars are around !
- The 3rd row and second row can be folded to make a flat loading area, but second row will be raising up instead of going down to floor. The folded second row takes up around 1.5 feet and as a result cannot make a bed inside the vehicle for those camping trips ! I am planning to build some custom plywood work to make a bed.
- The protruding rear wheel arches inside the cabin. This reduces the width of cargo loading bay. I was able to keep a dining table top flat on the base in a mid size kia SUV, bit not on this car.
- The rear seats don't move back or forth (horizontally).
- Digital radio reception is poor with a window mounted antenna.
- No way from steering to change FM saved stations.
- Upto 10 seconds of delay when switching from stored station to another in FM and digital radio
Time for some photos
Outside
Inside:
Third row
Some covered storage spaces
Bottle jack
Tow bar
Rear seat power points
Rear seat lights and rear AC controls
Different HU functions, supports Android auto, Apple car play and digital radio.
The 360view option with front and 360 degree views. This can be switched on anytime from a button in steering wheel
The 360view option with front and left side
The reversing view
Inside the hand rest are two USB ports and one HDMI in port
How it is to drive:
This really depends on how comfortable are you in pushing the accelerator. With light touches, car feels lethargic; but once the turbo starts spooling ( around 1500-1800 rpm), this car suddenly propels like a rocket with 430NM torque. Wish the torque was a bit more linear. There is noticeable turbolag below 1800 rpm and once the engine crosses 1800 rpm, car picks up speed very fast. The best comparison is 1.3L multijet engine with fixed geometry turbo. The boost is varied based on the accelerator inputs.
The 8 speed gear box is very eager to shit to higher gears. but one can stay in the power band using paddle shifts. The shifts are generally smooth. One annoying feature is the gear box shifting to 2nd gear while stopping at a traffic lights with brake applied, this shift is without a trigger and can be perceived as a jerk.
100 kmph in 8th gear is around 1700 rom and 120kmph in 8th gear is 2000 rpm. Gearbox downshifts quickly if we press accelerator further down. Cruising at highway is a breeze and overtaking is also easy. I havent driven the car above legal speeds, so I am not very sure about the very high speed stability. There are youtube videos showing this vehicle doing insane speeds.
Braking is fine, but hard braking at high speeds cause the nose to dive down and gives the passengers a feel that a crash was just avoided. This happened couple of times in the initial weeks of our ownership when family was very used to the sharp/no roll braking of Camry. The pedal travel is also more compared to a Swift/Camry. Brake pedals vibrate when emergency braking is triggered. The long travel & nose dive makes a feel that car is slow to stop, but the tested number ( 40.27m@3.29 for 100 to 0 kmph) is better than most of its competitors ( Data available at
https://performancedrive.com.au/performance-data/
NVH levels inside the car can be improved. This car can no way be called a silent car..at idle or highway speeds. Wind noise at 100 kmph is definitely there.
Steering at low speeds are fine, I dont find any issues except for the increased turning radius. But on highway speeds its a bit vague. Keeping car in a straight line in between lane markers needs more effort than Camry. The place I live gets some serious winds often; it is scary to drive this vehicle at 40-50 kmph cross winds at highway speeds.
This youtube video gives the most common performance numbers
Kitna deta hey (kmpl):
Generally 80kmph drive will return 15-16kmpl, 100kmph will give 12-13kmpl and 120 kmph will be 10-11kmpl
This is the best ever i managed over an 80km drive at 80kmph
