Old 1st August 2024, 20:20   #1
CentreOfGravity's Avatar
Thanked: 3,091 Times
2024 Suzuki Swift Sport specs leak ahead of launch next month
The specifications of the all-new Suzuki Swift Sport have been leaked prior to launch. An India launch isn't expected anytime soon.
Source: Rushlane
Original source: Best Car Web (Best of luck reading Japanese!)
2024 Suzuki Swift Sport specs leak ahead of launch next month-2024marutiswiftsportlaunchpricerender81068x684.jpg
2024 Suzuki Swift Sport specs leak ahead of launch next month-2024marutiswiftsportlaunchpricerender51068x683.jpg
After introducing the new-gen Swift, Suzuki is working on the Swift Sport performance model. As per reports, tests are currently underway at Suzuki’s test course in Japan. Launch is expected later this year in September.
The new Swift Sport will be lighter than the current model. Body-in-white (BIW) weight of the existing Swift Sport HEARTECT is 192 kg. This is around 40 kg lighter than its predecessor. Overall vehicle weight is 970 kg, which is around 70 kg lighter in comparison to the earlier model. The weight of the Swift Sport varies based on the market. For example, the European Swift Sport mild hybrid weighs 1025 kg. In comparison, the Japanese Swift Sport is 970 kg.
Dimensionally, the new Swift Sport is expected to be 3,990 mm long, 1,750 mm wide and 1,500 mm tall. That’s a gain of 125 mm in length and 15 mm in width, as compared to the current Swift Sport. The height and wheelbase (2,450 mm) are the same for both models.
Suzuki has developed a new K14D type 1.4L inline 4-cylinder turbo engine that comes with a 48V ISG (integrated starter generator). While the engine is new, the 48V mild hybrid setup is already in use with the current Swift Sport hybrid model. The ISG installed with this model generates 13.6 hp. In comparison, the Japanese model has higher numbers to show. With the 6-speed manual transmission, Suzuki Swift Sport will allow better control over acceleration. All while, registering improvement in fuel efficiency at around 16%. A 15% reduction in CO2 emissions is also noted, as per the NEDC combined cycle.
New Swift Sport’s 48V IGS supplies power to the vehicle during acceleration and high-load driving. It is also equipped with an advanced regen system that produces electricity during deceleration. The power generated is used to charge a dedicated lithium-ion battery.
The existing Swift Hybrid MZ (2WD) sold in Japan is available at a starting price of 2,167,000 yen (approx. Rs 12.04 lakh). In comparison, the current Swift Sport is available at 2,164,800 yen (Rs 12.03 lakh). As the new model will be equipped with a new engine and new features, it will be available at a higher pricing. However, the starting price of the new Swift Sport isn’t expected to go beyond 2.3 million yen (Rs 12.78 lakh).
The Japanese article mentions that the new model will produce 129 bhp and 23.9 kgm (234 Nm) of torque, which is 11 bhp less and 5 Nm more that the outgoing model which produces 140 bhp and 23.4 kgm (229 Nm) of torque.
CentreOfGravity is offline   (5) Thanks
Old 3rd August 2024, 15:26   #2
DicKy's Avatar
Thanked: 15,272 Times
Re: 2024 Suzuki Swift Sport specs leak ahead of launch next month
So they are continuing with the model and the old engine?
Heard they were stopping sales of the Swift Sport to comply with CAFE norms.
Originally Posted by CentreOfGravity View Post
The specifications of the all-new Suzuki Swift Sport have been leaked prior to launch....
The 140 bhp to 129 bhp drop happened around the time Europe raised its emission norms.
DicKy is offline   (1) Thanks
Old 6th September 2024, 08:57   #3
Thanked: 78,205 Times
The NEW Swift Sport to go Hybrid.
It is likely to appear sometime in 2024 or early spring 2025.
Name:  Screenshot 20240906 085623.png
the power unit will be an inline 4-cylinder, 1.4-liter turbo + 48-volt mild hybrid. The engine is a carryover of the current model, but the latest information is that the range of improvement is quite large, and "it will be an engine almost close to new development."
New Suzuki Swift Sport Main specifications (forecast)
・ Overall length × overall width × overall height: 3990 × 1750 × 1500 mm
・ Wheelbase: 2450 mm
・ Vehicle weight: 960 kg
・ Engine: Inline 4, 1.4L turbo + motor
・Maximum output: 150ps + motor 15ps
・Maximum torque: 24.5kgm + motor 6.0kgm
・Transmission: 6MT/6AT
・Drive system: FF・Appearance date: December 2024 to January 2025
・Estimated price: 2.3 million to 2.5 million yen
Link:
Old 20th December 2024, 14:03   #4
Swift Sport Final edition - 8500 cars only
Sale on March 19th 2025.
2024 Suzuki Swift Sport specs leak ahead of launch next month-screenshot-20241220-140103.png
Old 20th February 2025, 12:32   #5
New Swift to debut later this year.
The power unit is a 1.4L inline 4-cylinder turbo that is also installed in the current model, but the major change is that it will be a 48V mild hybrid.
Moreover, the latest information is that the engine body is not just a carryover, but "a major improvement close to the new development will be added". It is expected to significantly improve output and characteristics.
The price is expected to be around 2.3 million ~ 2.5 million yen with further enhancement of advanced safety equipment.
-Length×Width×Height: 3990×1750×1500mm
-Wheelbase: 2450mm
-Weight: 960kg
-Engine: Inline 4, 1.4L Turbo + Motor
- Maximum Output: 150ps + Motor 15ps
-Maximum torque: 24.5kgm + motor 6.0kgm
-Transmission: 6MT/6AT
Link:
