Old 28th August 2012, 18:08   #46
Thanked: 695 Times
re: Honda Brio SMT (O) - Ownership Review, 5 years and 40,000 kms
Originally Posted by gpa View Post
When you say coasting between downshift, do you mean shifting to neutral or coast till the lowest recommended speed for that gear and then downshift?
I use the tankful-tankful method as well but in my case the mileage indicator readout is higher than the actual figure by 1 km. E.g. If the tankful-tankful method indicates I got an overall FE of 14.2 kmpl, the mileage indicator in the instrument cluster indicates 15.2 kmpl.
Basic rules Never ever coast in neutral for FE sake, its dangerous to drive with no power on wheels, leading to serious loss of control.
Tankful to tankful is the most practical and accurate way to measure FE, don't count on single reading, take an average of 5 to 7 FE readings over a period of time to arrive at a reliable FE number.
tj123 is offline   (1) Thanks
Old 28th August 2012, 21:50   #47
adityasiera's Avatar
Thanked: 433 Times
Rule#1 is not to loose power
What i meant is i just lift off the gas and let the engine braking kick in. hope it clarifies.
adityasiera is offline
Old 29th August 2012, 13:22   #48
gpa
gpa's Avatar
Thanked: 342 Times
Originally Posted by Chitta Pradhan View Post
Is it better than Swift to drive? Have you tested the FE with AC on on highways on TFM?
Yes, the Brio is better than the new generation Swift in terms of overall driveability. I am yet to take the car on a highway trip. But with ~2,500 kms on the odo and with minimal use of the a/c my FE has seen a steady increase and at the last tankful was 14.8 kmpl.
Originally Posted by reignofchaos View Post
Let me answer that - The FE on the highway for my brio varies between 13.5 to 19 depending on how I drive. It also depends on time of day, the best FE is during early mornings when its cold outside.
Thanks, for your inputs reignofchaos. Will keep your inputs in mind when I am on highway drive.
Originally Posted by adityasiera View Post
The first gear is still notchy (3000kms) on my car. In gear acceleration is typical of any Honda Vtec engine and if you are in the sweet spot, you get rewarded with a hoooosh!!
The notchy first gear has improved considerably in my car but I expect shifting to be smooth once the car crosses the 5k kms mark. You are right about the 'hooosh' and that can be a very hard addiction to get rid of.
Originally Posted by PranavDesai View Post
Sorry for jumping in late gpa, but hearty congratulations to you. I am very glad to find a partner now as I too have a Taffeta White Brio S(O). I have felt the AC drains the acceleration to a fair extent, that is the car needs to be revved higher, what do you say?
Thanks, PranavDesai. I don't feel that the a/c is a drain on power. pressure on the accelerator increases very marginally but any loss of power or drag on the engine with the a/c switched on is barely noticeable.
Originally Posted by Gansan View Post
Congrats gpa! Nice car there! Ride safe and enjoy! So I told him I need one since I had never ever driven a Honda! Then got the stock reply that the TD car had gone out and will be back by 11.00 AM and then they will give me a call. I am yet to receive the call!
Thanks, Gansan for your wishes. I am not surprised at the experience you faced at the dealer. If you read my earlier posts you'll see that I experienced the same at one of the Honda dealers I went to for a test-drive.
Originally Posted by supertinu View Post
Congrats GPA on your new purchase. I might be little late in wishing though. By the way after reading your experience with Honda A.S.S I probably should never complain about Ford A.S.S. It seems like a 5 star hotel treatment in comparison at Elite Ford, Bangalore.
Thanks, supertinu. I do hope mine was a one-off experience and that future services at Magnum Honda are top-notch.
I don't follow this, I was just clarifying with adityasiera if that is what he meant.
gpa is offline   (2) Thanks
Old 29th August 2012, 13:56   #49
sgiitk's Avatar
Thanked: 4,800 Times
When in 1974 I bought a nearly new Ford Escort Mk.I I found the gearshift a bit notchy. The car had barely done 1000 miles. I was told by the guru's that it will take about 5000 miles to fully clear. It did, so your judgement is spot on.
sgiitk is offline   (2) Thanks
Old 4th December 2012, 19:35   #50
smsrini's Avatar
Thanked: 436 Times
Congratulations on the Brio!
Did the 3M under body coating make a difference in the tyre / road noise that transmits into the cabin ?
thanks
SRini
smsrini is offline
Old 6th March 2013, 00:46   #51
rohit_dce's Avatar
Thanked: 20 Times
Let me answer that - The FE on the highway for my brio varies between 13.5 to 19 depending on how I drive. Mind you I have upsized MRF ZLO tyres so the efficiency will be higher with the stock rubber.
You can cruise comfortably at 120-130 and still get an FE of around 15-16. If you drive between 90-100, it'll shoot up to around 18-19. It also depends on time of day, the best FE is during early mornings when its cold outside.
Hey how has your experience been with the Brio? Like other than fuel efficiency, what are good parts about it and what are the parts you do not like about it? I was thinking of getting one for my sister.
rohit_dce is offline   (1) Thanks
Old 6th March 2013, 14:12   #52
reignofchaos's Avatar
Thanked: 2,502 Times
Its been pretty trouble free so far - my car has done around 15k km and has been pretty much trouble free. Its a great little city commuter car with reasonable high way ability. The engine is a lot smoother than when it was purchased and is a lot more free revving too.
The only issues I've had so far are with the horn which was replaced under warranty and a rattle in the dashboard. The latter gets fixed every time at service but ends up returning after a few days. I've given up on that one now as it only comes up occasionally and doesn't bother me too much.
reignofchaos is offline   (1) Thanks
Old 7th March 2013, 00:34   #53
rohit_dce's Avatar
Thanked: 20 Times
Hows the seating position? And is it like a good highway car? It's nice to hear the car gets better with time. And what about the servicing costs and stuff, are they like lower than the competition?
Old 7th March 2013, 10:10   #54
Its very comfortable for a small hatch. I'm 6'1" and I fit in it without any trouble. Both ingress and egress are excellent. However I'd have preferred a lower driving position. Compared to my other car this feels way too high up from the ground.
On the highway the seats are extremely comfortable - they are replicas of bucket seats so there's more than enough side bolstering which helps in avoiding fatigue.
As for servicing costs, I paid 1800 all inc for the 10000km service and 3300 for the 20000km service. Seems pretty reasonable to me.
Old 8th March 2013, 00:22   #55
rohit_dce's Avatar
Thanked: 20 Times
That appears to be quite the user experience. The servicing costs are pretty reasonable then. And yes I like the fact that seats are comfortable as well. Thanks mate for the help.
Old 17th March 2013, 10:03   #56
bj96's Avatar
Thanked: 1,466 Times
...a rattle in the dashboard. ... gets fixed every time at service but ends up returning after a few days...
Any update on this?
Even my 2 weeks old rattles sometimes. Feel it more during quiet / late evening rides. My 1st service is due later this month, need to get this sorted out.
-BJ
bj96 is offline
Old 22nd March 2013, 15:31   #57
tarunchoudhary's Avatar
Originally Posted by bj96 View Post
Any update on this?
-BJ
My Brio VMT is around 3 months old...
At the time of its first service, I requested the service guy to fix a small rattling sound which I thought came somewhere from back door LHS area.. but the service guy failed to acknowledge any such sound.
Now, there is a definite rattle from the dashboard area (although small and seldom)... Hoping I can convince the service guy now about its presence!!
tarunchoudhary is offline   (1) Thanks
Old 27th November 2013, 12:10   #58
Thanked: 87 Times
Originally Posted by puchoo View Post
Firstly ofcourse many congratulations on the purchase.
I too am a bit surprised at hearing about the honda sales attitude , my experience with them in Delhi has been excellent - i wish my Skoda guys had half the product knowledge and courtesy !
Glad to hear that all the problems were sorted out at the H.A.S.S !
Hi Puchoo, Can you please recommend your Honda Dealership? I am in the market to buy a Brio and would prefer a proven dealership to avoid any horror stories.
abhjain is offline
Old 27th November 2013, 16:01   #59
Hi gpa,
Congrats on owning the Brio . I also bought a BRIO S MT (Red) in march this year and i am simply loving this car.
I experience a lag in 2nd gear sometimes with AC on and when i am light footed . This lag is not there when the revs are higher. Did you notice this ? Or is it only me and my driving behavior
vjautofanatic is offline
Old 27th November 2013, 16:11   #60
puchoo's Avatar
Thanked: 774 Times
I dealt with two of them
Automax Honda in Bikaji Gama place , they are right next to the Skoda showroom.
The second one was South end Honda in Select City walk Mall , Saket
Between the two , will probably go with Southend.
This was about a year ago when i was toying with the idea of maybe buying a City instead of the T-Jet (since it had gone out of production) and then again for my grandmother who eventually did buy a city from them.
puchoo is offline
