re: My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: 11.5 years & 1.34 lakh km done [SOLD] Quote:
Originally Posted by scorpian Hi,
May be I can help.
I am using first generation swift lower arms and they work fine. They needed a light bit of one metal edge on the lower arm to be grinder with a grinder, It was a two minute job and i did it myself at the FNG for the metal edge to be shaved. |
Thank You Manoj for the insights.
Regarding Lower arm, I went with OTR as Monroe was taking 2 weeks for delivery. I have already placed the order for the parts. Will keep your suggesting in mind in case FNG notices any issues during replacement. Quote:
Originally Posted by scorpian The steering rack can be overhauled using a copper bush and regreasing the rack with genuine SGP grease. I will cost you around 6k. Lasts about two years. Be aware steering becomes stiff for sometime post this work. For peace of mind go for the new one and yes it is super expensive at 38K. |
Steering rack, yes it is a costly affair... will be trying the fix first. If things don't get better, will plan on replacing the complete kit. Quote:
Originally Posted by scorpian I am running a Stage 1+ tune on my sx4 since last 80k kms and its the best money spent. I have been trying to get a downpipe but since i am based in goa and cant send my car to black works i haven't been able to lay my hands on it. But i am told with the down pipe diesel smell is more pronounced and little loss on low end. |
Thanks for sharing. I have been on Dieseltronics and have predominantly used the "P2" mode and found the performance better than stock and drivability has been a lot better. After reading this post, It gives me a feeling the Dieseltronics P2 mode may be just scratching the surface of what you all call as the Stage 1 or 1+. ![LOL](https://www.team-bhp.com/forum/images/smilies/LOL.png) I want to try out the Wolf Tune and have kept that plan on hold for now till I get the downpipe installed and modify the air intake. That way the tune is more inline with the mods done to the car.
New Issues found during the last couple of weeks.
I noticed a lag in the way the car responds to the throttle input with Stock or with P2 mode. Initially started noticing this when I was travelling to Ooty last month, it feels like the turbo never works in the second gear and when I move to Gear 3, Turbo works fine. I initially thought the problem may be because it is taking time to spool as I was going uphill until I noticed that when accelerating in Gear 2, I take my leg off the throttle and apply throttle again, the turbo works.... and I can feel the car pulls effortlessly. This got me confused. why does it work only if I take my legs off and apply throttle again.
Checked it during normal flat roads and it is intermittent, responds fine sometimes and I have to do the same lift off and apply throttle to get this working. ![Disappointed](https://www.team-bhp.com/forum/images/smilies/disappointed.png)
Turbo function wise I see it responding in all gears and when it works, the power is felt in all gears and there is no noise....atleast I hope it is not a Turbo failure.
Along with this, I also noticed when I switch off the vehicle, there is a mild motor running noise heard just behind my right headlight (unable to pin point) ... and it fades away. I have not heard it earlier. Will try to add a Video or an Audio clip if I manage to capture it. It is mild and happens every time the vehicle has run as little as 1 or 2 km and it does not happen if I start the car and leave it in idling and switch off. This has been bugging me for sometime and i have searched the web with no luck. If anyone has encountered this issue, please share your thoughts and how you managed to get this fixed.
Will be taking my car to the service center once the parts arrive and get these checked and also hoping to get an answer. Once all issues are fixed I will get on to the mods I have planned. Will share updates on what happened in the next week or so.
Reason: Two smileys/post
