Old 9th June 2021, 15:52   #751
Dr.Naren's Avatar
Thanked: 17,150 Times
re: My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (~200 HP / 420 NM) | EDIT : 5 years & 75,000 km up!
Removed the rear seat base and folded it for the first time in 5 years of ownership to load luggage
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210609_124429.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210609_125028.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210609_125129.jpg
Almost flat surface
Dr.Naren is offline   (10) Thanks
Old 9th June 2021, 17:10   #752
benzinblut's Avatar
Thanked: 882 Times
Originally Posted by Dr.Naren View Post
Almost flat surface
A 200bhp cargo hauler?
Jokes apart, I once did this on my S-Cross and put in a small cupboard. After the seats folded, the space is huge.
benzinblut is offline   (4) Thanks
Old 9th June 2021, 17:26   #753
Dr.Naren's Avatar
True that!! I used to take my SX4 whenever there was excess luggage, not anymore haha!!
Dr.Naren is offline   (1) Thanks
Old 13th June 2021, 19:00   #754
ibisbrew's Avatar
Thanked: 175 Times
Great car and great job documenting everything.
Thanks for the ride today. I mean the turbo spools ( ) and boy does that thing pull.
Factory horses are great but adding personal touches and building something like this, brings a uniqueness like no other.
P.S. Sorry for the okay-ish angle, the rain didn't help :/
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-dr.narenscross.jpg
ibisbrew is offline   (3) Thanks
Old 13th June 2021, 20:18   #755
Dr.Naren's Avatar
Thank you
It was nice meeting you guys and the drive on new road was fun .
Old 17th June 2021, 15:13   #756
Dr.Naren's Avatar
Engine Torque Rod Replaced
During the 70k km service, Wagen Tunen had found out that the torque rod is weak. It is a rod at bottom part of engine connecting to gearbox. They had sourced the part in few days, but I couldn't get it replaced due to lockdown.
Pics:
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210617_131425.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210617_131412.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210617_131404.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210617_132410_bokeh.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210617_130719.jpg
Part Cost: Rs. 1653
Labour: Rs. 250
Good experience at Wagen Tunen as always
There is no sound while going over speed breakers and the mild jerk during sudden acceleration has also disappeared.
Stay Tuned....Few Upgrades are on the way
Dr.Naren is offline   (7) Thanks
Old 22nd June 2021, 12:37   #757
Dr.Naren's Avatar
Can't wait to hear them sing: Morel Virtus 😎
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210622_113742.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210622_113844.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210622_114034.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210622_114113.jpg
Dr.Naren is offline   (5) Thanks
Old 24th June 2021, 12:57   #758
Dr.Naren's Avatar
Super cheap DIY gear knob change!!
The OE gear knob of S-Cross 1.6 is an imported part and priced at more than Rs.5000. Many owners have issues with the knob as it develops cracks and disintegrates. Tip is to avoid parking under sun or use a cloth on gear knob when parked under sun. The knob gets super sticky after exposure to sunlight, followed by cracking.
Cheap / Smart solution:
1. Get the OE knob of Ciaz 1.5 DDIS: Rs. 520
2. Swap the shift pattern badges
Thanks to Mr. Neeraj for this picture, he has explained the procedure very well.
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-screenshot_20210624123933.jpg
I had done the step 1 few days back, but was not able to remove the shift pattern badge easily from the Ciaz knob.
Look at the condition of gear knob
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210527_152254.jpg
There was no issue driving with Ciaz knob, but it was difficult when someone else would drive the car as they would try slotting into first gear instead of reverse .
Finally I found something in my animal dissection kit and thought it would work..and it did haha
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-screenshot_20210624123822__01.jpg
Attached the S cross shift pattern badge on Ciaz knob and saved around Rs. 4500!!
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210624_122223.jpg
Dr.Naren is offline   (16) Thanks
Old 25th June 2021, 18:35   #759
Dr.Naren's Avatar
Exterior & Interior detailing done
I hadn't got the car detailed since long time. I came across a shop named A to Z car accessories in Udupi. Their work looked good and the pricing was very VFM.
I got a package priced at Rs. 3500 which included
1. Exterior detailing: Proper wash which included removal of tyres, number plates, all emblems were cleaned with brush. Major scratches were removed by wet sanding followed by machine polish for the full body. They also did dressing of all the black trims and tyres.
2. Interior detailing: Vacuum cleaning, foam cleaning and dressing
They took a long time but the end result was top notch.
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210625_161809.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210625_164356.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210625_164454.jpg
Wiper blades changed
I also got new wiper blades (26+14). Brand is Excelite, trying for the first time. Price is Rs. 570
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210625_153830.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210625_154618.jpg
Dr.Naren is offline   (11) Thanks
Old 14th July 2021, 20:04   #760
Dr.Naren's Avatar
Finally: Garrett Intercooler Upgrade
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210714_175031.jpg
Detailed post after 500 km trip. Initial impressions are better low end and sharper throttle response
Old 16th July 2021, 10:48   #761
Dr.Naren's Avatar
Brake Pads Changed:
Front:
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20201231_142751__01.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20201231_142937__01.jpg
I installed TVS HI-PER brake pads. Had bought it for Rs.1400 from Boodmo. Previous pads were KBX and I had done 8k kms, the pads had 50 percentage of the life left. But, there were minor cracks leading to vibrations under braking.
Rear:
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210617_115510.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210617_115517.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210617_115537.jpg
OE rear pads cost 6k+. I bought Roulunds pads from Boodmo for Rs. 1150. I was using driveline pads before and had done around 6k km. One of the pad was damaged due to caliper issue. Hence, changed the entire set.
I used to hardly get 7-8k kms average life for front brake pads. It looks like doubled now after ICE Upgrade, time to make it 3x more with Morel Elate Titanium 603 .
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210711_102513.jpg
Oh Yes, I had posted about installing Morel Virtus 602..but the Elate Titanium with sticker price of 2 lakhs was available at massive discount and I just picked it up.
Dr.Naren is offline   (4) Thanks
Old 21st July 2021, 17:19   #762
Dr.Naren's Avatar
Morel Elate Titanium 603 Installed
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210719_091419__01.jpg
Details here:
https://www.team-bhp.com/forum/car-e...ml#post5104956
Driver side AC vent replaced
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210716_172403__01.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210716_172618.jpg
The sliding knob was broken, had to change the entire vent. Part was sourced from Boodmo.
Feedback on new brake pads
Intial bite is impressive. I have driven around 1000 km with these pads. Good alternative compared to OE pads. I didn't check full braking at high speeds. Not expecting it to perform like EBC. Hope it's as good as stock or slightly better.
Bad News
I got rear ended by an Alto. I had slowed down before the toll booth and the idiot just crashed into me. The damage doesn't look that bad from outside, but it's not the case inside. The rear panel is badly damaged and even the floor area is pushed in, so the boot doesn't get locked properly. All thanks to the cost cutting by Maruti, rear crash bar is deleted for Indian S-Cross
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210718_192342.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210718_192403.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20210718_191845.jpg
I would be repairing the car at Maruti. Parts have been ordered, should arrive in 2-3 days.
Dr.Naren is offline   (3) Thanks
Old 21st July 2021, 17:57   #763
pugram's Avatar
Thanked: 208 Times
Bad News
That's sad Doc.
Someone cast an evil eye on your beauty.
What was the story of the Alto ? Did he brake late ? I hope you are taking him to task.
I am sure you will bring it back to the original spec and maybe include the crash guard too
pugram is offline   (1) Thanks
Old 21st July 2021, 18:05   #764
Dr.Naren's Avatar
This happened at speed breaker just before the toll gate. I had slowed down and just crossed the speed breaker and hear a loud sound . It was raining too, may be the Alto guy braked late and the wet roads made it worse.
Yes, I am exploring this idea to add the crash member. It's too expensive to import.
Old 21st July 2021, 19:01   #765
BoneCollector's Avatar
Thanked: 11,051 Times
Bad News
That's sad. Will you be replacing the boot door too? If yes then remember to do a thorough water leak test before taking delivery. I had a tough time with getting the leak plugged from the beading area as well as the glass pasting area. Another issue that can crop up is the dislodging of the request sensor relay or something like that located on the under side of the inner trim of rear floor panel where the lock of boot is located. It may not be the same as Brezza but better to check it.
BoneCollector is offline   (2) Thanks
