Been a long while since I posted an update. Recently got the 4 year / 60K kms service done from Aadya Motors (after their separate Fiat establishment). Here is a summary of all things good and bad in the past year.
Tyres
The Michelin PLC have started to put out a some more road noise than before. Very small weathering cracks can been seen near the side-walls. But the best part of the tyres has been that I have not had a SINGLE puncture till date
But, then it had already done 47000kms. So I decided to avoid any risk, as I was due to travel on some outstation trips. I have now replaced them with Yokos - AVS DB V550. I upgraded to 205/60R15, getting about 0.5inch of extra ground clearance. I paid about Rs.6700/- per tyre.
First impressions - excellent grip, low road noise (definitely can make out the difference between the ageing PLC and the Yoko). It was just awesome to drive on the bangalore-shimoga route last weekend.
Engine:
Predominantly smooth. Keep getting around 14/15kmpl during office commutes; around the 22kmpl mark during outstation trips. I have tuned the race-chip for better driveability, and I think that's been one of the reasons for the good mileage. I recently changed the tuning to get better top-end, but can clearly see a dip in mileage. The recent trip to Shimoga gave me just about 20kmpl. But that had some really spirited acceleration involved. Will most likely switch back the setting.
Battery:
Changed the OEM battery to Exide maintenance free about a month ago. Over the past couple of months, had been noticing some random warning lights on the dash. I first ignored it as I assumed it could be because of the recent 3M detailing that I had got done on the car. But then after some days the engine RPM started swinging on its own. So got the battery checked immediately and it turned out that many cells were dead. This set me back by Rs.4500/-.
Interiors:
The interiors of the car have held up well. No undue paint rip-offs or creaks. There is a small rattle from the rear left door, that's been persisting across many services. But it just seems like its not going away for good. It's to do with the door lock shunting with the latch on the body. Now have some insulation tape wrapped around the latch, which has muted the rattle a little bit. Need to experiment further, as I don't expect Fiat A** to be able to do anything else on their own.
Sound Deadening:
Have now got some less known (& less expensive) sound deadening pads in the doors. It does make a noticeable difference to the audio quality, but not very significant. It costed about Rs.3000/- per pad.
Service:
Like I mentioned, got the 4th year service done at Aadya motors. Getting there is a pain. Might be better off spending Rs.350/- for pickup/drop facility. The place itself is still getting readied. It seems that Fiat deadline to separate out the operations from the TATA side of things meant that they shifted without being fully ready.
Well what about the work? It's OK. They are atleast showing some intent. But then the quality of work was pretty much what we are all used to. The worst part was that they broke the clip of the rear AC vent housing.
. Now I used super glue to fix it in place.
Well, the car has definitely been a pleasure all these years. If we just resign to the fact that Fiat A** is what it is & try to do as much as we can ourselves, its been near perfect - a large sedan, looks that stand the test of time, 20+kmpl of diesel, power boost by race-chip, awesome ride & handling, pretty decent service & maintenance costs...
Stiil, miss a bit more power, that's it...just a bit more!
MODS: Can you please move this to the long-term section? Thanks!
