Toyota Hilux CHAMP Official Price: 459,000 – 577,000 Baht (Thailand)
Toyota Hilux Champ will make it to India, the IMV 0 platform, which is a ladder-frame unit, is meant for developing markets, and is likely to spawn an affordable version of the Fortuner.
Hilux Champ is likely to make its way to India in the future, and the SUV (affordable Fortuner) is expected to go on sale around a year after the pickup’s India launch.
Link:
Short wheelbase model SWB :
2.0 5MT SWB : 459,000 Baht
2.7 6AT SWB C&C : 487,000 Baht
2.7 6AT SWB : 499,000 Baht
2.4 6AT SWB C&C : 536,000 Baht
2.4 6AT SWB Attractive Package : 577,000 Baht
LWB long wheelbase model:
2.4 5MT LWB C&C : 499,000 Baht
2.4 5MT LWB : 527,000 Baht
2.4 6AT LWB : 562,000 Baht
Length 4,970 mm
Width 1,785 mm
Height 1,735 mm
Wheelbase Length 2,750 mm
Minimum ground clearance 164 – 180 mm.
Minimum turning radius 5.4 m
Tailgate dimension (width x length x height) 2,312 x 1,711 x 327 mm.
Oil tank capacity 55 liters
Length 5,300 mm
Width 1,785 mm
Height 1,735 mm
Wheelbase Length 3,085 mm
Minimum ground clearance 164 mm
Tailgate dimension (width x length x height) 2,674 x 1,711 x 327 mm.
Oil tank capacity 70 liters
Engine & Drivetrain
Petrol 2.0 liters
Engine code 1TR-FE petrol 4-cylinder DOHC 16 valves 1,998 cc. Bore x Stroke 86.0 x 86.0 mm (Square Combustion Chamber) Compression 10.4 : 1 Fuel is supplied by EFI injectors with Dual VVT-i variable valve system. Maximum power 139 hp (PS) at 5,600 rpm Maximum torque 183 Nm at 4,000 rpm Paired with a 5-speed manual transmission with rear-wheel drive.
Petrol 2.7 liters
Engine code 2TR-FE petrol 4-cylinder DOHC 16 valves 2,694 cc. Bore x Stroke 95.0 x 95.0 mm (Square Combustion Chamber) Compression 10.2 : 1 Fuel is supplied by EFI injectors with Dual VVT-i variable valve system. Maximum power 166 hp (PS) at 5,200 rpm Maximum torque 245 Nm at 4,200 rpm It is paired with a 6-speed automatic transmission with rear-wheel drive Sequential Shift.
2.4-litre Turbo diesel (5MT)
Engine code 2GD-FTV diesel 4-cylinder DOHC 16-valve, 2.4 liters, 2,393 cc, Bore x Stroke 92.0 x 90.0 mm, Compression 15.6 : 1 Fuel injection with i-ART injectors via commonrail Turbocharged compressed air trailer with Intercooler Maximum output 150 hp (PS) at 3,400 rpm Maximum torque 343 Nm at 1,400 – 2,800 rpm Paired with a 6-speed manual transmission with rear-wheel drive.
2.4L Turbo Diesel (6AT)
Engine code 2GD-FTV diesel 4-cylinder DOHC 16-valve, 2.4 liters, 2,393 cc, Bore x Stroke 92.0 x 90.0 mm, Compression 15.6 : 1 Fuel injection with i-ART injectors via commonrail Turbocharged compressed air trailer with Intercooler Maximum output 150 hp (PS) at 3,400 rpm Maximum torque 400 Nm at 1,600 – 2,000 rpm It is paired with a 6-speed automatic transmission with rear-wheel drive Sequential Shift.
Safety Features &; Driving Assistance
GOA Safety Structure
3-position 2-point ELR seat belt with automatic retraction system
2-position airbag
Front pair
Anti-lock ABS
BA brake reinforcement system
Brake Force Distribution ED
Source:
