Old 3rd September 2021, 11:55   #61
Thanked: 76,191 Times
re: Toyota's Compact SUV, now launched as Corolla Cross
Toyota Corolla Cross for Japan:
- Differentiates in exterior styling from the Cross launched in other countries
- getst a 'C' insignia sitting on the front grille, a badge shared with the rest of the Corolla line-up in Japan.
-higher-end variants of the Japan-spec Corolla Cross get quad-beam LED headlights with sequential LED turn signals.
- the interior remains conservative, with an all-black, single colour scheme broken up by bits of silver.
-Japan-spec Corolla Cross separates itself with models sold elsewhere with the inclusion of a rather large panoramic sunroof.
Toyota's Compact SUV, now launched as Corolla Cross-d67a1de964ea4b9f2e31f500f66a66bb.jpg
Toyota's Compact SUV, now launched as Corolla Cross-9c7134a8c253e2c13674166f4714b6c1.jpg
Toyota's Compact SUV, now launched as Corolla Cross-8475d6d8aeb746352ac9833c471b66ae-1.jpg
Toyota's Compact SUV, now launched as Corolla Cross-3d308c7e45b986ad960e69ced1505951-1.jpg
Toyota's Compact SUV, now launched as Corolla Cross-5db42230c61a4a60ea7a0ec6fd630b99-1.jpg
Toyota's Compact SUV, now launched as Corolla Cross-20210902corollacross7.jpg
Toyota's Compact SUV, now launched as Corolla Cross-20210902corollacross1.jpg
Link
volkman10 is offline
Old 9th September 2021, 10:14   #62
Toyota Corolla Cross for the Japanese market, looks stunning in black.
Expect the midsize SUV for India to carry the same moniker.
Toyota's Compact SUV, now launched as Corolla Cross-20210909_newcorollacross5.jpg
Toyota's Compact SUV, now launched as Corolla Cross-20210909_newcorollacross1.jpg
Link
Old 14th September 2021, 11:46   #63
Launched in Japan:
Toyota, Corollas' new compact SUV "Corolla Cross" Gasoline car and hybrid car are available and the price starts from 1,999,000 yen. (~ ₹ 13.4 lakhs)
Gasoline cars and hybrid cars are available in the powertrain lineup, and the prices for gasoline cars range from 1,999,000 to 2,640,000 yen( ~₹ 17.7lakhs) 2WD (FF) and E-Four 4WD are available for hybrid vehicles, and the price ranges from 2,590,000 yen(~ ₹ 17.3 lakhs) ) to 3,199,000 yen (~ ₹21.4 lakhs)
The Corolla Cross will be a model located between Toyota's SUV lineup, the middle-sized SUV "RAV4" and the compact class SUV "Yaris Cross."
The RAV4 will use the TNGA GA-K platform and the Yariskros will use the TNGA GA-C platform, while the Corolla Cross will use the same TNGA GA-C platform as the new Corolla.
The "C-HR" is a lineup of SUVs that use the TNGA GA-C platform, but while the C-HR is positioned as a specialty SUV, the new model Corolla Cross is more utility. It will be an SUV that emphasizes.
The body size is 4490 x 1825 x 1620 mm (total length x total width x total height). The wheelbase is 2640mm. The minimum ground clearance is 160mm for both 2WD and 4WD. The weight of the vehicle varies depending on the grade, but the lightest gasoline vehicle 2WD weighs 1330 kg, and the hybrid vehicle weighs 1380 kg to 1510 kg. Considering handling, the minimum turning radius is 5.2m, which is the smallest level in its class.
- Hybrid vehicle achieves fuel efficiency of 26.2km / L in WLTC mode
The gasoline-powered vehicle is a combination of the 4-cylinder 1.8-liter DOHC engine used in the Corolla series and the Super CVT-i. The hybrid vehicle combines the 4-cylinder 1.8-liter DOHC engine for hybrids, which is also used in the Corolla series, with the THS II system with a reduction mechanism. The fuel consumption is WLTC mode, 2WD for gasoline vehicles is 14.4km / L, 2WD for hybrid vehicles is 26.2km / L, and 4WD for hybrid vehicles is 24.2km / L.
Link
Old 18th October 2021, 11:32   #64
Axe77's Avatar
Thanked: 26,774 Times
This will be a brilliant fit in the Indian market. Ideally I would like a top of line hybrid variant to retail on road at about INR 32 - 35 lakh as realistic pricing.
It definitely doesn't look exciting by any measure. Even the looks, both interior as well as exterior I feel actually look very 2015 (comparable more to the current gen Tucson for instance rather than something that says 2022.
I'd definitely put it on my list for my 25 - 35L second car purchase. The hybrid efficiency makes a strong case for itself in today's times, combined with the absence of range anxiety from full blown EVs currently.
Axe77 is offline   (1) Thanks
Old 8th December 2021, 08:03   #65
Toyota Hilux and Corolla Cross spotted in Bihar. What is Toyota up to?
Toyota Hilux is rumored to be launched in India, but sighting of the Corolla Cross is speculated to give a new dimension to the SUV launches from Toyota (/Suzuki).
Link
volkman10 is offline   (4) Thanks
Old 8th December 2021, 08:51   #66
DicKy's Avatar
Thanked: 14,571 Times
Toyota Hilux is rumored to be launched in India, but sighting of the Corolla Cross is speculated to give a new dimension to the SUV launches from Toyota (/Suzuki).[/url]
I believe it is on a truck. So most probably on transit to our neighbours.
Also not camouflaged or anything. Just pre delivery transit wrappings.
DicKy is offline
Old 8th December 2021, 09:29   #67
Equus's Avatar
Thanked: 424 Times
Corolla cross makes perfect sense for India. Also for Toyota - this way they can keep increasing Fortuner prices
Seriously, they are missing a proper 5 seater crossover. If priced around 22-28L, it should succeed!
Equus is offline
Old 15th December 2021, 00:51   #68
CEF_Beasts's Avatar
Thanked: 19,725 Times
According to MotorOctane the spyshots they have received from a subscriber of their’s is the Toyota Corolla Cross under camouflage in Hyderabad.
Now unless the side profile would’ve been visible it’s hard to tell which make and model it is and whether it is actually a Corolla Cross!
https://m.motoroctane.com/article/ne...is-time/228095
EDIT: The ORVM placement is not the same as the Corolla Cross, it’s some other car under testing.
CEF_Beasts is offline   (2) Thanks
Old 16th January 2022, 20:51   #69
amitjha086's Avatar
Thanked: 657 Times
Re: Used CVTs: Toyota Corolla vs Honda City
This is a little off topic. But since this post on Toyota Corolla appeared on the homepage of Team-BHP the same day that I went to check out Toyota cars for a friend, I felt like putting in my enquiry here and throwing in some info too. Are Toyota Corolla Cross and Toyota Raize available in India?
A short video on Toyota Corolla Cross
Another video on Toyota Raize
Corolla Cross comes with 2.4 litre petrol engine as told by the salesman. The ground clearance is 200mm. The price of MT is 1.16 crores NPR and for automatic is 1.36 crores NPR. This feels solidly built and exudes elegance. Since, this was too expensive, there was no point in test driving it. Then we went to check the Raize ( pronounced as in Rise). It was imported directly from Indonesia and appeared so much like Brezza. The built quality was poorer than Brezza and door panels were filmsy. The interior was a compromise too. The gears did not slot well and 1.2 liter petrol engine was just adequate for getting from point A to B on flat roads. It cost 66 lacs NPR for a 5 gear MT and 72 for auto. I did not find them value for money. On asking them, why should anyone buy Raize over say Creta SX costing 60 lacs or a Magnite turbo costing 40 lacs, he answered reliability. Well, too high a premium for reliability for a car that should cost around 40 lacs NPR.
Anyway, Corolla cross was a nice place to be and seemed so perfect. It was a tad smaller than RAV4 which was on display just beside it, but perfect for my kind of usage. I hope to go for a test drive someday soon; but then they will thrown in so many call later on to coerce on buying. Looking forward to an EV version of Corolla Cross which should come at half this price. For those not aware about costs of cars in Nepal, ICE cars attracts a tax of 240% which EV do no carry much tax. For reference, Swift vxi is 32 lacs NPR, Nexon Petrol XZ+ is 48 lacs NPR and Nexon EV top variant is 41 lacs NPR.
amitjha086 is offline   (2) Thanks
Old 17th January 2022, 22:41   #70
Thanked: 69 Times
Attachment 2245334
Attachment 2245335
This might be the Yaris Cross as a person from Toyota told me today, its coming here this year inside 20 lacs
Joker is offline
Old 18th January 2022, 00:37   #71
CEF_Beasts's Avatar
Actually the car spotted by MotorOctane is the new gen Hyundai Tucson, just to get some attention they have mentioned Corolla Cross. Had messaged the founder of MotorOctane, he saw my message as well but sadly didn’t correct the mistake.
Easy way to identify is the ORVM. On the car spied the mirror is differently placed compared to both Corolla Cross and Yaris Cross.
Yaris Cross mirror position:
Corolla Cross mirror position:
New gen Hyundai Tucson mirror position:
I doubt the Yaris Cross will make it to India (it’s too expensive for India, I’m sure Toyota doesn’t want another Yaris experience), the person from Toyota could’ve confused the Creta-rival that both Toyota and Suzuki are co-developing as the Yaris Cross, which will be built in Toyota’s factory currently where only the Camry is assembled.
Old 31st January 2022, 20:11   #72
ron178's Avatar
Thanked: 7,601 Times
The USA's Insurance Institute of Highway Safety (IIHS) has confirmed that they are currently crash-testing the 2022 Corolla Cross, uploading an audio clip of the static roof strength test.
Link to Tweet
ron178 is offline
Old 11th February 2022, 10:09   #73
Toyota Corolla Cross is a huge success wherever it has been launched. Hybrid variant is in huge demand in most markets.
Contrary to what critics are saying online about hybrid cars and expensive battery replacement costs, the reality is quite the opposite.
Checks with several Toyota dealers across town have confirmed that the Corolla Cross Hybrid has been more popular than what Toyota initially anticipated.
Malaysians responding well to Toyota Corolla Cross Hybrid, contributes over 40% of sales
Hybrid adoption rate in Japan (90 percent) and Thailand (85 percent), it is definitely encouraging to see Malaysians being more receptive to hybrids than before.
Link
Old 10th May 2022, 20:15   #74
ron178's Avatar
Toyota Corolla Cross achieves the IIHS' highest award, Top Safety Pick +.
Three Toyota SUVs earn IIHS accolades - IIHS
To qualify for either award in 2022, vehicles must earn good ratings in six IIHS crashworthiness evaluations, including the driver-side small overlap front, passenger-side small overlap front, moderate overlap front, original side, roof strength and head restraint tests. They must also be available with a front crash prevention system that earns advanced or superior ratings in both the vehicle-to-vehicle and vehicle-to-pedestrian evaluations.
For TOP SAFETY PICK, at least one good or acceptable headlight system must be available. To qualify for the “plus,” good or acceptable headlights must be standard across all trims.
ron178 is offline   (1) Thanks
Old 25th May 2022, 16:24   #75
1-year waiting period, Japan suspends bookings for Toyota Corolla Cross Hybrid.
Unable to cope with the demand, a situation that is made worse by the on-going semiconductor parts shortage, Toyota dealers in Japan have temporarily stopped accepting any more bookings for the Corolla Hybrid.
It is unclear when the suspension will be lifted but Japanese buyers looking for a Corolla Cross are now being directed to the regular combustion engine variant, which has a shorter, 6 months waiting period.
Link
