Old 7th May 2018, 13:11   #106
Thanked: 21,450 Times
re: Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!
Hope the wheels were turning freely after installing the new pads and rotor.
Yes sir, they are rotating freely.
No screeching sounds or for that matter, no unusual sounds are heard during braking or otherwise too.
Old 7th May 2018, 19:56   #107
mxh
mxh's Avatar
Thanked: 280 Times
Yes sir, it is in the schedule hence went as per manual. I wanted to change at 10,000 kms actually.
Attachment 1758136
In the chart: Fuel filter Cartridge is Fuel filter
I guess diesel engines call for fuel filter replacement much more frequently. For my City petrol it's 48 months/ 80000 km and it costs Rs 514.
mxh is offline   (2) Thanks
Old 7th May 2018, 20:50   #108
govigov's Avatar
Thanked: 1,219 Times
Complete view of the rear when pilot lamps/headlights are switched ON
Attachment 1741487
Complete view of the rear when brakes are pressed
Attachment 1741488[/center][/b]
Hey Anurag,
I noticed something, not sure if this is with all the creta's. If you look at the picture without the brake ligts, the red lights on the tail gates are ON.
If you press the brake, the high mounted stop lamp glows, but the lights on the tail gate is OFF.
Is that how it is supposed to be?
govigov is offline   (1) Thanks
Old 7th May 2018, 20:56   #109
In the first image, parking lights/headlights when switched ON, the two lights on the tail gate glow along with the arrow in the LED Reflector.
In the second image, I had switched OFF the parking light and pressed the brake hence the lights on the tail gate aren't glowing.
Old 7th May 2018, 22:02   #110
govigov's Avatar
Ah! That makes sense. Congratulations on your purchase.
Old 10th May 2018, 22:03   #111
Inspired by this video, always wanted to see how the suspension will be working on my car over the road I take regularly. Nothing path breaking or anything great in this post but just my curiosity.
Mounted the rear dashcam underneath (On the tail pipe and recorded the video). I had driven for 30 kms @ 100 kmph constant before fixing the dashcam at that location. There was no other proper place where I could mount the camera and secure it with zip ties.
Used a 10,000mAh power bank and connected the dashcam to it using the 4m cable provided in the dashcam package and kept the power bank in the boot.
Rear cam mounted and secured properly with zip ties
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180510_112642.jpg
A complete view
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180510_112648.jpg
Shot taken from the camera after mounting
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-a_20180510100239.jpg
Shot taken from the camera on-the-go
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-a_20180510111629.jpg
Three sample videos
a4anurag is offline   (23) Thanks
Old 10th May 2018, 22:43   #112
catchdoon's Avatar
Thanked: 117 Times
Mounted the rear dashcam underneath...
That's pretty neat DIY you did there.
Looks like Creta has got decent enough shock absorber there. It isn't just way too stuff nor it is way too wobbly. A tad bit on the smoother side.
catchdoon is offline   (1) Thanks
Old 11th May 2018, 07:45   #113
paragsachania's Avatar
Thanked: 27,204 Times
Pretty interesting video there that is quite an effort with the mounting of the Dashcam and pulling the cables et al. But this doesn't in any way prove if the suspension is better or worse or for that matter even if its working beautifully or not. Anurag has rightly pointed out that he did this out of curiosity and that pretty much is seen there from the outcome.
The Camera is mounted on the Beam pointing towards the suspension system. At any given time, the camera is at a fixed distance away from both the road surface (unless you get into typical off roads) as well as the suspension. So this actually shows the relative movement between a rigidly fixed camera versus always in action suspension system.
Reminds of this ad whenever we refer to working of suspension and the competition :
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-bajaj_platina_ad.jpg
paragsachania is offline   (12) Thanks
Old 17th May 2018, 08:47   #114
MODIFICATION: EGR Delete
Was waiting for 20,000 kms to complete so I could blank the EGR valve until then I drove with the EGR coupler removed. Have driven for almost 2,000 kms approximately before placing an order for the EGR delete kit from eBay.
EGR coupler...
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180327_024736.jpg
...coupler removed
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180327_025112.jpg
CEL thrown with the EGR coupler removed was P0489 which means Exhaust gas Re-circulation (EGR) system -circuit low” or “Exhaust Gas Re-circulation “A” Control Circuit Low.
CEL lit (car doesn't go into limp mode when the CEL lit)
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img20180327wa0000.jpg
Diagnostic Report
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-p0489.jpg
Got the EGR delete kit from eBay for ₹700 including shipping (was shipped from Poland. Order to Delivery in 14 days).
The kit contains:
  1. EGR-078 Stainless Steel (1.5 mm) - 1 piece
  2. EGR-175 Gasket Gambit (1 mm) - 2 pieces
Contacted BHPian interc00led and meet him at our FNG since working will be easier as they have the right tools to help us. Took us almost 2 hours to complete the work due to the heat from the engine bay.
Actual plan was to install the blanking plate in place where the gasket (Figure No.: 28418E) is on the EGR valve control unit on the EGR unit that will let gases into the EGR cooler and then into the intake manifold but due to the EGR valve/cooler's positioning it was difficult and required a lot more parts to be removed to gain access to those screws...
Intake Manifold
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-intake-manifold.jpg
...BHPian interc00led decided to go the other way and install it on the exhaust manifold side. This is the gasket that sits between the exhaust manifold and the EGR unit (Figure No.: 28492).
Exhaust Manifold
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-exhaust-manifold.jpg
EGR Delete kit (Slightly larger in size compared to OEM gasket).
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180514_192710.jpg
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180514_192736.jpg
Battery, Air filter box removed for easy working
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180515_193027.jpg
Screws removed where the blanking plate needs to be fit
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180515_193612.jpg
Blanking plate with gaskets
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180515_200049.jpg
OEM EGR Gasket
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180515_200100.jpg
Blanking plate fixed and pipe reconnected
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180516_031531.jpg
After clocking 3,000+ kms without EGR (2,000 kms with couple removed and 1,000 kms post blanking plate fix), I can say:
  • Throttle response is better in the lower RPM range (1000-1300 RPM) as compared to stock;
  • I used to notice black smoke at 2000 RPM when accelerating in 4th gear onwards but now I can see the smoke when the RPM is over 3000 RPM but the quantity is reduced.
  • After the plate has been installed both BHPian interc00led and me have noticed the surge in 3rd gear. It was slightly on the linear side earlier but now the surge is evident clearly.
Will keep updating the thread as I clock miles.
a4anurag is offline   (11) Thanks
Old 17th May 2018, 10:11   #115
Thanked: 1,369 Times
If you don't mind me asking, why did you do it in the first place? I mean, did you find any lack in performance? I know it makes a noticeable difference when the EGR is clogged after 50k miles or over but your Creta is pretty new isn't it? Also, why wait till 20,000 kms? I've also heard the engine gets louder after 'delete'. So, how's yours sounding now?
Don't get me wrong. I'm asking as I'm wary of messing around with the mechanical bits and wondering if it's something I can consider for my diesel i20.
swiftdiesel is offline   (1) Thanks
Old 17th May 2018, 10:20   #116
Don't get me wrong.
No offence taken buddy.
Did the EGR delete as the engine would run better and cleaner. I didn't want soot deposition in the intake manifold and other parts that will create issues as it gets older (read clocks miles).
EDIT:
Not sure on increase in noise levels as the Creta is silent already inside.
Last edited by benbsb29 : 17th May 2018 at 11:51. Reason: Corrected typo as per RP.
a4anurag is offline   (4) Thanks
Old 19th May 2018, 09:15   #117
Re: Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log EDIT: Now Remapped
MODIFICATION #21: Engine hood insulation
The ugly part under the hood is finally covered now thanks to AliExpress.
Contacted the seller and sent images of the car and hood underside for confirmation. Within 3 minutes received a positive response so placed an order for it. Received the item in 14 days flat with no customs duty. Link to the item.
Item Cost: $ 54.28 = ₹ 3,690
Coupon used: $10 = ₹ 679
Net Paid: ₹ 3,000
Package Contents:
  • Insulation Sheet x 1
  • Retainer Screws x 15
Since the holes on the insulation match with that of the holes on the hood, it only requires one to screw fit those clips all the holes. The hood has a total of 11 holes that need fasteners to be plugged-in to hold the insulation intact.
Images of the install
Packing of the item
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-1.-packing.jpg
Label of shipping etc
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-2.-label.jpg
Insulation pad
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-3.-insulation-pad.jpg
Screw type fastener
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-4.-fastener-screws.jpg
Removed from the packing and spread flat on the engine bay
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-5.-insulation-sheet-spread-flat.jpg
Under side of the insulation
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-6.-underside-insulation-sheet.jpg
Holes to fix the fasteners (11 no's in total)
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-7.-holes-hood-insulation.jpg
Pre-cut new holes under the hood for easier and faster install
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-8.-precut-holes-matching-hood.jpg
Wrinkles observed on the sheet thanks to the useless way to send
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-9.-wrinkle-due-packaging-style-used.jpg
A warning sticker (I think problem is new)
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-10.-warning-sticker-aluminum.jpg
Before the hood install
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-11.-before-installation.jpg
After the install
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-12.-after-installation.jpg
Fastener fixed (Close up)
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-13.-screw-type-fastener.jpg
Before vs After
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-14.-before-vs-after-install.jpg
a4anurag is offline   (25) Thanks
Old 25th May 2018, 20:06   #118
FE Update - After the Remap
First full tank FE after the remap.
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-screenshot_20180522230046.jpg
Old 28th May 2018, 23:52   #119
Another FE Update - After the Remap
With higher usage of the car this month with almost 4,600 kms driven, this is the second full tank completed post the remap and the FE figures are back in the range of what I used to get before remap. Pretty happy with this.
First tank FE (14.12 kmpl); Second tank FE (19.16 kmpl) and a mini summary
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-fe-update.jpg
Also to protect the black cladding all-round the car, purchased Armor All Original Protectant from Amazon.in for ₹ 250.
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180528_230330.jpg
MODIFICATION #22: Rear Spoiler
Thanks to BHPian speedmunster for help on guiding me to an accessory store for Rear Spoiler. Had visited many shops on the Minister Road area for fitment of the rear spoiler and got a quote ranging from ₹ 4,000 to ₹ 8,300 for a body coloured one with 3M + Clamps to hold the spoiler in place rather than the spoilers that need holes drilled in the body for fixture. Car Sonics @ Minister Road, had the spoiler in stock and got the job done in flat 5 minutes and was charged ₹ 3,680.
Clamps provided to fix the spoiler firmly on the body
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-clamps-holding-spoiler.jpg
WIP
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-wip.jpg
Some images post fitment
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180528_192138.jpg
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180528_192208_01.jpg
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180528_194119.jpg
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180528_194127.jpg
Stock vs With Spoiler
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180503_053739horz.jpg
Shall update the thread with better quality day light images.
a4anurag is offline   (7) Thanks
Old 29th May 2018, 00:10   #120
ecosport rules's Avatar
Thanked: 2,063 Times
About the remap
Is the low end torque better now ?
Also
How is the fit and finish of the spoiler.?
ecosport rules is offline   (1) Thanks
