Originally Posted by filmaka Hi Manuuj,
This question is for other fortuner owners in the forum as well, Please share your inputs, Thanks in Advance.
I own a Feb 2013 4 X 2 Automatic Fortuner, It comes with a auto door lock feature that locks the doors once the vehicle crosses 25 km/h Although it is a good safety feature but I do not like it, The owners manual lists some steps to disable it, But i have tried numerous number of times but could not disable it, I visited the Toyota dealership and they tried doing it by linking the Toyota module to it but they also could not find the option to change this, Any other users have any info on how to disable the auto lock feature, I may be missing something but I have tried it over and over and also read the steps in the manual with no luck.
Thanks All,
Filmaka |
Hello Filmaka,
Welcome to the Falcon's thread. First of all this is not my dear friend Manuuj's thread but dkaile's. Technicalities apart, the procedure for the same is listed below which I have tried personally and works flawlessly. It is slightly technical, so kindly pay attention that you do not miss a single step. So for turning off the
automatic locking and unlocking function, this is the procedure -
1. Remove the key from the engine switch and check that the theft deterrent system is disarmed.
2. Within 5 seconds, insert and remove key twice in quick succession.
3. Wait for 5 seconds (use a watch) and within the next 5 seconds, push and hold the lock and unlock switches simultaneously for 3 seconds or more. The turn signal lights will flash
once indicating operation successful to this point. You are now in
programming mode.
4. Within 5 seconds, push the lock switch on the wireless remote control key
twice within 2 seconds. Within the next 2 seconds, push the unlock switch
once. The turn signal light will now flash
twice.
5. Within 10 seconds, for turning Automatic locking/unlocking function to
OFF do this - Push lock switch
twice, Push unlock switch
once within 2 seconds, Turn signal will flash
twice indicating that the this programming is successful.
For turning locking/unlocking function back
ON -
Steps 1 to 4 as above remain the same
ON do this - Push lock switch
once, Push unlock switch
once indicating that the this programming is successful.
This procedure is clearly laid out in the Owner's Manual of my 4x4 MT Fortuner 2011 Model (Build 07/11) and should work on your model too as they have NOT changed the Wireless Remote Control in any way as far as my knowledge goes.
Cheers....
Herr Generale' Guderian,
Attaching two more photos of the right side of the plumbing of the master cylinder. Hope you get to see the bush that you so desired -
Hope you find what you were looking for.
PS- As far as I can make out no such bush is attached/needed here as seen in your thread, maybe due to the pipes being custom fit for the new master cylinder.
