Old 1st July 2018, 12:16   #91
Dr.Naren's Avatar
Thanked: 17,150 Times
re: My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto, EDIT: 10+ years & 1.3 lakh km done
The performance has got little more better after driving few hundred kms. The car has almost nil lag, it pulled on an uphill with 4 people from 1000 rpm in 3rd gear.
1500 to 3500 rpm zone is just brutal, smash the pedal and the car just shoots. Nobody could imagine it's an 1.3 under the hood.
Rajiv has increased the top end more than he what usually does. I was not paying attention and the car revved to 5500 rpm in 2nd gear, there was no drop in performance, it just pulled. For best performance / timing, shift at 4500 rpm in every gear .
Just to give an idea of how quick the car is :
0-100, 1/4 th mile, top speed are all better than a stock S-Cross 1.6 hahaha!!
Dr.Naren is offline   (4) Thanks
Old 12th July 2018, 22:26   #92
Dr.Naren's Avatar
The car should be taken to Maruti service soon :
I was doing 0-100 runs and noticed that car was 2 seconds slower. The clutch was slipping. This is a video taken in 3rd gear, notice the sudden rise in RPM from 2k to 3k.
The lower gear synchronizer rings should be also changed as there is difficulty in slotting into 2nd gear. I would also get the service done.
Following jobs would be done :
1. Engine oil change (Motul Xcess 5W40)
2. Liqui Moy engine oil flush
3. Liqui Moly Ceratec
4. Brake fluid & Coolant change
5. New Clutch assembly
6. New lower gear synchronizer rings
Planning to keep the car at Maruti for a day. Can't wait to fully enjoy the Wolf Moto performance .
Old 13th July 2018, 11:31   #93
Dr.Naren's Avatar
I had taken the car out late night. It was raining heavily. Headlights were badly affected by moisture, one of the major drawback of opening up headlights and installing after market projectors . It won't be possible to achieve factory level perfect sealing by after market guys.
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180706_205644.jpg
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180706_205604.jpg
Dr.Naren is offline   (3) Thanks
Old 13th July 2018, 14:24   #94
Prodigy07's Avatar
Thanked: 638 Times
Ouch. I encountered the same issue in my Baleno yesterday.
The funny part is the moisture content inside the headlamps are directly proportional to the distance
In my case, until yesterday night there was moisture only near the indicator portion. But, after I drove to office today, it has extended till the headlight bulbs
Prodigy07 is offline
Old 13th July 2018, 14:40   #95
Dr.Naren's Avatar
I believe your headlights are stock and not tampered. There are many such cases reported in Brezza and Baleno. Maruti has replaced them under warranty .
Dr.Naren is offline
Old 13th July 2018, 14:42   #96
Prodigy07's Avatar
Thanked: 638 Times
I can't claim warranty as the headlamps have been opened up and smoked
Old 13th July 2018, 14:47   #97
Dr.Naren's Avatar
My bad! I thought your headlights were not tampered .
How was it resealed? Did you use butyl sealant?
Dr.Naren is offline
Old 15th July 2018, 19:42   #98
Dr.Naren's Avatar
I noticed that clutch was slipping very little today. It was much better. Clutch slipping is present after rains / driving through water. Anyways I should change the clutch soon. I had got Dragy GPS Performance Meter and timed 0-100.
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180715_193436.jpg
It was very impressive at 10.79 seconds, even with little slipping of clutch. This is the fastest timing for 1.3 MJD documented online in India . It would be definitely better after I change the clutch, thank you Rajiv and Wolf Moto!
I drove around 100 km today, quick drive to Marvante beach.
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180715_165804.jpg
Dr.Naren is offline   (2) Thanks
Old 18th July 2018, 22:04   #99
Dr.Naren's Avatar
I had given the car to Maruti service centre yesterday for replacing clutch assembly, lower gear synchronizer rings, gear oil change. Approximate bill would be around 12k.
The job was completed today as they were too busy yesterday. SA called me and said there is some abnormal sound from engine. They are suspecting timing chain. I have instructed them to inspect it and fix whatever is necessary. Hoping to get the car back tomorrow.
Meanwhile I had ordered all filters from Boodmo and they are in transit
Got these from Amazon : Motul Xcess 5W40, Liqui moly engine flush and Liqui Moly Ceratec
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180716_184410.jpg
Planning to change all filters along with the above items next week!
Dr.Naren is offline   (5) Thanks
Old 23rd July 2018, 15:35   #100
Prodigy07's Avatar
Thanked: 638 Times
I'm not sure if the installer used Butyl sealant. But the glue that they used was transparent and they have applied couple of layers too!
Old 23rd July 2018, 18:39   #101
Dr.Naren's Avatar
I was out of station and dad had collected the car few days back.
Lower gear synchronizer rings, Clutch assembly, Gear oil : Rs. 11,891
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180723_140054.jpg
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180723_140120.jpg
The gear shifts are lot smoother now. Clutch pedal is also lighter. All the issues have been resolved.
SA also observed abnormal sound from timing chain. I am happy that service guys got it into my notice. Timing chain and all the supporting components were replaced. I was little surprised with the labour amount, it was slightly more than 4k. Labour amount was more than parts here .
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180723_135953.jpg
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180723_140036.jpg
Total cost : Rs. 20,556
Glove box lock was broken. Leoshashi gave me the part number and boodmo link. It was just 48 bucks . Very impressed with Boodmo, they delivered it within a week.
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180723_133320.jpg
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180723_133314.jpg
Air filter, Fuel filter and Oil filter have also been delivered. Ordered from Boodmo again!
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180723_183528.jpg
Planning to do the general service soon. I had already ordered filters from Boodmo, or else I could have finished the service also along with repairs. The car feels lot better to drive now. No more irritating sound at idle, 2nd gear slotting issues. Hope the synchronizer rings don't give up easily this time!
Old 27th July 2018, 18:59   #102
Dr.Naren's Avatar
I went to service centre with these items in car
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180727_103234.jpg
1. Motul X-Cess 5W40 4L (2.9l to be used)
2. Liqui Moly Ceratec (200 ml to be used)
3. Liqui Moly Engine flush
4. Liqui Moly Gear oil additive X 2
5. All filters
I got the routine service done and above parts were supplied by me. Additional items were Engine coolant and Brake fluid.
Cost break up :
1. Motul X-Cess Engine oil, Ceratec and Engine flush from Amazon : Rs. 5226
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180727_185041.jpg
2. Liqui Moly Gear oil additive X 2 : Rs 758 (Yes, it was a steal.. Thanks to Amazon Prime day sale)
3. All filters from Boodmo : Rs. 1763
4. Service at Maruti including Coolant & Brake fluid : Rs.2583
Total : Rs. 10,330
After service, parked outside home!
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180727_182222.jpg
Initial impressions are good. Engine is very smooth, thanks to Engine flush + Motul X Cess + Ceratec. I have spent more than 30k in last few days for repairs / service. This car had seen most of repairs / replacements, but the major things like turbo, steering column, gearbox were all replaced under warranty. Hoping for a trouble free ownership from now.
Old 28th July 2018, 00:28   #103
Dr.Naren's Avatar
I got to time my car again. I was waiting for new clutch and the service to be done. As expected, I got good improvement in 0-100 timing. My SX4 with Wolf Moto Remap (with zero hardware mods) did 0-100 in 10.35 seconds. Yes, it's the fastest timing for any car with 1.3 MJD documented online in India .
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180728_001636.jpg
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180728_001656.jpg
Quarter Mile timing was also very impressive at 17.19 seconds. Just to give an idea about how fast the car is, Abarth Punto does the same in 16.8 seconds!!
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180728_003111.jpg
SX4 1.3 MJD has an average quality turbo from TEL. It can't handle very high EGT's. As per Wolf, it's not possible to push the car more on stock turbo. I am planning to experiment with turbo from S-Cross 1.6. Few guys in Europe have already done this, I don't believe it would be plug and play though.
Old 28th July 2018, 13:59   #104
Dr.Naren's Avatar
I am totally in love with this product!
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180724_093122.jpg
Have driven 150 km after adding this and the gear shifts are very smooth. It is so goooooooood! I did not notice much difference immediately, but it definitely works after driving few kms. Wish I tried this product earlier.
Old 30th July 2018, 00:19   #105
Dr.Naren's Avatar
I am really happy with the performance of new Wolf map. Rajiv has given maximum possible power for 1.3 MJD and clearly warned me that Turbo would be at risk if I do WOT for long duration at high speeds. I try to take care of that aspect most of the times. But, today I pushed the car really hard and ended up getting CEL. The error was related to turbo boost.
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img_20180723_162927.jpg
I have faced this CEL only once till now. The car ran perfectly fine after I restarted the engine. Rajiv has suggested to go little down on boost and he will give an updated map.
Dr.Naren is offline   (1) Thanks
