Old 23rd April 2020, 20:50   #1
Thanked: 78,169 Times
Toyota's Compact SUV, now launched as Corolla Cross
Toyota's C-SUV is speculated being spied testing in Thailand.
If so, this could be the SUV that will be based on the Suzuki’s C-platform that underpins the global Vitara and Brezza. Will rival Hyundai's Creta, Kia Seltos and others in this segment.
It is likely to measure around 4.3 meters in length. There will be two different versions of this SUV, one each for Maruti Suzuki and Toyota.
Toyota's Compact SUV, now launched as Corolla Cross-b89afa6c2a5745897a3408fed66da13f.jpg
Recap:
Toyota and Suzuki have agreed to collaborate on the development of a C-segment SUV for India, with Toyota taking on production of the Suzuki Vitara Brezza for that market.
Link
Source:
Last edited by benbsb29 : 30th April 2020 at 12:06. Reason: Corrected typo -> Creta
volkman10 is offline   (7) Thanks
Old 25th April 2020, 19:59   #2
Thanked: 5,458 Times
Re: Toyota's Compact SUV spied on test in Thailand
First impression? Design seems to be on the lines of S-Cross. A strict no-go, then.
romeomidhun is offline
Old 29th April 2020, 08:33   #3
Spied again, speculated to be the Toyota Corolla Cross:
Called the 740B Design,the compact SUV will make its debut in March 2021.
Replacement to the Corolla Sedan for the Indian market?
under the new TNGA-C platform, which will come in between the C-HR and RAV4 models.
It will have TNGA platform, the same as Corolla, but in a simplified version, focused on emerging markets. And as anticipated by FOUR WHEEL Drive, it will have 1.8 flex hybrid engine, plus 2.0 flex versions.
Link
volkman10 is offline   (9) Thanks
Old 29th April 2020, 21:10   #4
Thanked: 2,556 Times
Could this be the Rav4?
Because a search for Corrolla cross shows what is essentially a station wagon or something that looks like a subaru outback rather than something an SUV silhouette.
ZenMaster is online now
Old 29th April 2020, 22:03   #5
New Toyota Corolla Cross 2022 trademarked in Australia! Corolla-based small SUV to take fight to Kia Seltos.
the Corolla Cross – or whatever it ends being called – is on the way, and it will sit alongside the C-HR in Toyota’s growing SUV line-up and therefore take on the Kia Seltos and Hyundai Kona, among other small models.
Like the Corolla and C-HR, the Corolla Cross should ride on Toyota’s TNGA-C platform and will likely share its powertrain options with the former, including its 125kW 2.0-litre naturally aspirated four-cylinder petrol engine and 90kW 1.8-litre petrol-electric full hybrid.
Front- and all-wheel drive are both expected to be available, as per the Yaris Cross, while continuously variable automatic transmissions (CVT) will feature prominently across the range, if not exclusively.
And there’s also the prospect of a GR Corolla Cross that would rival Hyundai’s yet-to-be-revealed Kona N by adopting the GR Yaris’ 200kW 1.6-litre turbo-petrol three-cylinder engine, which is also expected to power the mooted GR Corolla hot hatch.
Link
Old 30th April 2020, 08:54   #6
This model would be positioned as a more practical alternative to the Toyota C-HR but at the same time simpler and more affordable than the RAV-4.
All the initial details indicate the initial launch in several Asian markets, followed by the release in South America. Corolla Cross will be produced in Brazil and can reach the US market whether it will be available in Europe or not is still unknown at this time.
Link
The debut of the new Toyota Corolla Cross is set for sometime in 2021. It remains to be seen in which markets it will initially go on sale, although everything indicates that Brazil will be one of them. Chances are that the first units will be available by the end of next year or even as early as 2022.
Link
Old 1st May 2020, 10:55   #7
New Toyota Corolla Cross 2022 trademarked in Australia! ---
More practical and conventional than C-HR, and is simpler and more affordable than RAV-4 in the global market.
Trademark filed - Corolla Cross:
Toyota's Compact SUV, now launched as Corolla Cross-toyotacorollacrosstrademarkaustralia.jpg
Old 5th May 2020, 19:27   #8
Toyota C-segment SUV different from C-HR, same platform as the Prius and C-HR , in a segment between the C-HR and RAV4 and a size smaller than the RAV4.
Link
Rivaling Jeep Compass, the SUV is rumored to have a starting price of R $ 150,000 ( ~ ₹ 20.6 lakhs) and rage topping at R $ 250,000(₹ 27.5 lakhs)
It should take advantage of the 2.70-metre wheelbase of the sedan, as well as the architecture with independent suspensions on all four wheels
The first is the 2.0 four-cylinder flex with variable injection between direct and indirect, capable of yielding 177 hp. It comes coupled to the CVT exchange with 10 simulated gears.
The second, already anticipated by FOUR WHEELS, is the 1.8 four-cylinder flex hybrid of pseudo-Atkinson cycle, with 122 hp, managed by a CVT box that combines the forces of thermal and electric thrusters in a planetarium.
Link1
Old 25th May 2020, 10:14   #9
Toyota's new C segment SUV "local boy"as called in Japan , appear in a leaked image.
appear as a younger brother of RAV4
the local boy is called the Toyota in-house name, and it is a 3 number type crossover with a compact size feeling like the C-HR, but practicality and habitability It seems to be a fulfilling model equipped with.
It is not a sporty model with large diameter tires like the C-HR that emphasizes running, but it is a rather modest visual, but in the direction of model rise (RAIZE) which is popular as an A segment SUV model.
the power train is a 2.0L M20A type in-line 4-cylinder direct injection that is also used in the Lexus "UX200". There is a high possibility that an engine will be installed, and the engine output is probably 174ps / maximum torque of 209Nm, and fuel consumption is expected to record around 16.4km / L in WLTC mode.
Link
Old 29th May 2020, 22:39   #10
Toyota Corolla Cross :
- 2.0L naturally Aspirated engine
- Launching in early 2021
Thailand may be the same as Taiwan's 1.8L naturally aspirated engine, and the Japanese version will be replaced by 2.0L Hybrid.
Full length: 4,400mm full width: 1,815mm full height: 1,600mm wheelbase: 2,640mm vehicle weight: 1,530kg minimum turning radius: 5.2m
Engine type:
2.0L inline four-cylinder
Maximum horsepower: 140hp / 6,200rpm
Maximum Torque: 17.5kgm / 4,000rpm
Gearbox: CVT stepless automatic drive
FF front suspension: McHuachen rear suspension: double A-arm
Link
Old 8th June 2020, 09:15   #11
Toyota's C -SUV coming later this year.
First arriving in Thailand, but likely to arrive in India too. This SUV will be an alternative to funky, more expensive C-HR.
Think of it as a more versatile C-HR, as if the C-HR is a BMW X2 and this C-SUV is a BMW X3.
Now more details are leaked:
- Toyota C-SUV body dimensions: 4,460 mm long, 1,825 mm wide, 1,615 mm(H)
Toyota C-HR external dimensions: 4,360 mm long, 1,795 mm wide and 1,565 mm
Toyota RAV4 body dimensions: length 4,595 mm, width 1,855 mm, height 1,700 mm
- TWO Power-trains to choose from:
2ZR-FBE 4-cylinder petrol engine in 1.8-liter inline with 141 horsepower at 6,000 rev / min, maximum torque of 177 newtons-meters at 4,000 rev / min, transmitted by 7 speed Super CVT-i automatic transmission with Sequential Shift and Shift Lock
Hybrid 4th Generation power: 2ZR-FXE DOHC 4-cylinder petrol engine in the 1.8-liter Atkinson cycle with a maximum power of 98 horsepower at 5,200 rev / min, maximum torque of 142 newton-meters at 3,600 rev / min combined with working with motor Electricity 72 horsepower, maximum torque of 163 newton-meters, nickel-metal hydrid batteries Including a 122 horsepower system, transmission with E-CVT automatic transmission with Shift Lock
- Distribution of all 4 sub-models, namely
1.8 SPORT
HYBRID SMART
HYBRID PREMIUM
HYBRID PREMIUM SAFETY
The basic car details are as follows:
1.8 SPORT
1.8 liter gasoline engine
TNGA structure (same TNGA-C platform as Toyota Corolla Altis including C-
HR)
9 inch touch screen audio system supports Apple CarPlay connectivity
Telematics system
Rear view camera
Back seat and synthetic leather material
Automatic air conditioning system
17 inch wheels
HYBRID SMART (standard equipment added from 1.8 SPORT)
1.8 liter Hybrid engine
LED Projector headlights
HYBRID PREMIUM (standard equipment added from HYBRID SMART)
Tailgate open-close electrically With sensors to open-close the rear lid, Kick Activated
Driver seat, electric adjustment
Blind spot warning system on the side mirror BSM
RCTA warning system
Upgraded from 17 to 18 inch alloy wheels
HYBRID PREMIUM SAFETY (Standard equipment added from HYBRID PREMIUM)
Electric moon roof
Panoramic view camera with 3D view (Panoramic View Monitor)
The Toyota Safety Sense safety kit is expected to be version 2 as it is installed in the Corolla Altis consisting of
All-speed range DRCC (Dynamic Radar Cruise Control) control system
AHB (Automatic High Beam) control system
Safety system before collision PCS (Pre Collision System)
Lane departure warning system With automatic LDA (Lane Departure Alert with Steering Assist)
Lane Tracing Assist (LTA)
There are 7 exterior colors on the exterior.
-Platinum White Pearl
- Attitude Black Mica
- Celestite Gray Metallic Gray
- Silver Metal Stream Metallic
- Graphite Metallic Gray
- Red Mica Metallic
- Nebula Blue
Interiors:
- All models black except the HYBRID PREMIUM / HYBRID PREMIUM SAFETY pearl white, black and blue gray
- Terra Rossa red, only the HYBRID PREMIUM / HYBRID PREMIUM SAFETY pearl white, black and blue gray
Model name is not yet known, but "Corolla Cross" is very much possible .
Link
volkman10 is offline   (4) Thanks
Old 12th June 2020, 09:52   #12
Toyota's upcoming SUV shows its front, test drive to commence soon: Link
Old 12th June 2020, 11:04   #13
Amrik Singh's Avatar
Thanked: 3,651 Times
RAV 4 ? However there seems to be a exterior design change. Going down the ladder of Toyota SUV's - LC, LC Prado, Highlander, Fortuner, RAV 4, this Toyota C-SUV is new entrant ?
Amrik Singh is offline
Old 12th June 2020, 19:49   #14
Toyota Corolla Cross tail lights gets partially exposed for the first time. Skoda like tail lamps?
- Code name 740B the SUV has been developed locally last year
- Positioning is set under RAV4 and is built with the same TNGA-C chassis structure as the current Corolla Altis .
- The rear is equipped with an L-shaped LED guide. The light bar, the body through the black scratch-resistant wheel arch to enhance the rough feeling of SUV.
Link
Old 13th June 2020, 12:13   #15
Toyota's C-SUV to get RAV4 inspired tail lights. Link
the inverted L-shaped design looks like the new RAV4
there are several parts that are different from the new RAV4, such as the vertical basic reflector and the rear lower bumper with a protector, a slightly glossy rear fender, the rounded press line around the rear quarter panel, etc
There are roughly four types in the lineup as follows.
Rendered:( but not accurate)
Or will it lo like the Wildlander in China ?:
Toyota's Compact SUV, now launched as Corolla Cross-744x01autohomecarchsen13snpmaigqqaak4qjvgojc890.jpg
